Diesel sounding M20 with forged pistons problem
  • etagolnik
    • Nov 2012
    • 105
    My m20 stroker (b28 I think?) sounds funny at cold idle. There is sort of a clanking sound similar to a diesel. I have been informed it may need a valve adjustment, have an exhaust leak or need different oil.
    When the engine is warm the sound is gone by the engine but a soft clanging can be still be heard inside the car.
    I am running 10w60 Liquimoly oil.
    I am wondering if the forged pistons have anything to do with it...Maybe they take time to expand.
    I have taken Videos of the cold idle and warm idle.
    Cold Idle: https://www.youtube.com/watch?v=7e5x4dVvwxU
    Warm Idle: https://www.youtube.com/watch?v=FYXDTfBI-Uc
    Input would be appreciated!! Thanks!
  • betz
    • May 2016
    • 317
    Yes, forged pistons are noisy when cold and will burn some oil / be noisey on start up. This is due to the different properties of the metal. You can get different materials / coatings that will combat this. Maybe give us info on what type of pistons you bought?
    Full disclosure, I did not listen to the video.
    But this is one of the reasons I went with stock pistons for my 2.8 build.
    '86 Burgundrot 325 2.8 stroker.
    Other cars:
    2000 Porsche Boxster
    2006 Subaru Outback XT 5MT
    1972 Porsche 914
    • wworm
      • Dec 2016
      • 1719
      just FYI your vids are switched in the first post. No idea what the clacking is. Mine sounded like that and it was a bone stock eta. Not quite as clacky but did sound a more like a diesel than a gas engine lol. Check the valves and see if that helps.
      1984 Delphin 318i 2 door
      • digger
        • Nov 2005
        • 6196
        yeah forged pistons do that depending which alloy and what clearances are used.
        • e30davie
          • Apr 2016
          • 1788
          Your other video suggests it all works quite well:)
          Not much help but my Stocko m20 sounds significantly different when cold vs hot. I put it down to being an old engine thing....
          • digger
            • Nov 2005
            • 6196
            its always worth rechecking the valve train or trying to chase down the noise as it could be some kind of light interference issue
            • ForcedFirebird
              • Feb 2007
              • 8300
              Use a mechanic's stethoscope and probe the rocker cover and outside of the bores. Will tell you in seconds where the noise is from. :)
              john@m20guru.com
              Links:
              • etagolnik
                • Nov 2012
                • 105
                Hey guys! Thanks for all the replies.
                - The Pistons are Ross Forged Pistons
                - I believe the rods are Eagle forged H beam rods
                - Myster-e ported (Bimmerheads?) Head with 272 cam and I believe heavy duty rocker and double valvesprings
                I have tried using actual stethoscopes to hear where the noise is coming from and have not been that successful in tracking it down.
                I have been told it may be an exhaust leak (doubt it). The exhaust does leak right where the turbo meets the downpipe but I doubt it is the culprit.
                I have been told the rockers may need adjusting. Last time I adjusted the rocker lash was before the engine was in the car. So I am hoping that is the issue.
                I can also hear a rattle from inside the car, coming from the engine bay when i hold the rpm steady around 1200ish, which could still be the valvetrain.
                • etagolnik
                  • Nov 2012
                  • 105
                  Also, How much oil is supposed to be coming out of that oil rail that passes from the front of the head to the back of the head?
                  I watched through the oil filler hole as it was running and couldn't see oil spraying out?
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Doesn't really "spray", it's more like a steady stream/drip. If it's "drop, drop, drop" check oil pressure.
                    john@m20guru.com
                    Links:
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4502
                      That sounds like good ole piston slap to me. Non coated JE and Ross pistons are known for it. I had an Evo that sounded like a diesel on cold start up. That engine was torn down after 20K hard miles and it looked like brand new but sounded awful.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Nail = Head.
                        JE, Ross and a few others like to have excessive piston to bore clearance. Great pistons, despite the flack of the internet bosses, but they are loose jugs until ~200°f or so.
                        Today's alloys are much better, but in all honesty, I have been amazed at how well the hyper alloy OEM Mahle pistons react to abuse, and how tight of a tolerance they allow.
                        john@m20guru.com
                        Links:
                        • hasa
                          • May 2013
                          • 307
                          I've heard noisy Venolia's and Wiseco's too. Depends on clearances.
                          • etagolnik
                            • Nov 2012
                            • 105
                            - Oil pressure is good. Its about 90psi or so cold and then warm its just under 20psi and rises with rpm.
                            - Sucks about those pistons...I dont like. The engine is only a few years old. I plan on doing methanol injection and shooting for 400whp. If I warm up the car before beating on it I guess it will be ok if thats normal for those pistons.
                            - Last night I checked the rocker to valvespring clearance and most of them were larger than spec..I set them all to 0.010". I think the biggest gap I measured before adjusting was 0.016"! I'm interested to see how it sounds/performs now.
                            - Tonight I plan to button up the valve cover and seal a exhaust leak right after the turbo.
                            • etagolnik
                              • Nov 2012
                              • 105
                              So I drove the car today and it still is rattling. Even when its warmed up.
                              Here is a video. If you listen real good you can make out the rattle.
