Ring Ridge?
  • Andre3127
    • Dec 2017
    • 291
    Ring Ridge?
    I have a 325e block I'm building an engine with, and it has a significant ring ridge in the #1 cylinder on the front side. The others have a ridge that's almost undetectable except for the line under the honing marks.
    Has anybody built a motor with cylinder and piston wear that's beyond the .0047" clearance service limit spec? Should I just run the damn thing? or consider overboring to 85mm and building a 2.8?
    Budget E30 Parts - Used and Reconditioned parts for your BMW
  • ForcedFirebird
    • Feb 2007
    • 8300
    Definitely bore it! Otherwise you run the risk of banging up your new rings to bits. The old rings were slowly worn to that shape, the sharp edges on the new rings will be screaming in pain.
    john@m20guru.com
    Links:
    • TobyB
      • 5298
      I think I can count on the fingers of no hand the number of
      BMW engines I've taken apart that had a measurable ridge*...
      ...*unless something bad had happened to that cylinder,
      like running with a leaking head gasket.
      Bore it. John's always right AND the ridge will kill the ring and/or piston in short order.
      t
      • ForcedFirebird
        • Feb 2007
        • 8300
        Originally posted by TobyB
        John's always right
        Wouldn't go that far lol.
        My pops likes to say "I thought I was wrong once, but I was only mistaken." :p
        Honestly, though, just try and share good info with the community - most of it is based on experience.
        john@m20guru.com
        Links:
        • redlightpete
          • Mar 2012
          • 266
          You could probably find an m20 block for free with no measurable ring ridge. I’d leave one at the end of the driveway for you, but that probably doesn’t help you much in NY.
          • Andre3127
            • Dec 2017
            • 291
            I always appreciate hearing from you FF. It just so happens that I have another block already in my possession, but it was sort of sold to someone. I asked him if be needed the block since he really just wanted the rotating assembly, but he said I could keep it if I need. It has a very slight ridge but I think when I hone it it'll go away. Almost feels like it's only combustion residue.
            If the ridge is nearly gone, should I still bore it out?
            If I make a 2.7i stroker using a b25 piston in a b27 bottom end (crank and rods), will the rings hit that ridge? I can't find any detailed specs of both pistons when it comes to upper ring to wrist pin distance.
            Sent from my XT1053 using Tapatalk
            • jeffnhiscars
              • Jun 2011
              • 6011
              A ridge reamer is your friend
              Alice the Time Capsule
              • digger
                • Nov 2005
                • 6216
                the first thing to do is measure it properly to see of its round, straight, tapered or what IMO
                • Andre3127
                  • Dec 2017
                  • 291
                  That's the plan, but I'm now probably just going to use my other block and save this one to turn into a 2.8 and bore it to 85mm.
                  I need to borrow a micrometer from work in order to measure the bores. That size is the one I don't have!
                  Thankfully, I have the equipment to bore out cylinders myself. Bread and butter for a bridgeport mill.
                  • TobyB
                    • 5298
                    Once or twice (or maybe more :) ), I initially disagreed with something you wrote.
                    In trying to type up the response, invariably, I discovered it was MY misunderstanding,
                    not yours....
                    Thus, I realized the errors of my ways. :nice:
                    t
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      ...as long as we admit when we are :p
                      john@m20guru.com
                      Links:
