Best Top End Gasket Set?
  • tomstin
    • Mar 2015
    • 569
    I have a head gasket weeping oil. I'm getting tired of the oil leak and time to tackle the head gasket. Is there a top end gasket kit that is better than others?
    And yes, for sure its the head gasket. Dry above the split between the head and the block.
    2004 525i Manual - 1985 325E Coupe Manual
  • digger
    • Nov 2005
    • 6176
    the OE one is the best....but you can buy one of the cheaper ones and just buy a OE head gasket
    • GoochE30
      • Jul 2018
      • 55
      I did the Elring kit and I haven't had any problems with it. I've always heard OEM is best, but my engine is coming apart again soon for built bottom end so I kept the Elring head gasket on there in the meantime. No issues
      • TobyB
        • 5286
        Personally, I've had no trouble with Elring or even (gasp) Reinz, but that shows you
        that sometimes,
        Ignorance IS bliss!
        heh
        t
        • hasa
          • May 2013
          • 307
          Reinz and Elring are OEM quality
          • TobyB
            • 5286
            Reinz head gaskets are sometimes marginal in the oil sealing department.
            They tend to hold compression, but may leak externally.
            "May" being the operant word.
            There's a thread a good while back with pictures. It's pretty obvious, visually.
            I used a Reinz before I saw that thread, and I guess that was the secret, as mine doesn't leak.
            t
            • nogapersnBMWs
              • 184
              BMW head gasket ($100) or Goetze ($35) have worked well for me--many have said Goetze makes the BMW HG--then usually get cheap top end gaskets set like Victor Reinz and sell the head gasket.
              1989 332iS AW2 @ 2,342 lbs. m20b31 (JE FSR 10.5:1; 284/280 cam; ST+1 Intakes; RHD 40mm ITB/CF Plenum; Stahl 1.5"/CRMB X/Borla XS Pro; TMS J-Stock suspension (Ver. 2); M3 E3 undertray/VAC CF splitter; exhaust blown difusser; (Teves Mk60 ABS in trunk next)
              Originally posted by Jb325is
              Sucks for everyone involved. Lots of guys are just building IG cars these days... Look good on the internet, but in real life they're hacked up piles of shit.
              Transaction Feedback: http://www.r3vlimited.com/board/showthread.php?t=258421
              • e30davie
                • Apr 2016
                • 1788
                Im 30,000km in on an elring. Hasn't failed yet, doesn't mean it won't fail tomrrow. doesnt mean it wont last another 100,000km:)
                Surface preparation is 100x more important than head gasket brand i reckon. I can make the best headgasket leak oil with poor surface prep:D
                  • 37833
                  We have a solution! With Goetze head gasket:
                  The Classic BMW engine builder since 2011. Engines, cylinder heads, parts, and select vehicle work — built by enthusiasts, trusted by builders.
                  Grover Beach, California
                  BimmerHeads.com
                  • tomstin
                    • Mar 2015
                    • 569
                    Originally posted by MR 325
                    We have a solution!
                    Mr 325, are the gasket sets the same for both the M20B27 and B25 engines? I have aB27. Thanks!
                    • nogapersnBMWs
                      • 184
                      The HG in both m20b27 and m20b25 are the same far as 84mm bore (its the internal crank size, piston compression/dome shape and rod length that differs), the only thing to check is the HG thickness as they are made and sold in different thicknesses to account for block and head shaving or to adjust quench. Although an m20 comes with different heads (200, 885), the top end gasket set is same except the intake and TB gaskets IIRC
                      Talk to Bimmerheads (MR 325) or Blunt, they will get you what you need!
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        VR and Elring gaskets leak oil at the head drain back holes. Just holding the gaskets in your hand along with OEM or Goetze, you can clearly see/feel the difference in quality. Biggest thing you will notice is the VR/Elring have an oval hole at the center oil drain - OE and Goetze have individual holes of the head bolt/drain. In a pinch, I have sprayed the VR/Elring gaskets with copper which seems to help, but only would do in a pinch.
                        https://bimmerheads.com/collections/...ead-gasket-set
                        Nice! Price is reasonable too.
                        I never understood why the TB and vac plates were never included in the kits, yet they supply new rings for the coolant sensors, t-stat and injector o-rings.
                        john@m20guru.com
                        Links:
                        • nogapersnBMWs
                          • 184
                          Very informative as always John!:
                          Maybe they kits don't include TB gasket as they are different sizes between m20b27 325e and m20b25 325i?
                          • THE DUDE ABIDES
                            • Apr 2018
                            • 57
                            So I'll take the fall on this one. I was dumb enough to buy a Metric Mechanic HG on my brand new motor. Guess what, it's a VR head gasket that has been slightly modified, coated and marked up 500%! For about the first 300 miles, I saw light seeping of oil into cooling system. No coolant in oil. Did leak down and compression test of the engine and numbers were good. As of two days ago, I am now seeing just a little bit of coolant in the oil so I will be swapping the HG with a Goetze one in the next few days. My logic is that for a while there was a one-way, pressure dependent leak between oil and coolant passages on the HG. Oil pressure gets up to 80psi and cooling system shouldn't go over 15psi so you can see how it's possible for this to happen. It seems that it took about 300 miles for it to become a two way leak. Fully reconditioned and decked head and block, etc. I suppose it could be an issue somewhere else, but I think that is unlikely.
                            The beatings will continue until morale improves
                            • digger
                              • Nov 2005
                              • 6176
                              The MM used to be Goetze brand gaskets.
