M20 AFM to M30 AFM with 19lb injector questions
  • Kingb
    • 928
    #61
    On ebay there are a set of design 3's and there are another set of 19# but doesn't specify what design but they look older so I am guessing those are 2's.
    I will look for the 2's
    Originally posted by Nicademus
    My car beats off to that car. :bow:
    • E30_fiend
      • Apr 2006
      • 7348
      #62
      design 2's are the ones that are skinny then fat then skinny
      Design 3's are about the same skinny size all the way down
      • kamotors
        • Nov 2007
        • 7102
        #63
        are these design 2's?
        these are the ones that i have
        7speedshop.com
        • E30_fiend
          • Apr 2006
          • 7348
          #64
          mine have black where yours have silver but they could have been paint stripped. Those are most definitely design 2s
          • Kingb
            • 928
            #65
            ok cool. Those are the ones that I am going to buy on ebay. They are $55 with free shipping rebuilt
            • p0cket penguins
              • Jul 2008
              • 481
              #66
              i used design three ... which are the thin ones and they work fine
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                #67
                OK so I finally installed the '027' M30 AFM today. Idles like shit every time I start it, then smooths out after 30 seconds or so. Plugged the M20 AFM back in, runs fine. What gives? I let it idle for about 30 minutes after installing the M30 AFM, and then drove it to work and back to give it a good workout. Is there something I'm missing?
                • kamotors
                  • Nov 2007
                  • 7102
                  #68
                  mine did the same thing, weird huh, sometimes it runs good sometimes it runs like poop.
                  7speedshop.com
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    #69
                    this may be worth a try, disconnect both battery wires, and touch them together. This completely clears any memory in the ECU. Connect the M30 AFM and then reconnect the battery.
                    This didnt happen to me but I'm just trying to help.
                    Taylor
                    • p0cket penguins
                      • Jul 2008
                      • 481
                      #70
                      Did you only install the m30 AFM.... cause if so your running lean
                        • 34847
                        #71
                        yeah, the M30 AFM was designed for a different engine with a different ECU and a different tune with a different calibration. :roll:
                        • CorvallisBMW
                          • 13039
                          #72
                          No, I also put on rebuilt 17.5lb injectors, 8mm plug wires and a K&N cone filter w/ heatshield.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #73
                            i tried disconnecting several times, and the problem always came back. the new AFM i bought the guy said he adjusted it to work on these engines, he said he loosened the wheel 2 clicks and he said it worked perfectly.
                            7speedshop.com
                            • CorvallisBMW
                              • 13039
                              #74
                              I was under the impression that no modifications were necessary to the '027' M30 AFM
                              • kamotors
                                • Nov 2007
                                • 7102
                                #75
                                me too, but obviously not because it didn't work for me or you.
                                7speedshop.com
