M20 converted to Serpentine belt - Adding supercharger - Take 2
  • whodwho
    • Jun 2008
    • 1547
    #31
    I needed to get rid of that old nasty coolant reservoir and looked at this one to match the the other tank after powder-coating.
    I had got this ebay one before, It is really well made and finished nicely and is same price or cheaper then a new stock tank. (I would like to see a sensor bung but oh well) The issue I had with it is it didn't fit with the brackets the way they were. I contacted them and they wanted pics of the stock one vs theirs but doesn't look like it ever got redesigned 8^(
    So I bought another one and just made it fit, the lower bracket is just not even close to correct so after some cutting and bending in the end fits well.
    I have seen these clamps before and thought I would try them on the ICV and hose splice (not shrunk yet)
    Getting there, still need to mount up the small radiator and SC drain and some p-clamps here and there. That tank is just too shiny and needs to be powder-coated 8^)
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • ForcedFirebird
      • Feb 2007
      • 8300
      #32
      Tried on a few devices/PC's and the pics don't seem to be working.
      john@m20guru.com
      Links:
      • whodwho
        • Jun 2008
        • 1547
        #33
        Well that just sucks 8^(
        Like just the last set posted or all of them? On one of the site updates I couldn't attach pics so I started sharing and linking them but maybe that isn't working
        • digger
          • Nov 2005
          • 6215
          #34
          #31 doesnt show for me either
          • whodwho
            • Jun 2008
            • 1547
            #35
            Any better?
            I think I found it, Google Drive changed its sharing default and you have to select a different option on each share
            • daveduck
              • Dec 2015
              • 88
              #36
              Originally posted by whodwho
              Any better?
              Yes it is working now, interesting setup! I'd like to see SC M20s become a thing.
              • vWBIRDWv
                • Jan 2016
                • 43
                #37
                Nice work Whodwho im really looking forward to seeing this
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #38
                  Lol. Whodwho has had his m20 supercharged for many years, for those who can remember e30tech days.
                  john@m20guru.com
                  Links:
                  • digger
                    • Nov 2005
                    • 6215
                    #39
                    i'd like to see a twin screw
                    • vWBIRDWv
                      • Jan 2016
                      • 43
                      #40
                      I want to work something like this up for our motor ForcedFirebird but we only need 8psi for our build hahaha
                      • whodwho
                        • Jun 2008
                        • 1547
                        #41
                        Haven't got much done with everything going on but did work on the clutch project. I was going to find someone to machine the flywheel for me and figured it wasn't complicated and I would invest it in a machine for myself and do projects 8^)
                        Picked up a HF bench mill, they are a re-branded Sieg X2 and not a bad machine for the price, about the same a drill press and hopefully a bit more accurate!
                        Blank button flywheel needing holes
                        I 3D printed a drill template and centered on a tight fitting socket to rotate on,
                        Chamfer the holes
                        Centered for the center hole
                        Drag out the new boring head
                        Having at it (sharpie doesn't like WD40)
                        Final pass
                        Give it a chamfer
                        Looking like it is ready to give it a go
                        Flex plate and spacer
                        Spacer needs a little thinning by 2mm
                        And all bolted up nicely
                        In all its glory and with APRs 8^)
                        Next up it's big brother
                        A not very common 8.5" Quarter Master, I have a single and dual disk in the hoard pile
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #42
                          Super slick Keith! A machine is only as good as the operator. ;)
                          john@m20guru.com
                          Links:
                          • dvallis
                            • Oct 2015
                            • 1474
                            #43
                            Thread resurrection for parts confirmation. Will the M52 water pump pully and alternator pulley fit on an M20 water pump and alternator?
                            "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
                            1987 E30 3L Turbo Stroker Das Beast
                            2002 E39 M5
