Intake manifold nuts, washers, ?
  • SD-KC
    • Jan 2018
    • 116
    In my rush to get the intake manifold off, I wasn't paying attention to the nuts holding the manifold on the engine (lesson learned). Now that it's time for reassembly, I'm seeing that I removed 6 nuts and washers and six nuts with hats. I found a bimmer forum post saying they should be nuts, washers, and wave washers. Realoem diagram has nuts and washers.
    1. Are the nuts with hats equivalent to nuts and washers?
    2. Did you use a wave washer to soften the torque force on your intake?
    Thanks all.
  • roguetoaster
    Biggus Tippus
    • 7830
    1. Yes.
    2. No.
    • digger
      • Nov 2005
      • 6211
      Flanged nuts are fine. wave and spring washers are never used on the most critical of fasteners anyway so how much do they actually do...., though realoem does say wave washers with the flanged nuts. Don't just use regular nuts without a washer as it will chew into the alloy and have higher tendency to loosen/relax as the contact stress is higher. the wave washers are so puny i doubt they function like a proper washer in spreading the load
      • SD-KC
        • Jan 2018
        • 116
        Thank you for your help. I appreciate the responses. So much easier to take these off than put them on. I'm in the process of fitting my fingers or threading the swivel socket into these spaces without dropping the nuts, washers, jeez... Testing my patience.
        • digger
          • Nov 2005
          • 6211
          Get some itbs it’s a lot easier to install and remove than the factory manifold lol
          • roguetoaster
            Biggus Tippus
            • 7830
            Magnetize your socket for hard to reach fasteners.
            • TobyB
              • 5298
              It's funny how the thinking has changed- the 2002 has wave washers anywhere a steel bolt head clamps down an aluminum casting.
              The E46 has either a heavier, captive washer if the bolt is in oil contact, or a coated flange- head bolt, no washer at all, if it's dry.
              t
              • ForcedFirebird
                • Feb 2007
                • 8300
                The manifold nuts are 12mm hex to have extra clearance for a socket/wrench, and shouldn't be flanged if original. The springs washers do work, albeit not as good as a lock washer (or stover/nylox nut).
                LOL digger Perhaps if the ITB's are open, but it would probably be a wash if the airbox is used.
                john@m20guru.com
                Links:
                • digger
                  • Nov 2005
                  • 6211
                  that's easy, the air box should come off first ;)
                  • Vincenze
                    • Apr 2019
                    • 1045
                    The original ones were just nuts and washers.
                    It's better to unscrew the long stud using the two-nut method before the installation and screw it backlater. It will simplify the installation.
