335i performance stats...
  • JoeMadoo
    • 936
    Anyone have performance stats from their 335i? I'm just curious on how much fasters these cars are than the 325i/325e. I know the alpina B6 runs a 14.4 1/4 mile.
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
  • MrK
    • Jan 2006
    • 709
    I underwent a few informal 'tests' of how fast my car is after its M30 swap, and with a restrictive exhaust (but otherwise fine engine), I managed around 6.6 secs 0-60, and I received proof that when I repeatedly beat my friend's 2004 201bhp Type-R off the line every time.
    Hope that helped.
    This is your M20 on steroids:
    • bmw335isturbo
      • Mar 2006
      • 218
      with the chiped e28 3.5L in my 1988 325 chell with the getrag 265 and 2:93lsd I ran 13.8-14.0 nothing striped out of the car, But it took a few runs to get the shift points right and not spin the tires.
      1986 335is-1988 335ist -1991 335istsigpic
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        I have no idea what my 345i will do 0-60, but i've tried to do it and am looking around 4.5-5 seconds I think. I have 3.25 gears, so Getting to 60 is easy in 2nd gear and that's where I have the most pull.
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • euroshark
          • Apr 2006
          • 3491
          According to the Alpina B6 2.8 and B6 3.5 test articles I have, the 335i should be faster than an E30 M3, even with higher gearing. The m3s came with a 3.25LSD, while some of the Alpina cars got 2.93s or 2.79s (3.5 liter versions).
          One test I have has some numbers for the B6 2.8 (210bhp but far less torque than the 3.5): 6.5 seconds to 60 and 143mph top speed with a 3.45 differential.
          Another test I have has a ton of performance specs, I'll try to get them all in here:
          Curb weight: 2690lbs
          Displacement: 2788cc
          Horsepower: 210 @ 6100rpm
          Torque: 206 @ 5000rpm
          Final Drive: 3:45:1
          Tires: 195/50/16 Pirelli P7 (lol)
          0-60: 6.9 seconds (lack or torque from the 2.8 I guess)
          0-100: 17.2 seconds
          1/4 mile: 15.5 @ 95mph
          These are the numbers I have for the 2.8 liter cars, I'll post up what I have for the 3.5 liter cars in a minute.
            • 34830
            those #s would be way different today, since nobody is going to be using 195 width tires, and the tire compounds are way better than they were in the 80s. considering a stock 325i can do a low-mid 15 sec 1/4 mile on today's tires...
            • euroshark
              • Apr 2006
              • 3491
              Here we go, the good stuff.
              First B6S 3.5 road test numbers:
              Horsepower: 260hp @ 6000rpm
              Torque: 237ft/lbs @ 4000rpm
              Curb weight: 2904lbs
              0-60: 6.0 seconds
              0-100: 15.8 seconds
              1/4 mile: 14.4 seconds @ 96.3mph
              Top speed: 152mph (M3 body, might be close with a standard E30 body)
              Another test has these numbers:
              0-60: 5.9 seconds
              0-100: 15.6 seconds
              1/4 mile: 14.2 seconds @ 97mph
              Top speed: 155mph
              I think it's safe to say that most of the 335is on this board should be somewhere between the specs of the B6 2.8 and the B6 3.5, except for Franks turbo devil car which should destroy them both
              Obviously gearing is a big performance booster. I couldn't believe that the B6 3.5 had a 2.79 diff, that's crazy. With a 3.25 you could probably knock a ton off of those acceleration figures and still hit 150mph with the right sized tires.
              • euroshark
                • Apr 2006
                • 3491
                Yeah, thats pretty much what I was getting at with the other post I put up. With better gearing and tires all of our cars should get close to the B6 3.5 numbers even though most of them are not making 260hp. That ~50hp disadvantage that most of the B35 guys have, and the ~65hp disadvantage that the B34 guys have can mostly be made up with gearing, which is why I am guessing that the performance figures will land somewhere between the B6 2.8 and B6 3.5.
                • JoeMadoo
                  • 936
                  Alpina didnt have a performance chip back then did they?
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • euroshark
                    • Apr 2006
                    • 3491
                    I believe they did make some alterations to the ECU for different timing curves and whatnot. I'm 100% sure that anyone with a B35 can hit 260hp with headers, a chip and a mild cam upgrade.
                    • E30/M30
                      • 224
                      I did a 14.4 1/4 in my Touring last year, but it could be a bit quicker as it weighs 2860lbs or 1300kgs, mind i could do with losing a few pounds too ! :-)
                      Should be better this year once it's been mapped.
                      • george graves
                        • 19992
                        Euroshark, you seem to know quite a bit about the m30 breed. Do you have a recomended chip maker? EAT seems to be what the e34 guys like - do you have any advice?
                        Originally posted by Matt-B
                        • euroshark
                          • Apr 2006
                          • 3491
                          D'Sylva is what I hear the E28 guys raving about in their B34s and swapped B35 cars. Apparently on the B34 a D'Sylva chip gains you like 25hp. I don't know the numbers for the B35, but I can only assume its a similar gain because the head flows much better, the cam is hotter, and it's got higher compression. I don' have any first hand experience because all my cars have oooooooold M30s with ooooooooold electronics!
                          Edit: I'm bringing home another Euro 635CSi this month or early next month. Euro motors FTW!!
                          • Jean
                            • 18228
                            0-60: 6.0 seconds
                            0-100: 15.8 seconds
                            0-60: 5.9 seconds
                            0-100: 15.6 seconds
                            Top speed: 155mph
                            How accurate is this weight figure (Curb weight: 2904lbs) for an e30 ?
                            • Garageaholic
                              • Dec 2005
                              • 5204
                              I think that the weight figure is actually a tiny bit higher. you have the bigger M30 engine and the tranny is also heavier...
                              It depends if you want AC also, not sure if that includes the curb weight.
                              Recent Rebranding!!
                              E30 SM62/S62
                              E30 M60 V8
                              E30 M30 Big 6!
