Building an M42
  • I8UR911
    • Jan 2013
    • 260
    #61
    Originally posted by Dj Buttchug
    total cost spent on engine parts already?
    I'll have roughly $3k-$3500 into the motor when done.
    Sounds like a lot, but it'll essentially be a brand new motor.....new bearings, seals, pistons, rings, gaskets, injectors are rebuilt, valve springs are new, etc.
    IMO a much better value than buying a used, unknown history, M5x/S5x.
    Sent from my XT907 using Tapatalk 2
    • I8UR911
      • Jan 2013
      • 260
      #62
      RobertC thanks for the tips. I will definitely keep those items on the "short list". I'll do any of these minor replacements to ensure that all these money isn't blown (no pun intended).
      • Dj Buttchug
        • Jun 2010
        • 7667
        #63
        figured as thats about what I have into mine. GL with this build. will be watching.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • totheredline
          • Jun 2013
          • 762
          #64
          what is this I hear that euro s50 solid lifters will fit in m42 cam trays?
          = Heidi 1988 325 -> 335i. 7200rpm built M30
          • bmwman91
            • Oct 2004
            • 3134
            #65
            You can try emailing Metric Mechanic to ask which lifters to use. I'd be wary of solid ones because you need to manually adjust them regularly. MM stuck M/S5x hydraulic lifters of some sort in mine, and they are supposed to be the lightest 35mm ones that you can put in there (MUCH smaller oil reservoir in the lifter than the stock ones). I just can't remember where they were from.
            If you want to REALLY go light, you can actually retrofit the smaller diameter S50 lifters and cam trays into an M42.
            The thing is that high lift cams + small directly actuated bucket lifters can = chewed up cam lobes. You absolutely MUST run a high quality synthetic oil with high levels of ZDDP. Mobil 1 15W-50 and Castrol 10W-60 TWS are the only ones that I can really recommend, and they were they only two that did well in MM's oil tests. It complicates things for break-in when you are supposed to use dino oil, but a lot of people have seated their rings fine with synthetic I think.
            Transaction Feedback: LINK
            • wazzu70
              • Jan 2005
              • 1143
              #66
              IIRC the Euro S50 solid buckets are too small of a diameter to work.
              There is an "updated" lifter for the M5x family that fits our cam trays and is lighter but I cannot recall the correct dates off the top of my head.
              IMO, going with a modified cam tray to fit the smaller M5x hydraulic lifters is the best route for most people unless the car is strictly a race car. With solid lifters you really need to use a cam profile made for them or else you dont see much benefit.
              Upgrading the valve springs and going with the smaller lifters is a great combo for most available cam profiles.
              -Nick
              M42 on VEMS
              • MF DOOM
                • Apr 2012
                • 944
                #67
                Call Jim at MM. He'll answer any question you have with GREAT detail. Just make sure you have time. My calls usually stretch to an hour+. IIRC, they use a stiffer internal spring on their m42 hydraulic lifters, among other things. Theyre good for 7700+rpm. What more do you want?
                bmwman91, you have a factory intake and tb on your car, correct? Did MM modify it in anyway?
                EDIT: Just looked at their m42 booklet and saw the pulse chamber.
                • totheredline
                  • Jun 2013
                  • 762
                  #68
                  This thread is interesting. http://www.r3vlimited.com/board/showthread.php?t=46060
                  Im really thinking about picking up an M42 for $300 at the junkyard and strip it down and dick with it a little and rebuild it for when I eventually find a decent 318is
                  • MF DOOM
                    • Apr 2012
                    • 944
                    #69
                    Theres nothing wrong with the factory harmonic balancer. Just a myth.
                    Any updates, I8UR911?
                    • bmwman91
                      • Oct 2004
                      • 3134
                      #70
                      Yup, got the PC intake. While I would like to just go ITB, I don't feel like swapping crap around every couple of years to pass SMOG. The whole idea behind my MM engine purchase was to get a big bump in power while having a relatively maintenance-free engine for the long term. The car has plenty of mid-range torque now, especially considering the fairly aggressive cams that are in there.
                      +1 on calling Jim. He's a good guy that likes to talk cars.
                      Also, for those considering the ~33mm lifters from the later model S50 engine, you NEED to run oil with high ZDDP content. Your cam lobes will be destroyed if you don't. High lift cams already have issues with the stock diameter lifters if you use the wrong oil, as I learned the hard way.
                      • Swanny
                        • Mar 2012
                        • 2834
                        #71
                        Awesome! My friend katfish is looking to do a pretty solid m42 build and I'll make sure he gets an eye on this thread.
                        Good things are happening in here!
                        Swanny!
                        SUCKERS.
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #72
                          That thread is full of a bunch of asshats who don't know what they are talking about!
                          The only person with any sense is e9nine
                          -Nick
                          M42 on VEMS
                          • bmwman91
                            • Oct 2004
                            • 3134
                            #73
                            Per Jim at MM, a built M42 can handle brief ventures to 9000RPM with hydraulic lifters and the stock harmonic balancer. I had them limit mine to 7700RPM in the software because I want to drive this thing for a LONG time. If you put in lighter valvetrain and bottom end components, and carefully select your valve springs to apply the minimum required pre-load, you can build a high revving M42 without solid lifters. I mean, you probably need to be even more careful about the spring pressure with solid ones, and you MUST get a custom cam profile intended for solid ones to use them effectively.
                            • decay
                              • 5637
                              #74
                              FWIW, the last smog guy i went to in December didn't even blink at my ITB setup; just made sure the required equipment was still there and dyno'd it.
                              the time before that, in 2010, was a "this is an M3, right? *wink*nudge*" kinda deal (though admittedly it took trying 4 shops).
                              so yeah, i understand not wanting to deal with it, but i think our cars are getting to the age where the techs don't necessarily know what's supposed to be there.
                              past:
                              1989 325is (learner shitbox)
                              1986 325e (turbo dorito)
                              1991 318ic (5-lug ITB)
                              1985 323i baur
                              current:
                              • bmwman91
                                • Oct 2004
                                • 3134
                                #75
                                Haha nice. I gotta find one of those shops. Honestly, it is retarded that CA does a visual inspection. Just run the exhaust sniffer, pressure test the gas cap and evap system. Done.
