Building an M42
  • wazzu70
    • Jan 2005
    • 1143
    #106
    I used the redline assembly lube on my engine when I put it together, but I have also used the generic auto store assembly lube too. I really don't think it matters too much honestly :) Just make sure you use something!
    Im watching your build with excitement. Cant wait to see the results.
    -Nick
    M42 on VEMS
    • I8UR911
      • Jan 2013
      • 260
      #107
      More progress today......
      Purty :-)
      Sent from my SCH-I535 using Tapatalk
      • I8UR911
        • Jan 2013
        • 260
        #108
        Top of pistons look good. Gasket surface looks good.
        A little more cleaning and time for reassembly :-)
        • I8UR911
          • Jan 2013
          • 260
          #109
          New head installed with VW lifters and Cat Cams. Button up timing in the next day our 2.
          • jwal
            • Apr 2014
            • 385
            #110
            Originally posted by I8UR911
            Update!
            M20 flywheel conversion finished. First impression = disappointment and waste of money. Didn't noticed much of a difference. There is A difference but not a big one. Maybe not enough driving yet?
            I don't mean to interrupt your thread, but I am looking into this mod myself. Do you still not think it is worth the money? What weight was your flywheel lightened to? I was thinking the stock m20 fly would be good at ~19 lbs. I don't like dropping too far from stock ~27 lbs.
            • I8UR911
              • Jan 2013
              • 260
              #111
              Flywheel conversion is good. My expectations were a little unrealistic. I was thinking my little M42 was going to rev like an F1 engine :-)
              • I8UR911
                • Jan 2013
                • 260
                #112
                More progress.......
                Top end assembled. Lots of work to do this weekend. Will continue to post pics throughout the weekend.
                • I8UR911
                  • Jan 2013
                  • 260
                  #113
                  Teaser pics :-)
                  • I8UR911
                    • Jan 2013
                    • 260
                    #114
                    Radiator installed with new coolant hoses. Dropped the lower oil pan expecting to find a bolt or 2 in the pan.... found nothing...... everything in tact :-)
                    Started to hook up fuel injectors and fuel rail to the throttle bodies just to find out that the fuel rail isn't a direct bolt on :-(
                    Hopefully progress continues today.
                    • I8UR911
                      • Jan 2013
                      • 260
                      #115
                      • I8UR911
                        • Jan 2013
                        • 260
                        #116
                        • bmwman91
                          • Oct 2004
                          • 3134
                          #117
                          Oh man, this is a hot f'ing build. Can't wait for some Youtube videos of this sucker running!
                          So. Excite.
                          Transaction Feedback: LINK
                          • wazzu70
                            • Jan 2005
                            • 1143
                            #118
                            ^ This x10
                            -Nick
                            M42 on VEMS
                            • DER E30
                              • Sep 2013
                              • 2349
                              #119
                              ETA on start?
                              -Christian
                              • I8UR911
                                • Jan 2013
                                • 260
                                #120
                                Originally posted by DER E30
                                ETA on start?
                                Will wire up the alpha-n control box Sunday (working Saturday). Welding up a new exhaust section to replace the catalytic converter tomorrow night. Tying up loose ends in the next few days. Hopefully will fire up this weekend....... we'll see :-)
