Random Data Plots - M42 Engine Parameters Stock vs 2.1L Stroker
  • bmwman91
    • Oct 2004
    • 3134
    #46
    OK, so on a whim I reinstalled the MAF conversion tonight. After seeing a few M42 + ITB videos on Youtube, that insane sound just made me want to work on the MAF a bit more since it (combined with the M30 air box) has a much meaner sound. Totally superficial, I know lol.
    Anyway, my 2 main gripes with it last time around were that the idle was occasionally a bit stumbly when the engine was warm, and there was a slight "dull" spot in the powerband between from ~2600RPM to ~3200RPM. Well, tonight the idle was buttery smooth and I didn't observe any stumbles. Maybe I forgot to tighten a hose clamp last time or something. Or, maybe I just need to give it more time and the stumble will return.
    What about the "dull" spot? My original theory was that the stock M42 air box had some resonance properties that worked really well with the intake system, and that using the M30 air box was breaking that. However, a big oversight on my part was that my data logs from my original engine were with a MAF+M42 air box, and the "bump" in air flow in the 2500-3500RPM range was not at all present when the MAF was in use. That is a big indication that the "bump" in air flow is due to some property of the VAM which makes it over-report the air flow due to resonance.
    This leads me to believe that the M42 VAM (AFM) is actually putting out an artificially high voltage in that range, probably because the intake resonances in that range (which are significant) are causing the flapper door to open more than it would with a steady air flow. Since BMW most certainly would have known about this, they tuned the fuel maps to take this into account, and all of the various aftermarket chip makers have too. Now, when I put the MAF in there, because of how I designed the converter, the output is going to be VERY accurate to the actual intake air flow. In this case, the DME will see a lower voltage than it would if the AFM was connected, which causes it to run a bit leaner. I am still not 100% clear on what the DME does at WOT: I know it goes open-loop at some point (dependent on either RPM and/or throttle position), but it is my belief that it is also using the VAM voltage for load calculation, so a lower input voltage at WOT would mean less fuel is injected.
    Revisiting this plot:
    Notice that at around 3000RPM the AFR with the VAM is ~13.0 and the AFR with the MAF is ~13.5. Now, here's where people on here with some tuning experience might be of assistance. Do you think that this slight leaning in AFR could be why my butt-dyno feels like there is a little less power in that range (2500-3500RPM)? My second-gear pulls with both sensors seem to indicate that performance is equal, although they were aligned to start at 3000RPM so maybe that is masking some small difference. Actually, things are slightly leaner all-around with the MAF versus the VAM, which is possibly because the VAM is slightly more inclined to over-report air flow due to how the flapper door reacts to the intake pulses at all RPMs.
    I am thinking of reinstalling the data logger system to do more investigation, so I will post more if I do that.
    Transaction Feedback: LINK
    • DER E30
      • Sep 2013
      • 2349
      #47
      Interesting data!
      -Christian
      • digger
        • Nov 2005
        • 6190
        #48
        What's cams do mm use in these things? Did they give a full camcard ?
        • bmwman91
          • Oct 2004
          • 3134
          #49
          So, I revisited the data that I took this summer and put together another plot. This time I displayed the air flow rates and AFR's from all 4 runs, with RPM as the X-axis. The most obvious thing is that the first run from each sensor is MUCH richer than the second run. Remember that I unplugged/reset the Motronic before swapping sensors, so it was re-learning all of the short- and long-term fuel trim settings. There was ~5 minutes of run-time after reconnecting the Motronic and doing the first pull, and then another 5 minutes after that until the second pull. Since the second pull is leaner, a big factor must be in allowing the Motronic to adjust based on run-time data from the O2 sensor.
          OK. Here's the plan. I reinstalled the datalogger hardware this evening. I am to put at least 100 miles on this thing so that the Motronic will (hopefully) be fully adjusted, and then I will log some more 2nd gear pulls with the MAF (which is on there now). I will probably also log the idle and some part-throttle driving just for the sake of completeness. Thereafter, the VAM will get stuffed back in, the Motronic reset and after 100+ miles I will do the same measurements with it. Does anyone here know how many hours of operation it generally takes for the Motronic to establish its long-term fuel trim values?
          Here is the plot of data that I mentioned at the start of this post.
          The green and orange lines are the first runs after resetting the Motronic with the engine at full operating temperature (green is MAF, orange is VAM). Similarly, the blue and yellow lines are the second runs, at which point the Motornic has had 10-15 minutes of operation at full operating temperature (blue is MAF, yellow is VAM).
          You will notice that the first runs are much richer than the second ones. My main interest here is the blue and yellow lines below 3500RPM. On these second runs, the MAF runs a lot leaner than the VAM (AFR of 15.0 vs 13.5). This corresponds exactly to the big "bump" in air flow signal coming from the VAM in that range. Someone correct me if I am wrong, but an AFR of 15.0 at WOT is not a recipe for power, and I think that this must be why I "feel the bog" in that range.
          I have no reason to believe that the VAM+stock air box is magically flowing that much more air in that range, and as noted in a prior post, I think that it is a resonance effect interacting with the VAM's door which causes an artificially high output voltage from the VAM sensor, which just about any M42 tune will have factored in. Since the MAF accurately reports air flow here, it ends up passing through the tuning tables and leads to leaner running since the table tuned with the assumption that air flow is over-reported in this range. I do seem to recall hearing unverified information over the years that indicates that the Motronic runs off of the 2D maps below 4000RPM regardless of throttle position, which means that it is using the air flow voltage as a primary load signal, and then above 4000RPM if the throttle is open more than 80% it switches to 1D maps for faster response (in which case the air flow signal is largely ignored). From looking at how well the AFR's match above 4000RPM, this seems like it could be the case.
          The initial implications here are that there may very well be no way that the M42 can ever have a "perfect" plug-and-play MAF conversion. You would either need a chip with a tune that is not based on a big bump in voltage from 2500-3500RPM, or you would need a MAF converter that taps into the crank position sensor and throttle potentiometer...in which case it really can't be called plug-and-play anymore since you are cutting wires. Maybe I could work an FFT algorithm in to the converter that basically allows the RPM to be read from the pulse frequency of the raw MAF signal, and then a correction curve is applied which mimics the VAM's goofy signal bump from 2500-3500RPM.
          Phew. That is a lot of text. At this point, I know one thing for certain. It is time to find a tuner that can work with M1.7 and get a custom tune for this engine with the MAF installed.
          For a little bit of extra fun, this link has a ~11,000 pixel wide plot. This one has the raw MAF output signal on it, and it is super duper wide which allows you to see how ugly the signal is. Every single intake valve opening is clearly visible! Remember, in this plot the horizontal axis is in milliseconds, not RPM.
          • eur04lif3
            • Jan 2009
            • 756
            #50
            I can tell your an engineer, I love reading your findings. Thanks for your contribution.
            Off topic, if you had to do it all over again, would you go MM? Considering costs vs. gains.
            My engine is getting up there in miles and I'm expecting any day to have to make a choice, rebuild to stock or upgrade.
            • bmwman91
              • Oct 2004
              • 3134
              #51
              Thanks for the kind words.
              Would I go with MM again? Hard to say. On the one hand, their customer service is excellent, they are fanatics about what they do and they deliver a quality product. On the other hand, they are $$$ and a built M42 from them will take as long as building one yourself with a competent local shop (I initially figured that MM would be faster, but they don't get many M42 orders so everything had to be special ordered for the build). I'd say that if there is a highly competent builder local to you and you don't depend on the car as a DD, then you might save a few $thousand that way. MM has extensive experience with BMW head work and they developed their own cam profiles, so I think that they might have an advantage over an engine shop that does not specialize in BMW, particularly older ones.
              Either way, parts will cost you an arm and a leg. The M47 crank is like $1300 these days (new), and I bet that parts alone for a 2.1L high compression build will cost at least $4000. The machine labor will probably be another $2000-3000. So, you could save a couple $thousand by assembling most or all of it yourself. You would also want to look into using the M44 timing case with its larger oil pump and more reliable design, although you would need a crank position sensor bracket.
              The main point is that getting power from the M42 is expensive.
              • varg
                Florida Turbo Man
                • May 2014
                • 3425
                #52
                Originally posted by bmwman91
                The main point is that getting power from the NA M42 is expensive.
                Fixed ;)
                This thread delivers. Lots of neat info.
                IG @turbovarg
                '91 318is, M20 turbo
                • bmwman91
                  • Oct 2004
                  • 3134
                  #53
                  Slight resurrection...
                  I did a little more data logging today now that I am 100% certain that the long term fuel trim (LTFT) is fully in place. Here is a comparison between 2 of the runs I did today, and a couple from a year ago shortly after I reset the ECU.
                  What's what?
                  MAF 1 and MAF 2 lines are from today's WOT pulls in 2nd gear, and I last reset the ECU ~4 months ago during an audio project.
                  MAF 3 is a 2nd gear WOT pull from about 5 minutes after resetting the ECU.
                  MAF 4 is a 2nd gear WOT pull from about 10 minutes after resetting the ECU.
                  So, I think that the AFR's look fairly good, except in the 2500 - 3500 RPM range. The LTFT leans things out even more in that range. I am amazed that I don't have issues with knock since the engine has 11.5:1 compression and we only get 91 octane around here. It must be somewhat of a testament to Metric Mechanic's head and piston developments.
                  Anyway, I am going to try to work with MarkD to get a customized map that enriches things in that range a little so that I don't get that dead spot in the powerband anymore. What are everyone's thoughts on the rest of the AFR's throughout the powerband?
                  • digger
                    • Nov 2005
                    • 6190
                    #54
                    why not a MS or other aftermarket system? it make s a big difference to be able run the fuel and timing the engine needs as compared to generic maps. The MarkD chip for my MM was not even close to being optimal
                    • bmwman91
                      • Oct 2004
                      • 3134
                      #55
                      I am planning to go with MS3Pro eventually. That is a big long-term project and I am planning to do it in a plug-n-play style with the factory harness, plus a few improvements (sequential injection, MAF support, maybe ignition coils with integrated drivers). In the meantime, I want to get this thing dialed in more properly and enjoy it before ripping things apart again!
                      How much power did you gain with a custom tune versus the stock one provided by MM/MarkD?
                      • digger
                        • Nov 2005
                        • 6190
                        #56
                        about 5% in various chunks of the powerband IIRC, i dont have good records from back then since is was 2006/07. with SMOG and all that shit it probably makes it a little harder perhaps
                        • bmwman91
                          • Oct 2004
                          • 3134
                          #57
                          Yeah, SMOG regulations in my state make things a little more of a pain, especially NOx when it comes to ignition timing tweaks. It also means that the engine has to look mostly stock (since I want to avoid having to swap manifolds for the test every 2 years!).
                          Anyway, I'll see if I can get MarkD to tweak the WOT fuel table in the 2500-3500RPM range to enrich things a little. The maps were purposely leaned out there because the stock AFM has a resonance there and over-reports air flow in that range with large throttle openings (whereas my MAF does not do this and remains accurate).
                          • digger
                            • Nov 2005
                            • 6190
                            #58
                            S
                            why does the LTFT have such quick and large effect? are you using much larger injectors than are actually needed?
                            what cam centrelines and duration are being used?
                            • bmwman91
                              • Oct 2004
                              • 3134
                              #59
                              Not sure why the LTFT indicates that the time-zero fueling is way too rich. This engine does have 24# injectors (vs stock 21#) and a custom chip. MM worked with MarkD on the software, so I would imagine that the fuel tables are at least halfway decent.
                              The cams are 272deg intake and 258deg exhaust (0.125mm lift). Peak lift is 11.40mm intake and 11.15mm exhaust.
                              • digger
                                • Nov 2005
                                • 6190
                                #60
                                are those the injectors that MarkD recommends with that chip?
                                what centrelines are the cams installed on?
