m42 serpentine belt conversion
  • uturn
    • Dec 2010
    • 1007
    Who else here has done this or attempted it?
    I'm lazy so this will take the guesswork out of tensioning the belt and getting it ready in case I buy a DASC.
    Went to the local junkyard to pull the timing cover to upgrade to the deflection plate. Got all the accessories... power steering pump, a/c compressor, alternator, harmonic balancer and tensioner brackets. Was unable to get the crank nut off so ordering the crank holder tool (auto tranny so was unable to pin the flywheel). Will have to go back for that at a later date. Cost so far with taxes, fees, and core charges. $190.00.
    Future cost...
    No belts and they wanted to charge me for the idle pulleys so I gave those back. 2x new belts $27, 3x idle pulleys oem $130. Freon?
  • djmossm42
    • Jul 2012
    • 687
    Haven't done it but its on my list of things to do. Following this to see your progress.
    Sent from my MI 4LTE using Tapatalk
    Wheelwell
    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
    LED Bulb Thread
    R6 LED Review
    • DER E30
      • Sep 2013
      • 2349
      Interesting, Would that free up some parasitic drag? I'm gonna do the late timing cover at some point, this might be a good upgrade for when I do that.
      -Christian
      • djmossm42
        • Jul 2012
        • 687
        After thinking about it, I did meet a guy with a 2002 that swapped in an M42. He made the switch so he use the Mini supercharger bolted to it!!! 😁
        This kit here!! http://www.gkdsportscars.com/supercharger-kit.html
        Wheelwell
        LED Bulb Thread
        R6 LED Review
        • Dj Buttchug
          • Jun 2010
          • 7688
          This is on my list of to-do's. In order to do the job you need everything from the front of an m44. This includes different alternator pulley, bracket and tensioner.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • TobyB
            • 5296
            Doesn't the late E36 M42 have a serpentine already?
            Edit- I looked, and it does. Also no funky sprocket inside the timing chain cover.
            t
            • bmwman91
              • Oct 2004
              • 3134
              Hmm, I guess that I would need a custom belt since I don't have AC anymore. I have thought about this a few times, and in some ways I like the original multiple-belt setup. There was an incident where the end seals on my steering rack blew out (as I was parking for a dinner date with the woman who is now my wife lol), so I just grabbed some heavy dykes from the trunk and chopped the PS belt off so the pump would not run dry.
              Transaction Feedback: LINK
              • Balleristic31
                • Aug 2009
                • 4198
                I've thought about doing this as well but have a hard time seeing a huge advantage unless you were to be supercharging. Aren't the serp belt pulleys heavier, thus adding parasitic drag to the motor? Obviously the set up would be a bit more modern and robust but I've only had 1 alternator belt failure in like 7 years (my fault anyway)
                Edit: I think it's worth noting I don't run power steering and have the whole system deleted
                -NICK
                • TobyB
                  • 5296
                  AC has its own v- belt on the later E36. Everything else loops around the serpentine, including
                  the power steering...
                  t
