M42 Full Rebuild now won't start
  • theTBLACK
    • Jan 2013
    • 156
    #31
    Originally posted by bmwman91
    Spark verified...did you remove a plug, leave it connected and see the spark? I'd think that you'd get something, at least a misfire, if you spray ether into the intake while cranking if you had spark.
    Could you have reversed the fuel feed lines? I think that if you connect them to the rail backwards you won't get any flow since the regulator doesn't really allow backwards flow.
    Did you remove or disconnect the ECU at any point? Maybe it is not plugged in, or you forgot to install a chip? If you replaced the DME, it is entirely possible that there is no chip in it unless you opened it and checked.
    1. Spark is verified
    2. Fuel feed lines are correct.
    3. I did replace the ECU. It is plugged in. I haven't looked inside of it though.
    This morning when I went to turn it on, while it was cranking, the tach jumps all over the place. It is so strange.
    Founder
    TheDirtyThirty
    instagram.com/thedirtythirty
    • bmwman91
      • Oct 2004
      • 3134
      #32
      Yeah crack the Motronic and see if there's a chip, and that it's fully seated.
      Transaction Feedback: LINK
      • Boris3
        • Apr 2007
        • 444
        #33
        Might not need to crack the ECU since you had already tried swapping it with no change according to an earlier post, no?
        Check the wiring to the blue temp sensor especially the condition of the wire before the plug end. This caused a no start situation (crank, spark and fuel but no start) for a friend of mine's e30 M3. Different engine I know but.... Someone had done a bad DIY fix that gave out.
        1990 325: track/racecar
        2003 330xi; project car
        2004 330i zhp: civilized car
        • Dj Buttchug
          • Jun 2010
          • 7686
          #34
          OP are you sure the timing is set on the TDC mark on the Crank (not the notch) This is a mistake that some make.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • theTBLACK
            • Jan 2013
            • 156
            #35
            Double checked timing and it's correct.
            Went through everything again, rechecked the timing. Checked continuity to the dme, all the wire harness everything. Still have spark, fuel, etc and still no dice.
            Here is a video of it cranking - check out the tach
            Founder
            TheDirtyThirty
            • Dj Buttchug
              • Jun 2010
              • 7686
              #36
              wtf. CPS no signal? im almost out of ideas...
              Ig:ryno_pzk
              • theTBLACK
                • Jan 2013
                • 156
                #37
                CPS replaced and good signal. I'm stumped.
                Founder
                TheDirtyThirty
                • uturn
                  • Dec 2010
                  • 1005
                  #38
                  Is the engine ground wire attached?
                  • nk1221
                    • Feb 2015
                    • 56
                    #39
                    Doesn't the cluster get the RPM readings from the crank position sensor? Maybe it's a faulty sensor, have you tried swapping it out with a different one?
                    Sent from my SCH-R970 using Tapatalk
                    • theTBLACK
                      • Jan 2013
                      • 156
                      #40
                      Yes it is, but I'll double check!
                      Founder
                      TheDirtyThirty
                      • theTBLACK
                        • Jan 2013
                        • 156
                        #41
                        I swapped it for a new one - perhaps the new one was faulty?
                        Founder
                        TheDirtyThirty
                        • nk1221
                          • Feb 2015
                          • 56
                          #42
                          That's what I was thinking! At least trying a different one will take that off the list of possible things.
                          • mr.vang
                            • 4371
                            #43
                            Unplugged the afm harness and crank it. See if that makes any difference in cranking.
                            • theTBLACK
                              • Jan 2013
                              • 156
                              #44
                              I'll try the original and go from there.
                              Founder
                              TheDirtyThirty
                              • theTBLACK
                                • Jan 2013
                                • 156
                                #45
                                Okay will do!
                                Founder
                                TheDirtyThirty
