M42 Timing chain guide rails
  • jaredmac11
    • Sep 2007
    • 253
    Im in the middle of a rebuild, engine has 150k miles.
    I opened up the timing case and the sprockets look good. Teeth do not look worn, etc.
    However, 2 of the chain guide rails are a bit worn, one has a lot of microfractures and likely needs to be replaced.
    Here are photos of the 2.
    The timing tensioner rail looks mostly ok. It has 2 worn stripes down the middle and a small patch of microfractures, however, the other timing guide rail likely needs to be replaced.
    The problem is, I cant find these parts at a reasonable rate anywhere. I'd be spending $300 for both of these together, which is literally a third of what I've spent on this project. For plastic rails.
    Bavauto, pelicanparts, ECStuning are all no help. There has to be an OEM-like make for these... right?
    I did note the guide rail has 2 part numbers, 1 is significantly lower cost.
    11311247470 - $65
    11311247483 - $200+
    If I were to replace the entire timing case, I'd be looking at easily $750 worth of parts, or the cost of the entire engine.
  • Gerta
    • Sep 2009
    • 2119
    Contact Blunttech - steve@blunttech.com.
    He can advise you on the best route to go.
    Parts Collector and Former Houndstooth interior junkie.
    • AndrewBird
      The Mad Scientist
      • 11898
      That's just kinda the way it is with M42s. Why these parts are so expensive, I don't know.
      • fresh_TD
        • Aug 2013
        • 2457
        I spent about $700 for all new timing components and gaskets for my M42 build. Through FCP euro. The timing components are not cheap for these emgines
        '91 318i (Alpine) - daily
        '88 325ix (Zinno) - drive here and there!
        • varg
          Florida Turbo Man
          • May 2014
          • 3440
          M42s are just expensive engines, the more complex engines get the more expensive they are to refresh. Try pricing out a full rebuild for M42 vs M20, BTDT, you could build a 2.8 stroker M20 for the cost of a stock M42.
          IG @turbovarg
          '91 318is, M20 turbo
          • jaredmac11
            • Sep 2007
            • 253
            It has been more expensive than I originally thought, unfortunately. I figured 4 cylinders 1/3 less in costs but since all of these timing components are pretty dang expensive and blow my budget up.
            • TobyB
              • 5298
              I think it's partly because they really didn't sell many M42's. I haven't found any
              aftermarket timing parts either. $200 for the E36 slider? That just... burns...
              t
              • Lmg
                • Apr 2013
                • 36
                Does anyone know if we can use the m44 timing chain guide in our m42? Pelican parts lists the m42 guide at $240 dollars and it's supposed to work with 96-99
                Z3 1.9l m44. Rockauto.com has an identical timing guide for a z3 1.9l for $69. Only slight difference is the upper bolt.
                • jaredmac11
                  • Sep 2007
                  • 253
                  Yes, you can. I did. You need to get the bolts and spacer/cylinder for the corresponding rail but they work. Just hop on to RealOEM.
                  http://www.realoem.com/bmw/enUS/show...diagId=11_6106
                  $69!? I wish I had that option when I bought mine. Nearly paid double and I thought I was getting a deal. Its a damn ripoff how much these rails are.
                  Edit: Just to note, I have the LATE M42 timing case, which is different than your early but Im fairly sure you can. It should be the same, but caveat emptor. Since I didnt do it for the early, I cant 100% verify but its the same part numbers and everything for both rails on the early and late models.
                  • Lmg
                    • Apr 2013
                    • 36
                    Just want to confirm. My buddy and I successfully replaced the m42 timing rail (metal & plastic) with the beck arnley z3 1.9 year #0241997(plastic). Everything lined up perfect and his car is now running quiet and smooth again. Note two things, Z3 rail is more beefy, & it Was missing the set screw which is the cylindrical adjuster with two notches on the surface facing forward. If you're not sure what I'm referring to look up the most current (and most expensive) rail. The "set screw" comes on the $248 dollar part. Rock auto has the best price @ $69.99 but you will need to get that adjuster from Bmw (can't find the pn). Napa is the next best price @ $138 for the older part number : 1131173447. Hope this helps! Cheers-
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      I just spent 1200 on doing a cooling system and timing system. Its not cheap but OE parts are the way to go
                      1991 318i 4dr slick top
                      Mtech 2 turbo restoration
                      • downforce22
                        • Aug 2009
                        • 3193
                        Interesting info here: With oem parts you know you are getting another 150k out of the engine, but are there really that many catastrophic m42 engine failures due to timing components?
                        I suppose most cars are probably junked when it happens rather than reported and repaired.
                        • sonomabimmers
                          • Dec 2015
                          • 802
                          I know three people it has happened to personally......and i don't know that many people with e30s
                          i love bmws
                          • bmwman91
                            • Oct 2004
                            • 3134
                            ...but are there really that many catastrophic m42 engine failures due to timing components?
                            Yes. It happened to me. The stupid deflector sprocket snapped off of the timing case. The casting must have cracked when the original sprocket blew its bearing, but I did not notice, so I wasted $160 on a new sprocket only to have the engine take a dump on me a year later.
                            At this point, my recommendation to ALL E30 M42 owners is to swap in the 1994-1995 M42 timing case. It eliminates the costly and failure-prone deflector sprocket for a plastic guide. The late M42 timing case is more or less a direct bolt-in. Just check RealOEM for the late E36 M42 for the proper gaskets and such since (at least) the case-to-block gasket differs. While you are doing it, also replace all of the oil pressure relief valve parts (spring, plunger, etc) since the original E30 design was also prone to major failures, and an updated set of parts was issued in the E36. That right there takes care of 2 out of 3 of the M42's most common faults.
                            The 3rd fault is the half-shell thrust bearing on the crank. Basically, never ever start your car with the clutch pedal pressed down because you are putting 300lbs+ of force onto that small thrust face with zero oil pressure. The ideal fix is to install two thrust shells for full 360 degree coverage, but that is a major project in itself.
                            Transaction Feedback: LINK
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3440
                              Yes. The bottom end is pretty strong, but sprocket failures, idler failures, rails falling apart, all pretty common if you read around. Usually it makes a bunch of noise before it eats itself.
                              IG @turbovarg
