M42 Head Gasket Blown, Project Thread
  • bmwman91
    • Oct 2004
    • 3134
    #91
    Well, the injectors are going off to Sssquid for refurb. Their customer service is awesome and they are going to get them flowing for me at no charge, despite these being stuck probably being my fault for letting them sit for so long.
    I did try to free them myself with no luck. Applying 12 & 20V pulses, and smacking them on the workbench, did not help. I also clamped some 15mm PCV hose into the outlet side, poured in some injector cleaner and then pressurized it to 45PSI with my air compressor while pulsing & smacking them, but even trying to back-flow them like that made no difference. Whatever is in E85 and/or the Lucas stuff certianly seems to turn to cement after a few months! I don't want to risk really messing these up, so I will let the professionals work on them. Considering this project started in November...what is another week of delay, really? Plus, now I know that every single other sensor and actuator is working properly since I tested it all lol.
    I promise to get pics up at some point. I am taking them as I go, but don't have time to edit & upload right now.
    Transaction Feedback: LINK
    • digger
      • Nov 2005
      • 6191
      #92
      curious why E85 was used?
      • bmwman91
        • Oct 2004
        • 3134
        #93
        I'd guess E85 because alcohol is a decent solvent for petroleum gunk, and it is a hell of a lot less expensive per gallon than lab-grade alcohol. Granted, the Lucas cleaner is not all that cheap, and I am not sure what the mix ratio is, but I trust Sssquid to know what they are doing. I have spoken to a few more people I know who are into cars and apparently I am not the only one who has had injectors glue themselves shut after sitting around for too long. One theory is that it is actually a small formation of surface rust due to ambient humidity that causes them to stick. In my case I doubt it since they were in hot-barred plastic bags, but whatever. I am not all that worried.
        • bmwman91
          • Oct 2004
          • 3134
          #94
          So I got it fired up today. Mechanically, it runs correctly and does not make any odd noises or give any other indication of a major problem. However, it is not currently running correctly. When I started it, it immediately wanted to idle at ~2000RPM. After doing that for a couple of minutes, it would drop to ~1500RPM for a moment, rev back to ~2000RPM and then just keep quickly oscillating like that.
          I think that I have ruled-out the AFM (MAF conversion) and TPS since disconnecting those did not really make a difference (the engine would stumble briefly and then resume the previous behavior). I had checked the ICV a month or so ago and it was moving freely when 12V was applied, so I don't think it is stuck open, and I will check again tomorrow. When the engine is revving up to 2000RPM, the AFM output does rise to ~2.25V, which means that metered air is getting in somehow...so it is not a vacuum leak at least. I think that the only sources of a leak like that could be either the ICV, or the TB itself.
          Back when I got a spare TB and cleaned it, I used acetone. Some of you may have noticed that the M42 TB (and maybe other engines too?) have a slick gray coating that looks like it was dripped or smeared into the bore. Whatever it is, acetone dissolves it, and when I was done cleaning the TB I could see slivers of light around the perimeter of the throttle plates when I held it up to a light. So, I guess the gray stuff was (maybe?) a sealant intended to produce a zero-clearance fit between the throttle plates and bores. When I noticed the newly created gaps, I wondered if it would be enough to cause enough air to leak by that it might cause issues at idle, but the gap around the perimeter was only ~0.002" (0.05mm) based on checking with some feeler gauges so I figured it would be fine.
          I believe that the engine changed from a steady 2000RPM idle to oscillating due to either a switch from open-loop to closed-loop idle control, or some other switch in the software based on coolant temperature. I only ran the engine for 2-3 minutes since I don't want to get it fully warmed up until I am ready to drive it to get the piston rings seated.
          Anyway, has anyone else had experiences with leaky throttle bodies? Is a gap that small enough to get the engine to idle at 2000RPM?
          • ForcedFirebird
            • Feb 2007
            • 8300
            #95
            Oscillations indicate a leak between the AFM (MAF) and throttle body. Being the size the BMW IAC is, those little cracks are tiny in comparison, so doubtful that is the issue.
            When the ECU has unmetered air going around it, it gets "confused" and rolls the idle trying to make corrections for the "mystery" air that is causing a high idle. So it dips too much, then rises too much, essentially trying to chase it's own tail.
            john@m20guru.com
            Links:
            • bmwman91
              • Oct 2004
              • 3134
              #96
              I see. Yeah I had PMed Jordan to ask about the gray coating and he said that it was basically insignificant. So, maybe I do indeed have a stuck ICV, or some sort of big vacuum leak elsewhere. Time to poke around in there some more I guess!
              • bmwman91
                • Oct 2004
                • 3134
                #97
                Update. Yeah the TB is a non issue. The one thing that I had assumed could not be the issue, turned out to be the issue lol. It is the ICV.
                The car was running fine on it 7 months ago, and I have no idea how sitting for that long could have caused it to die. I did blast it out with brake cleaner, but I doubt that hurt it. Basically, it operates smoothly and does not stick. When I hook it up to my adjustable power supply, the following seems to be the case:
                1.7-2V: vane starts to move
                3.5V: vane is fully closed
                7V: vane is fully open
                I am not sure what the normal behavior is supposed to be, but it sort of seems like maybe the return spring is weakened or broken. Either that or there is something going on with the ECU or tune. I got the oscilloscope on the ICV terminals while it was running and the PWM signal is present, so it is not like the signal is stuck ON. I'll try a used ICV to see if that helps, or maybe suck it up and buy a new one.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #98
                  Yeah the IAC is just and electric motor and the ECU uses PWM to modulate the opening. Typically with key on, you can feel the IAC vibrating. When off or disconnected, if you shake it (in a twist motion) you should feel the flapper rocking back/forth and hitting the return spring(s).
                  Now you have me curious, never took one apart to see the mystery smoke inside.
                  john@m20guru.com
                  Links:
                  • bmwman91
                    • Oct 2004
                    • 3134
                    #99
                    The flapper was moving around when I shook it, so it at least was not stuck. There did seem to be some hysteresis in the motion though as I varied the input voltage up and down. I took the thing apart yesterday, which requires destroying it, and it is a very simple device. There was a little rust inside and a tiny bit of build-up in places that carb cleaner may not have been able to get to, so perhaps that was causing it to get stuck further open than it should.
                    Anyway, once I get the one I bought from you we'll see if it fixes the issue. Fingers crossed!
                    • bmwman91
                      • Oct 2004
                      • 3134
                      #100
                      OK, I have finally found the cause of my high idle. After replacing the ICV (got one from roguetoaster which was in better shape than my old one) and swapping in a clean throttle body I got a hold of, there was no difference at all. I also tried swapping a spare ECU in to no avail. What DID work was swapping a slightly older revision of my custom tune in. Although it ran rich (old tune was for 24# injectors, current ones are 28#), it did idle at the correct RPM. The latest tune from Sssquid is a little bit "experimental" I think, so they will get me a corrected one soon, since I just emailed them with my findings. It must be that some bytes related to the ICV PWM signal got nuked since it was indeed the case that the ECU was opening it too much (air flow signal should be 1-1.5V at idle normally, and I was seeing 2.25V meaning that too much air was being allowed in to the engine NOT as a vacuum leak).
                      Anyway, I promise I will get all sorts of pictures up at some point relatively soon lol. I've been busy with work and dicking around with getting this thing running correctly lol.
                      • digger
                        • Nov 2005
                        • 6191
                        #101
                        something something aftermarket ECU you'll wonder why you never did it earlier. easier to troubleshoot and you can retune it youself and not rely on anyone else
                        • bmwman91
                          • Oct 2004
                          • 3134
                          #102
                          Ha, yes that is the planned next step. It'll likely be an AEM Infinity 506. But I'd like to drive and enjoy this thing for at least a few months first!
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #103
                            As crafty as you are, surprised you don't just get an emulator and tune it yourself.
                            john@m20guru.com
                            Links:
                            • bmwman91
                              • Oct 2004
                              • 3134
                              #104
                              Nah, after working with Sssquid for a while now, I know I will get much better results from someone who has thousands of hours of experience with tuning. And, Motronic is enough of a pain in the ass that a stand-alone solution is where I'd go if I really wanted to have proper control of things.
                              Speaking of having control of things, the damn car still does not run properly. It is perhaps not a software thing after all. I am going to lay out what all I did today and hope that the good folks on here can help me figure this one out, because I am thinking that it is going to be something pretty obscure. Everything is on the table, including faults in the wire harness since I had it totally apart for cleaning & restoration.
                              - Sssquid sent me a bone stock tune with the only change being what was needed to properly run 28# injectors. The car started and idled properly from a cold start, and I drove it a few miles. About a minute after that cold start, it would stall coming off the throttle (such as at a stop sign) unless I have it a little throttle. The idle would sometimes stabilize if I was careful to really ease off the throttle.
                              - I swapped out the MAF conversion for the old stock AFM (conversion is plug-n-play) and gave tat a shot with the stock tune. The engine was still fully warmed up. It idled better, did not stall at all, and the only hiccup was a small stumble here and there coming off the throttle.
                              - After the engine fully cooled off, I started it with the stock tune and AFM to pull it into the garage. It would stall without me giving it a little throttle.
                              - When the engine was fully warmed up still, I popped in some of the other high performance tunes from Sssquid. They are basically the exact ones that he has developed and successfully run on other 2.1L M42 engines from Metric Mechanic. The car would start and the idle would oscillate between 1100-1600RPM. I did not try driving it, just idling.
                              - With the engine cold and the performance tunes in, it will idle steadily at ~2100RPM for a minute or two, before starting to oscillate.
                              I checked the resistance between terminals 43 & 78 on the Motornic plug (the two lines for the coolant temp sensor) and it came out to 400 Ohms when the engine was still luke-warm. Wiggling the wires at the sensor plug did not change the value, so there is no broken wire. I am replacing it anyway since my problems seem to have some link to engine temperature, but it seems unlikely that the sensor is bad since it is only about a year old.
                              I have replaced or swapped the following items while troubleshooting the oscillating idle to no avail:
                              - ICV
                              - throttle body
                              - TPS
                              - ECU
                              - AFM (swapped with MAF conversion)
                              Sensors & stuff that have been replaced within the last year include:
                              - Crank position
                              - Cam position
                              - Coolant temperature
                              - Crank damper wheel (60-2 toothed pulley)
                              Before the HG blew late last year, I was having an issue where the car would stumble and sometimes stall about 1 minute after a cold start, and it would go away after another minute as it continued to warm up. That particular behavior probably started around the beginning of 2019. I assumed it was the tune, but maybe not. I am unsure if it is related to my current issue since the entire wire harness is now a different one, damn near everything has been replaced and/or swapped and I can't think of anything that does not check out properly on my freshly rebuilt engine.
                              Prior electrical measurements indicate that this is NOT a vacuum leak. First, I have had vacuum leaks before, and they do not make the idle enter a constant oscillation pattern as far as I have ever seen on an E30. Stalling and a stumbling idle, sure, but not the oscillation. Anyway, the air flow signal at idle when it is idling either too high or oscillating is around 2.25V, which means that the ICV is being opened too much. Since I have replaced the ICV, cleaned it very well, checked the wiring connections, and verified that the signal looks about correct with an oscilloscope, I think that there is some issue with one of the inputs to the Motronic which is causing it to purposely open the ICV too much. As far as I know, the only things that are going to have an effect like this on the idle control are the coolant temp sensor, AFM, air temp thermistor and TPS.
                              At this point, I think that I am just going to have to yank the intake and fuel rail for some inspecting, take apart the big Motronic plug to verify that nothing got yanked when I rewrapped the harness, and probe through every connection from the Motronic plug to each endpoint. I am at a total loss otherwise. The engine runs well enough when not idling that I do not think it can be some sort of major cam timing issue or other mechanical fault.
                              Any and all thoughts and insight are appreciated.
                              • roguetoaster
                                Biggus Tippus
                                • 7830
                                #105
                                Well, until I read to the bottom I was thinking "where's the vacuum leak," having arrived at the bottom I nominate TPS connector intermittent strain based wiring fault as the likely culprit. How's operation without the TPS plugged in?
                                Also, is your evap purge valve still present?
