1991 318is Differential complete rebuild kit?
  • Ant131313
    • Feb 2016
    • 214
    Please help with links to a complete rebuild kit for a stock 1991 318is differential? I am needing all supporting characters including bearings too as well as the correct type of diff fluid? I am guessing I have a small case 4.10 but I don't know if it's LSD option or open.
    Thank you guys!
  • TobyB
    • 5248
    Far as I know, you'll need to buy the parts separately. No- one packages kits for
    BMW like they do for the domestic solid axle stuff.
    And brace yourself- the parts add up fast.
    No linky here. But if you get the part numbers off realoem.com, and then search yourself,
    you'll see what I mean...
    Strangely, Rockauto.com and other 'domestic' suppliers will have some of the bearings-
    they are standard parts.
    t
    • varg
      Florida Turbo Man
      • May 2014
      • 3395
      It's probably an open diff, LSD was an option on the 318is. Probably not worth it to spend the money rebuilding an open diff, and it's not exactly a DIY job unless you have the tools and are familiar with rebuilding diffs. Better to find a good used 4.10LSD.
      IG @turbovarg
      '91 318is, M20 turbo
      • flyboyx
        • 8371
        I think It's likely an lsd. Most but perhaps not all 318is's will have the "s" on the tag.
        Personally, I have never seen one without this feature
        Gigitty Gigitty!!!!
        • dsphil
          • 495
          327is
          325es
          325es
          318is
          Fiesta ST
          E46 M3
          • jpod999
            • Dec 2015
            • 1401
            I used to see plenty at yards here in the Bay Area. I was very surprised when I found an LSD actually.
            OBDI M62B44/6 swap
            Transaction feedback
            - jpod999
            • flyboyx
              • 8371
              wow! so bimmer diffs charges between 215 and 315 for a clutch rebuild kit but only 200 for a ring and pinion? damn.
              Gigitty Gigitty!!!!
              • AllydNYC
                • Aug 2013
                • 350
                You could go with a service like this: http://www.r3vlimited.com/board/showthread.php?t=292966
                E30: '91 318is - M52/ZF320 | Azev A 16X7.5 | H&R Race/Bilstein | Completely refreshed suspension/brakes/drivetrain
                An Associate/Bachelors degree is America's most overrated product
                • agent
                  Vice Grand Pubaa
                  • 7960
                  Originally posted by varg
                  ...it's not exactly a DIY job unless you have the tools and are familiar with rebuilding diffs. Better to find a good used 4.10LSD.
                  Truth. Or:
                  Thanks! We've done business with a number of forum members and have relationships with both Guten Parts and Kadunza.
                  Originally posted by kronus
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3395
                    I've never seen one with it
                    IG @turbovarg
                    • E30SPDFRK
                      • 5701
                      It's not too hard or expensive to do yourself, as long as you're good at being organized and can follow step by step instructions. I believe I spent less than $500 doing a 4 clutch upgrade to my 4.10 with all new clutches, dog ears, bearings, seals, and machining. There is a good writeup online somewhere, just google BMW 188mm diff 4 clutch for instructions.
                      Byron
                      Leichtbau
                      • Fsnow
                        • May 2015
                        • 184
                        Neither of mine came with lsd. Really how much could that have cost to add as an option new?:(
                        1991 318is x 2 .
