Diff problem need help
  • JALMARSSON666
    • Nov 2018
    • 17
    Hey I have 168 Lsd on my e30 and did a cheeky burnout today but afterwards it started acting like a welded diff, when i do a sharp turn it makes a loud clunking noise and feels like a welded diff, when jacking it up on one side i can spin the wheel half a turn freely then it locks up, with both wheels in the air both wheels spin in same direction without problems, anyone know what couldve happened?
  • bmwman91
    • Oct 2004
    • 3134
    Sounds like you need to get the diff out of the car and opened up on a bench. You could try pulling the cover with it on the car too. Either way, something sounds like it has expired in there and I'd do a proper inspection before trying to drive it more since having it seize up could result in damage to the driveshaft or axles.
    Transaction Feedback: LINK
    • Northern
      I like cupcakes & sh!tboxes
      • 5270
      Probably grenaded the spider gears if it's a 168
      Originally posted by priapism
      Originally posted by shameson
      • varg
        Florida Turbo Man
        • May 2014
        • 3417
        Get that thing out of the car or stop driving it before it fails, which could cause a crash. As for seizing, I wouldn't worry about the driveshaft or axles too much, I think it would have to lock up at WOT and peak torque for it to damage anything before of the diff because of the amount of lash in the driveline and the guibo, and the tires will be the fuse outboard of it. I'd worry more about how unsafe having the rear wheels lock up suddenly is. Personal experience.
        IG @turbovarg
        '91 318is, M20 turbo
