MMP M62B44 Build Project "Jack-N-Coke"
  • MonkeyMadness
    • 3251
    #601
    Yes I have seen that thread. looks to be nice work and well though out.
    I'm currently in the process of building my 3rd. SC manifold. Hopefully I'll have my next one done within the month...
    • MonkeyMadness
      • 3251
      #602
      Ok in search off some cheap but usable o2 sensors that fit a 93-94 Bmw...
      • quickervicar
        • 1197
        #603
        (forgive me) RockAuto has some on closeout for a 540i for around $20. Don't expect Bosch quality at that price.
        • MonkeyMadness
          • 3251
          #604
          Cool thanks I'll look into that ;)
          • Old city bimmer
            • Jun 2014
            • 1114
            #605
            thats cheap
            323i MTEC1
            Z3 coupe
            E60 M5
            • Tjabo
              • Feb 2015
              • 57
              #606
              I need to find a remote expansion tank solution for my e39 540, do you happen to know if yours has the correct pressure cap, and the necessary nipples to function properly on an early M62, looks to me like it would work? I like the looks of its shape and size (small and shallow).
              • MonkeyMadness
                • 3251
                #607
                Small update. Upstream 4 pin o2 sensors for early obd1 harness are on there way!
                • MonkeyMadness
                  • 3251
                  #608
                  Alright looking for sum info on the limp mode for the 404 dme.
                  I have finally installed my o2 sensors and with in minuets threw a CEL.
                  in fear of falling into limp mode while away from my house.
                  Looking to start driving it to work to put some miles on it. I work 8 miles away.
                  Will the lack of o2 throw me into "limp mode" or if they are hooked up but still throwing a CEL
                  • 36brua
                    • 689
                    #609
                    have you tried to 'clear' the chk light? disconnect bat. let sit for a few minutes reconnect drive and see what happens. which side 1-4/ 5-8 ?
                    My CA legal M60 swap
                    The happening in our garage
                    • MonkeyMadness
                      • 3251
                      #610
                      I disconnected the 404 after I shut the car down and walked away...
                      I didn't even do the stomp test. I was a tad bit peeved and not really wanting to fuck with it or let it ruin my day. lol
                      I'll plug it in tonight and run it to see if it comes back, then I'll do a stomp test...
                      I really need to ditch this dme shit and go to the MS3 but I wanted to wait till I had my SC setup... ugh
                      • JGood
                        • Jan 2004
                        • 7959
                        #611
                        The 404 DME doesn't have a 'limp mode'. It won't go into closed loop unless it gets a valid/within spec signal from a few major sensors (coolant temp, O2's, etc...) but that won't hurt anything short term. Half of r3v probably has their 02 sensors disconnected haha.
                        Without codes, can't really help, but first thing I'd verify is that you have the o2's hooked up correctly. IIRC, the longer harness goes to the drivers side.
                        This particular "dme shit" is light years more advanced then MS, at least for N/A use. And it's nice that it's throwing a code, now you know that something is wrong...
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • Denny
                          • Jan 2010
                          • 822
                          #612
                          Too bad your far away I would invite you in for a ride in my car and show you how I can control damn everything in this car... then you tell me if MS is light years behind...(yeah it was a pain to setup not much info out there but I got it running!! and documented I could replicate my setup so easy now) In the REAL world nobody needs ALL the shit that BMW has in there to control this engine including B.S EWS... and now you can actually tuned it properly (N/A or boosted) and get rid of 25 pound of wiring too.. loll...
                          Denny
                          ___________
                          1990 BMW red 325IC M30B35 all stock Girlfriends ride
                          1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                          Blogs:
                          http://bmw325e30.blogspot.com/ (restoration)
                          http://bmw325e30turbo.blogspot.com (Twincharge M20)
                          http://bmw325e30m62b44.blogspot.ca/
                          • JGood
                            • Jan 2004
                            • 7959
                            #613
                            Well, I was referring to the processing power. But now I see he was referring to MS3 anyway, so I retract my statement in that aspect.
                            Still, the DME/software is not to blame here. Obviously there is a sensor/input problem. Which can easily be isolated by simply pulling the codes.
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5272
                              #614
                              I could believe that even an old Bosch OBD1 DME has more processing power/is more advanced than MS3. Just looking at the tables in the MS41 DME makes me realize the crazy amount of tables and corrections go into making an engine run "properly" vs what I can do in TS with MS2
                              Originally posted by priapism
                              Originally posted by shameson
                              • Yorl
                                • Mar 2012
                                • 172
                                #615
                                Well, it's not what you can actually do with MS3. The problem is, do you know how to do it??
