And yet another V8 swap...
  • 36brua
    • 689
    #46
    Originally posted by Northern
    where'd you source that?
    ditto ^nice flywheel - aluminum ? ring gear for M60 starter ? what p plate clutch set up are you planning on? Thnx
    My CA legal M60 swap
    The happening in our garage
    • Jean
      • 18228
      #47
      UK ebay I believe sells these
      • Yorl
        • Mar 2012
        • 172
        #48
        TTV Racing it is. For the 5 speed trans and M3 E36 clutch assembly
        • alco
          • Feb 2013
          • 197
          #49
          Do you have a part number? There appear to be many a flywheel that would work and their layout on the site leaves a bit to be desired...too many products with no real information.
          Velocity Motor Works
          1972 2002
          1983 533is
          1987 325is (Roxanne)
          1988 M6
          1989 M3
          1989 325ix (Darth Maul)
          Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
          • alco
            • Feb 2013
            • 197
            #50
            By their site, the following should work too:
            http://ttvracing.com/engine-types/?m...ls#prettyPhoto[iframes]/17/
            http://ttvracing.com/engine-types/?m...ls#prettyPhoto[iframes]/16/
            1972 2002
            1983 533is
            1988 M6
            1989 M3
            • JGood
              • Jan 2004
              • 7959
              #51
              Your links don't work, but they have 3 flywheels that I see on their website; m60, m62, and m60 for use with M3 clutch. TTV told me that they can make an m62 flywheel for use with the M3 clutch as well (they would just add the trigger wheel for the CPS).
              Just contact them if you're interested...
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • Yorl
                • Mar 2012
                • 172
                #52
                Yes, mine is the M60 with the M3 clutch. If you have M62, you'd need a different one.
                • jalopi
                  • 2370
                  #53
                  Nopes, it's not solid!!! And it's 17 pounds
                  Lol... I was gonna say, 'check out my 45lb flywheel'
                  • totheredline
                    • Jun 2013
                    • 762
                    #54
                    :up: Great work! cant wait to see the finished product
                    = Heidi 1988 325 -> 335i. 7200rpm built M30
                    • Yorl
                      • Mar 2012
                      • 172
                      #55
                      Just want to say no updates and going on vacation next week...
                      Heads are at the machine shop, I got a new fuse box and random connectors and Raychem to build a new engine harness, and I installed my floor-mount pedal box.
                      Yes, floor mount. I'm short :D :D
                      • jalopi
                        • 2370
                        #56
                        How bad is the flex with the floor mount pedal?
                        • Yorl
                          • Mar 2012
                          • 172
                          #57
                          0 flex. I first cut and welded some strips to the floor, to make it completely flat, then I cut a thick steel plate, drilled and with helicoils for the pedal box. That plate is welded to the now-flat floor, and some reinforcements are welded to the sides and back to the seat mounting points.
                          Cut a hole in the carpet and voila, done. Looks good once everything is installed, I fit fine and, as far as I can tell, there's no flex. I've done some other cars the same way and never an issue, but I guess I'll let you know for sure when I take it to the track.
                          • jalopi
                            • 2370
                            #58
                            Well, if it doesn't feel like it's flexing and the clutch disengages fine, it's probably not flexing. Besides, it sounds like you did do it the legit way anyway.
                            • Yorl
                              • Mar 2012
                              • 172
                              #59
                              Well, haven't done much lately... by not much I mean nothing! I just installed the new fusebox inside the car and this weekend I'll start re-wiring everything. I also have a reservoir for the pedalbox, and I got my x-mas present, because I'm such a good boy :D
                              And now, for the xmas present...
                              I also have a Race Technology dash2, but I find it too modern for the M3. Everytime I see the stack, boner
                              • jalopi
                                • 2370
                                #60
                                Holy crap, those clusters are awesome! Just too much money for me though
