I think stock is a return style? Not quite sure... but the stock hardlines run from the fuel tank on the pass side across underneath the body to the drivers side, and then run up along that frame rail. Then turn up into the engine bay right by where the brake proportioning valve is. And then assuming its a return style, the return follows the exact same route because I remember there being 2 fuel lines along the drivers side frame rail.
I'm planning on doing pretty much the same thing, just with all new lines. And Im using earl's pro-lite 350, not using hard lines.
