My '90 325is LS3 Swap Build Thread
  • CLM21
    • Dec 2013
    • 223
    #211
    Awesome, thanks. I'll probably just pick up some thread adapters if that's the case.... Sounds like an easy enough fix.
    • CLM21
      • Dec 2013
      • 223
      #212
      Originally posted by ultimateracing335i
      I just looked at the sikky oil pan instructions. It says to trim the baffle. Did you do that?
      I just talked to them about this and they said it was just a precaution. Some applications require it and some don't, so if you're able to install the pan with no problems then you've got nothing to worry about.
      • ultimateracing335i
        • Sep 2014
        • 122
        #213
        That's good I was worried.
        • Q8y_drifter
          • Aug 2009
          • 297
          #214
          I trimmed mine just in case. Wasn't sure if it was needed and said fuck it and just did it.
          Alpine White 1989 E30 Coupe - LS1/T56
            • Sep 2014
            • 122
            #215
            Did you wire in your bmw tach with the gm tach signal. I don't know what I need to get it to work.
            • Old city bimmer
              • Jun 2014
              • 1114
              #216
              awesome build
              323i MTEC1
              Z3 coupe
              E60 M5
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4508
                #217
                bump
                • 67Riviera
                  • Feb 2018
                  • 1
                  #218
                  Is this build still among the living?
                  • CLM21
                    • Dec 2013
                    • 223
                    #219
                    I know its been a hot minute, but finally got around to finishing this build. Pictures to follow.
                    • CLM21
                      • Dec 2013
                      • 223
                      #220
                      Engine Bay:
                      Click image for larger version  Name:	Resized_20200214_212500.jpeg Views:	0 Size:	74.6 KB ID:	9909030
                      Exhaust:
                      Click image for larger version  Name:	Resized_20200206_112054 (1).jpeg Views:	0 Size:	66.0 KB ID:	9909031
                      T56:
                      Click image for larger version  Name:	Resized_20200104_130930.jpeg Views:	0 Size:	69.0 KB ID:	9909032
                      Fuel Cell:
                      Click image for larger version  Name:	Resized_20191220_115628.jpeg Views:	0 Size:	64.6 KB ID:	9909033
                      Rear End & Bracing:
                      Click image for larger version  Name:	IMG_0767.JPG Views:	0 Size:	90.4 KB ID:	9909034
                      Still a few things to be done. Gauges, tuning, fender flares, and debating a cage. Will get fire up videos pretty soon here.
                      • Pootis
                        • 636
                        #221
                        Wow that exhaust looks great!
                        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #222
                          That exhaust tuck is niiiice.
                          Fair warning. My trans mount failed after a year or two. The design isn't great.
                          • CLM21
                            • Dec 2013
                            • 223
                            #223
                            Interesting. Any idea if this has happened with other sikky mounts or if they've redesigned it since the original kits?
                            • shiboujin
                              • Feb 2006
                              • 2791
                              #224
                              I haven't seen their latest. The main failure point is that the bracket is basically "glued" to the metal mount. So over time, it just separates.
                              • CLM21
                                • Dec 2013
                                • 223
                                #225
                                Gotcha. I'll ask them about it.
