M60B44,MS2,S62 ITB build
  • Jack89i
    • Dec 2013
    • 240
    #46
    Originally posted by BenzoNI
    Hi Jack, when are hoping to have this running?
    Have you contacted my friend about the ITB adaptors? Do you plan to run factory can timing?
    For now I'm just trying to get it running with the stock manifold and then I'll do the ITBs. Trying to take one major mod at a time so things don't get too complicated. Hopefully by July/August I will be ready for the ITBs
    sigpic'89 325i
    M60 swap in progress
    • Jack89i
      • Dec 2013
      • 240
      #47
      Engine is all together sans oil pan
      Bolted to the block to prevent (minimize) warping..had a little bit of warpage but I put a nice bead of RTV where it was lifting and torqued accordingly
      (TIG credits go to my buddy, Brock)
      I worked on getting my z3 rack fitted while he welded my pan. I've had this e30 for 6 years and have always wanted to swap the school bus rack out but never did. I decided it was time..
      sigpic'89 325i
      • jpod999
        • Dec 2015
        • 1401
        #48
        Nice progress! I am planning on doing that rack mount subframe mod next weekend, any pointers before I get started?
        OBDI M62B44/6 swap
        Transaction feedback
        - jpod999
        • BenzoNI
          • Dec 2014
          • 63
          #49
          I may be selling my full ITB setup as I'm
          Thinking about going twin turbo. Complete setup including manual throttle linkage, adaptor plates, helicoils everything, ITBs, I let runners. Etc.
          • Jack89i
            • Dec 2013
            • 240
            #50
            pretty straight forward, just drilled out the 5 spot welds, bent it forwards and sawed the bead on the underside. Do one side at a time so the position doesn't change.
            sigpic'89 325i
            • jpod999
              • Dec 2015
              • 1401
              #51
              Thanks for the tips!
              OBDI M62B44/6 swap
              - jpod999
              • Jack89i
                • Dec 2013
                • 240
                #52
                I'll shoot you a PM, are they still on the car?
                sigpic'89 325i
                • george graves
                  • 20003
                  #53
                  sub'ed
                  Originally posted by Matt-B
                  • dougie30
                    • Apr 2012
                    • 1708
                    #54
                    What clutch/flywheel/slave combo were you running with the five speed?
                    Sent from my MotoG3 using Tapatalk
                    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                    • Jack89i
                      • Dec 2013
                      • 240
                      #55
                      For 5 speed I used a m60b44 (240mm) flywheel (e39 540) and then a b28 clutch kit (e36 328, e39 528 ect)
                      Note that the e34 540i flywheels are 265mm (until 96 I believe) but you want the later 240
                      sigpic'89 325i
                      • Jack89i
                        • Dec 2013
                        • 240
                        #56
                        Engine bay is all ready for the engine to go in!
                        Made my own adapter brackets for the recaros to go on stock e30 sliders
                        And of course..
                        After having a door that flies open for several years I finally fixed it and a few other interior bits
                        Interior is done for the most part
                        sigpic'89 325i
                        • Zacm829
                          • Jan 2008
                          • 1919
                          #57
                          I know this is up and running. Dyno anytime soon?
                          1987 325i-M60b44 swap
                          • dougie30
                            • Apr 2012
                            • 1708
                            #58
                            what ever happend to this build? such momentum, lost
                            • bavarianbeast-khalil
                              • May 2016
                              • 3
                              #59
                              Yeah I wish I could see a video of this thing ripping down the street.
                              BavarianBeast.com
                              • AWDBOB
                                hooptie connoisseur
                                • Aug 2013
                                • 4488
                                #60
                                Bump
