E30ls1
  • Reyhan335
    • Nov 2015
    • 700
    #166
    Originally posted by Q8y_drifter
    a) Can't see the first pic
    b) There's a pin holding down that orange quick disconnect fitting. Hammer it out, don't lose pin, install new AN fitting, hammer pin back in.
    Have I ever told you that you're the man? Lol
    e30Ls1 Swap IG: 1dirty30
    • Q8y_drifter
      • Aug 2009
      • 297
      #167
      There we go!
      Just make sure you pressure test everything on the bench beforehand and check for leaks. Last thing you wanna do is drop the trans to fix a leaking slave fitting (don't ask me how I know lol)
      Alpine White 1989 E30 Coupe - LS1/T56
      • Reyhan335
        • Nov 2015
        • 700
        #168
        Last night was supposed to be a night to get a lot of work done.
        We were gonna
        Put the flywheel on
        Clutch
        Slave cylinder
        Transmission
        And bolt all that together.
        But.
        The old release bearing wouldn't come out at all. I went to an auto parts store right before they closed. Rented their tool. And it broke the tool.
        So we tried with some 90 degree pliers. And still nothing. It's seized in there and it sucks.
        Nothing ever goes as planned
        • garretvs
          • 464
          #169
          Do you mean the needle bearing in the aft end of the crankshaft that the tranny shaft engages? If it looks ok, put in a little grease and put everything together. The bearing only spins when you sit at a light with your foot on the clutch ....
          Also, be sure the face of the flywheel & pressure plate is clean and shiny. Ditto the clutch itself. ONE greasy thumbprint can cause clutch "judder" on engagement -- a real pain in the ...
          E30-LS1 aka. 357is
          email us to pick up our LS1 swap guide
          E30-LS1 KITS now available!!
          E30LS1@gmail.com
          e30ls1.com
          • Reyhan335
            • Nov 2015
            • 700
            #170
            It's the throw out bearing. Right where the flywheel goes
            • Q8y_drifter
              • Aug 2009
              • 297
              #171
              Thats the pilot bearing and yeah they can be a pain. Never had to deal with em as my LS1s all came from auto cars.
              • Reyhan335
                • Nov 2015
                • 700
                #172
                Since I have the slave cylinder all hooked up. I'm quite confused since I've never worked on a t56.
                Would I need the clutch fork? Shouldn't the slave cylinder do everything? I was looking at it yesterday and was just confused
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  #173
                  The T56 uses an internal slave, so there's no clutch fork. Just the hydraulic braided line going into the bell housing and the bleeder going out.
                  • Reyhan335
                    • Nov 2015
                    • 700
                    #174
                    When I bought my t56 from Charlotte there was a clutch fork already in it. That's what's confusing me
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #175
                      Got the bitch out. With a lot of heat and I went through one rental tool and got another one and finally got it
                      [URL]https://vimeo.com/162208728[/URL
                      Here's the tranny. I really don't understand how the slave and the fork work together.
                      Sorry, we couldn’t find that page
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        #176
                        That looks like an LT1 T56. You'll need a T56 from a 98+ LS1 F-Body.
                        The older style LT1 T56 has a revision for a clutch fork on the midplate and uses an external slave to actuate the fork (left).
                        The newer LS1 T56 has threaded holes to mount the internal slave you have so no fork necessary (right).
                        Your LS1 style slave won't work with your T56. I'm not sure if the LT1 T56 can be swapped in though. Maybe someone else can chime in.
                        • Reyhan335
                          • Nov 2015
                          • 700
                          #177
                          Oh no...
                          • Reyhan335
                            • Nov 2015
                            • 700
                            #178
                            But there's two holes on the bell housing for the slave cylinder hoses to come out of.... Maybe there's like an adapter plate? Idk. I spent a lot of money on this trans i really hope I can make it work
                            • Q8y_drifter
                              • Aug 2009
                              • 297
                              #179
                              You have the correct LS1-style bellhousing which has holes for the hydraulic lines but the midplate and input shaft will need to be changed out I believe.
                              I don't have much info on this swap other than these couple links from a google search.
                              Manual Transmission - Difference between LT1 T56 and LS1 t56 - Is there any difference between LT1 t56 and LS1 t56? I need to buy a transmission for my LS6 and i've found one. Will both be bolt-on or need any other parts? Thanks Kevin
                              We admit it; from time to time we need to dink around on the Googles and internets just as much as the next guy. Being car guys, our random internet searches an
                              • DER E30
                                • Sep 2013
                                • 2349
                                #180
                                Try to find the part number off thr front plate, you may have gotten boned...
                                -Christian
