E30ls1
  • 90e30ls
    • Dec 2015
    • 77
    #151
    Going with booster delete myself. Should see mine on Friday.
    • Reyhan335
      • Nov 2015
      • 700
      #152
      Which one did you get
      e30Ls1 Swap IG: 1dirty30
      • Reyhan335
        • Nov 2015
        • 700
        #153
        Look what came in the mail [emoji7][emoji7]
        • jpod999
          • Dec 2015
          • 1401
          #154
          I'd be nervous about a single master boosterless setup with a V8 swap, have you seen Lee's new dual master kit?
          OBDI M62B44/6 swap
          Transaction feedback
          - jpod999
          • Reyhan335
            • Nov 2015
            • 700
            #155
            Nah you have a link to it? And we will see how I like it.
            • DER E30
              • Sep 2013
              • 2343
              #156
              Why is 1 dual circuit master different than 2 single circuit master? If the pedal ratio/overall ratio is good then it'll be perfectly fine. 2 masters don't make more or less effort or safety than a properly set up single master
              -Christian
              • Reyhan335
                • Nov 2015
                • 700
                #157
                I honestly have never heard of it. I doubt it's that much of a change.
                • jpod999
                  • Dec 2015
                  • 1401
                  #158
                  OBDI M62B44/6 swap
                  - jpod999
                  • 90e30ls
                    • Dec 2015
                    • 77
                    #159
                    I got the Chase Bays kit.
                    • 90e30ls
                      • Dec 2015
                      • 77
                      #160
                      This is my understanding of it too
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        #161
                        It's not safer because of reduced stopping distance or braking effort. It's safer because a dual master setup has two masters with separate circuits. If a master or circuit failed you still have one master/circuit left to stop the car.
                        Alpine White 1989 E30 Coupe - LS1/T56
                        • DER E30
                          • Sep 2013
                          • 2343
                          #162
                          But 1 dual circuit master has dual circuits as well for the same reason... That's why it has 2 brake line connections, it has a twin set up inside typically with the bias set up internally.
                          -Christian
                          • Q8y_drifter
                            • Aug 2009
                            • 297
                            #163
                            Nvm. I read single master and assumed single circuit. A tandem style MC should work fine.
                            • Reyhan335
                              • Nov 2015
                              • 700
                              #164
                              So I followed everything on the file. I bought all the fittings and lines. I have the clutch slave cylinder and it doesn't fit. What am I doing wrong
                              Cmon r3v help!!!! Lol
                              • Q8y_drifter
                                • Aug 2009
                                • 297
                                #165
                                a) Can't see the first pic
                                b) There's a pin holding down that orange quick disconnect fitting. Hammer it out, don't lose pin, install new AN fitting, hammer pin back in.
