Project Snow White (LM4 Swap)
  • sgtskid
    • 763
    #106
    ;d
    [ATTACH]115407[/ATTACH]
    Current: '91 DS M3, '03 TS M3 (6MT)
    '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
    Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
    1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
    IG: RDE_Fabrications
    Check us out
    Or YouTube --> HERE;
    • sgtskid
      • 763
      #107
      Update: I've put about 300 miles on her and she run's like a scalded cat!
      I have a short list of things that need to be fixed:
      1. Brakes are dragging (Massive Booster Delete)
      2. Still no Tach
      3. Speedometer is WAY off
      4. Electric fan runs all the time.
      Other than that, she runs great and is an absolute blast to drive. The solid motor mounts aren't as bad as I was expecting vibration wise and the exhaust is actually relatively quiet until I stand on it. No power steering isn't that bad but, I haven't had it on a tight road yet. The decision to delete the brake booster is still questionable, I can't give a solid answer until I have fixed the dragging pad problem (just need to adjust linkage). Because the pads are in contact with the rotor, the pedal is super firm and the pads have some pretty knarly fade.
      The fan should be an easy fix. I just need to change wire pin-outs on a relay.
      Check us out
      • sgtskid
        • 763
        #108
        1000 mile check in.
        1. Dragging brakes fixed - backed off on the rod between the master cylinder and the pedal
        2. Tach fixed - needed resistor between the power and signal wire
        3. Speedometer is still off
        4. Electric fan fixed - issue with relay wiring
        No power steering feels amazing, I am still really happy with it even on twisty roads when pushed hard. No power brakes is a little sketch when doing spirited driving - I will most likely be upgrading calipers or reducing the size of the master. I can't lock up the wheels and I don't have the confidence I want to late brake into a turn and know that the car will respond.
        On another note, I have been slowly going through the rest of the car and I started with the sunroof crank knob.
        I made a prototype on a 3d printer and once I verified the dimensions I printed a more permanent version from black Nylon. The permanent version was a little tight and I had to use a rubber mallet to tap it onto the handle. Works like a champ though and sure beats the little metal post.
        Check us out
        • kalib0y
          • Dec 2004
          • 3620
          #109
          great work and detail
          95 7.1L 16V E36 M3
          Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
          LIKE my Facebook Page! CLICK HERE
          • sgtskid
            • 763
            #110
            Thank you! I'll be hitting you up soon for some studs. We run them on our race car and I have a set on my 88 Super E.
            I'm trying not to upgrade the car too fast until I get all the kinks worked out. Doing so keeps me from beating on it too hard. :)
            Check us out
            • kalib0y
              • Dec 2004
              • 3620
              #111
              That's a great way to do it. Building and troubleshooting is where all the fun is.
              Let me know whenever you are ready brotha!
              95 7.1L 16V E36 M3
              • sgtskid
                • 763
                #112
                1500 miles. Photo creds: Fastest Foreigner - Killboy.com
                Check us out
                • sgtskid
                  • 763
                  #113
                  Update:
                  Just turned ~5,000 miles - car is running better than ever.
                  Huge shout out to Erk's LS Tuning and Wiring for getting the tune dialed in and the speedometer reading correctly.
                  The tach is now reading correctly after simply setting the signal in the ecu from 8cyl back to 4cyl which is what the tach was programmed for.
                  The speedometer receives a signal from the ecu which receives the signal from the transmission. The speedometer has a "learn" feature in which you press a button, drive a mile, and then press the button again. During this time the speedometer is measuring the pulses/mile and is suppose to calibrate on it's own. I tried this method a few times and the results were always very erratic speed. The issue was fixed by telling the ecu the diff ratio and tire size and then setting the output signal to 8000 pulses. The speedometer had a factory setting of 8000 so once I did a hard reset everything worked perfectly.
                  The gauges I bought were Summit Racing and I would not recommend them. The gauges haven't even been installed a year and they are already starting to lose portions of the numbers. The tach resolution is not that great and moves in increments of 100 and sometimes 500 rpm.
                  I did 70mph in 4th, 5th, and 6th gear to see what RPM the engine would run at and compared to the spreadsheet I had made (posted on page 2).
                  Below are the results and keep in mind tach moves in 100 and 500rpm.
                  4th gear 75mph (predicted rpm ~4,000)
                  5th gear 70mph (predicted rpm ~2800)
                  6th gear 70 mph (predicted rpm ~ 1900)
                  Check us out
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    #114
                    Why not use the BMW VSS in the diff?
                    • sgtskid
                      • 763
                      #115
                      Didn't think about it. I knew the ECU had a signal that was pulled from the trans and that's what I went with.
                      Off topic question for you Dark Side, do you race in Champ?
                      Check us out
                        • Jun 2010
                        • 2796
                        #116
                        I don't.
                        You mean Chump Car?
                        Why?
                        • sgtskid
                          • 763
                          #117
                          I don't.
                          You mean Chump Car?
                          Why?
                          Chump/Champ...they changed their name.
                          There is a guy that runs a DTM style E30 and I am pretty sure his name is Will. Just curious
                          Check us out
                            • Jun 2010
                            • 2796
                            #118
                            That's some kinda style, aight.
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4508
                              #119
                              What did this car make on the dyno with just the LS6 cam, refresh and truck intake?
                              • sgtskid
                                • 763
                                #120
                                I've never had it on a dyno. I'd like to one day and I have access to one, but our schedules never linedup for me to get over to it.
                                Check us out
