How the f*** do I remove broken glovebox?
  • c0rbin9
    • Dec 2015
    • 609
    How do I remove this shit? Bolts in back are removed.
    Help is appreciated.
    1991 318is Brillantrot daily driver (slow restoration)
  • johnt325ix
    • Nov 2013
    • 101
    Sent from my SM-G900V using Tapatalk
    • c0rbin9
      • Dec 2015
      • 609
      If only it were that easy. The latch is stuck closed.
      • johnt325ix
        • Nov 2013
        • 101
        Oh crap. I see it now. I have no patients. I would break it then replace it.
        • c0rbin9
          • Dec 2015
          • 609
          I don't even know how to go about breaking the latch. Anyone know where to cut with a dremel that will free the latch?
          • uturn
            • Dec 2010
            • 1005
            While holding the glove box up, push the lever to the right and pry the one on the left down. Then try to lower the glove box. If going beast mode, then just push up in the middle while pulling down on the glove box to crack the plastic.
            • varg
              Florida Turbo Man
              • May 2014
              • 3418
              After I broke the handle off of my glovebox and catapulted it across my yard I discovered that the trick was to push the glovebox door upwards and push the lever up and to the right. If that doesn't work you're SOL, I don't know how you could open it non-destructively.
              IG @turbovarg
              '91 318is, M20 turbo
              • c0rbin9
                • Dec 2015
                • 609
                I finally got it, following this guide:
                I had to bend the striker down to access the "catches" on either side of the striker. Also broke some plastic in the process. Glovebox itself seems fine though. Damn that was a PITA.
                • c0rbin9
                  • Dec 2015
                  • 609
                  Now electrical accessories/gauges don't work...
                  • c0rbin9
                    • Dec 2015
                    • 609
                    A/C, radio, gauges don't work. Everything else does. Everything worked before I took out the glovebox. Any ideas?
                    These wires are disconnected, not sure if related.
                    • IceWhite
                      • Jan 2015
                      • 945
                      ^ Those wires could be for the glove box light.
                      1990 325i
                      2004 330i Individual 6-speed
                      • c0rbin9
                        • Dec 2015
                        • 609
                        Anyone? I hate leaving stuff worse than when I started.
                        Radio, A/C, gauges except speedo - none of it works now. Is there a common relay or fuse for these things that I should be checking? I did a lot of bending and prying removing the glovebox. Anything I could have messed up? Surely the little glovebox lights don't need to be plugged in for this stuff to work?
                        Also the little brown/white and red/gray wires on top in the picture. Related?
                        Also still have interior panels removed, including glovebox and glovebox light.
                        • reelizmpro
                          • 9552
                          The glovebox R&R has nothing to do with the Radio, gauges, etc working. The wiring is supposed to be secured to the bottom of the air ducts which is out of the way. The brown and red wires are for the glove box light. There's also the constant 12v for the flashlight (missing 99.9% of the time) that is attached to the glove box.
                          88 M3 - LACHSSILBER
                          89 M3 - ALPINEWEISS II
                          • Stanley Rockafella
                            • Aug 2011
                            • 4062
                            one in the pink, two in the stink?!?!
                            but yeah, I dunno mang
                            • c0rbin9
                              • Dec 2015
                              • 609
                              Trying to point to both dangling wires. : (
