5-lug Setup
This is a sticky topic.
  • lifeiskaos
    • 1709
    #181
    updates?
    • Aptyp
      • 6584
      #182
      :) Tell me what you want to know, I'm sure there's something.
      Personally I want to figure out a swap to run e28 TRX bottle caps. I figured out the rear, not quite there on the front yet. e28 brake rotor fits on e36 hub, but locator bolt is offset differently. Maybe one day when I have more time and access to a machine shop again, I'll knock it out.
      • Gooch
        • Dec 2006
        • 1674
        #183
        Why would you want to run TRX wheels? Have fun buying tires for those things, and not to mention they're hideous.
        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
        '87 535i - Vacuum brake conversion [SOLD]
        '93 525iT - 5-speed swap - 320k and counting
        '09 328xi - 6-speed
        • lifeiskaos
          • 1709
          #184
          Oh, whoops. I thought this was the front hub thread. Just looked for a long thread in this subforum lol. Oops!
          • Aptyp
            • 6584
            #185
            Because I have a set of pristine TRX wheels? Because it would be lots of fun to run bottle caps with somewhat of a lip? Because it just makes sense to have a little fun.
            • Chabs
              • Jan 2010
              • 538
              #186
              I want to do this, but I've got a budget. How much does this usually cost on average?
              Josh
              http://www.r3vlimited.com/board/showthread.php?t=159843
              • Aptyp
                • 6584
                #187
                all depends on you. $400-500 should get you in the doors.
                • Jalves619
                  • 596
                  #188
                  Are the subframes of the MZ3 and e30 different? Since the car is my daily I would really love to just throw new bushings in the MZ3 rear suspension and swap the entire package in at once.
                  • Aptyp
                    • 6584
                    #189
                    great question... I don't know for sure, I've never had them side by side.
                    • Jalves619
                      • 596
                      #190
                      I remember reading that using the bushings from an e30 you could install a MZ3 subframe but I can't recall where I read that.
                      • rThor432
                        • Feb 2007
                        • 3907
                        #191
                        I remember hearing a while back that the crossmember is ever-so-slightly longer (wider) for the E36/5 and /7 chassis. IIRC it was a friend who is now running Z3 2.8 rear suspension who tried using the Z3 crossmember and found that it would not work.
                        • Jalves619
                          • 596
                          #192
                          Not the original source that I had mentioned but it renews my hope. I guess when I can afford the downtime I'll pull my e30 subframe and compare.
                          • Aptyp
                            • 6584
                            #193
                            founf out why my rear alignment has been messed up... one of my adjustable sway bar links was broken, so one side pulled as other side decompressed a little.
                            Don't know how I didn't notice it for months.
                            • Aptyp
                              • 6584
                              #194
                              Originally posted by Jalves619
                              http://www.e30tech.com/forum/showpos...6&postcount=40
                              I see only one problem with that post: running 15" is impossible on m3 rear brakes...
                              • Aptyp
                                • 6584
                                #195
                                Improved HTML file, so this is an update.
                                Check it out, I'm pretty proud of it.
