5-lug Setup
This is a sticky topic.
  • bimmer630
    • 1230
    #136
    Originally posted by HellzMindPlaya
    I tried, and learned the hard way to listen to peolpe who know what the hell they are talking about... Now to buy some wheel bearings and other items needed.
    Should look nice when done I hope.
    What is it that you did wrong anyway? if those are e36 offset wheels sticking out that far, what kind of hubs are you running? M-roadster trailing arms or something? the brakes dont look like m roadster
    • Aptyp
      • 6584
      #137
      he's either running z3 I6 trailing arms or these wheels are 8+" wide with offset 20.
      • Miasma
        • Apr 2007
        • 2009
        #138
        Should be a sticky for sure.
        • HellzMindPlaya
          • 395
          #139
          The trailing arms are off a 2.8 Z3 and they are 8.5 inch wide wheels with an offset of +45mm. Hope they fit if I change out the hubs to my trailing arms. The car is an 89 so I need to use these hubs, I just didn't/don't want to screw with the wheel bearings so I tried just bolting up the trailing arm first.
          e30 Sold long ago - Too many BMWs since then... For now 2006 M5
          • Aptyp
            • 6584
            #140
            got e36m3 spindles and brakes for all 4 corners today. No I need to wreck my head to figure out how to install rear brakes. I'd like those huge m-calipers and rotors all around.
            • clavinZERO
              Hella sick E30
              • Mar 2004
              • 2027
              #141
              you Sir are going to LOVE the braking. Got good rubber?
              "BMW Style 32 Poster-Child"
              HTTP://WWW.CLAVINZERO.COM/e30-5-lug
              **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
              • Aptyp
                • 6584
                #142
                :nice:
                I love breaking already, my ABS works and I have 25mm MC.
                When I started my car stopped 60-0 in 157ft (old used brakes)
                With stock e36/z3 and 25mm on all new parts 60-0 became 104ft.
                I have a feeling I'll be able to use my passenger seat belt as a strangling device.
                • robmespeedy
                  • Oct 2004
                  • 561
                  #143
                  under rear set up 86+ 318/325 for the [Brake Rotor 34-21-1-164-399 z3 I-6]
                  you can use the rotor from a 1.9L Z3 since it uses the same rotor as the I-6.
                  • Aptyp
                    • 6584
                    #144
                    if that's the case, then all 318ti and z3 rotors are the same, are they?
                    BMA shows them to be the same, but my ETK and WorldPAC doesn't. So better safe than sorry. Someone chime in on this issue.
                    • Lofty
                      • Apr 2008
                      • 14
                      #145
                      So let me get this straight. If I plan to use a big brake conversion such a Massive's, all I need is to buy E30 M3 rear hubs. Correct?
                      • Aptyp
                        • 6584
                        #146
                        asking the wrong person, but if Massive sells e30m3 rear BBKs then yes, hubs are all you need.
                        • robmespeedy
                          • Oct 2004
                          • 561
                          #147
                          the z3 1.9 and the z3 I6's use the same rotors.
                          but the 318ti rotors are not the same as the z3's
                          • Aptyp
                            • 6584
                            #148
                            ^ that's where I don't see the logic...
                            IF
                            318ti hub = z3 1.9L hub
                            AND
                            z3 1.9L Rotor = z3 I6 Rotor
                            AND all caliper carriers are the same.
                            AND all brake pads are the same
                            THEN
                            318ti Rotor and all z3 rotors should be the same.
                            There's some monkey business.
                            • robmespeedy
                              • Oct 2004
                              • 561
                              #149
                              318ti rotor part #34216758552
                              Z3 1.9 rotor part # 34211164399
                              Z3 2.5, 3.0 rotor part # 34211164399
                              • robmespeedy
                                • Oct 2004
                                • 561
                                #150
                                z3 1.9 hub part #33411095770
                                318ti hub part #33411095768
                                they are different.
