5-lug Setup
This is a sticky topic.
  • F34R
    sLaughter
    • 12385
    #196
    Can someone coin in and give me some info/advice on what to buy?
    I am building a track e30, I am also swapping over my e30 GC setup. Can I use the coils and buy some other shocks and struts?
    I have quite a few e36 325i in the junk yard. I can source the fronts for 30 a side. Or can I just use the E30 housings with e36 hubs?
    I then would need 318ti rears?
    I read up on it but mostly everyone goes M3. Should I just wait and get the M3 front housings? Or can I swap over the M3 brakes?
    I bought 16'' BBS RS 5x112 would these fit the M3 brakes?
    Also should I go with the e36 CAs?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • Spaz
      Crazy Canuck
      • 2276
      #197
      html down :(
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • Aptyp
        • 6584
        #198
        link works
        • E-Thirty
          • 1331
          #199
          Just a heads up, the HTML link at the bottom has a "-" between 5 and lug.
          Do you feel like something is trying to penetrate your butthole?
          • Aptyp
            • 6584
            #200
            thank you, sir. Didn't even notice it, but it's fixed now.
            • Aptyp
              • 6584
              #201
              ever since update I've been getting a lot less PMs. Feeling unloved.
              • iXguido
                • Nov 2009
                • 727
                #202
                Link's not working again
                • Aptyp
                  • 6584
                  #203
                  working like a charm here, every time
                  • iXguido
                    • Nov 2009
                    • 727
                    #204
                    http://www.torque-bound.com/5-lug.html <that the link ur talking about? doesn't seem to work for me. maybe it's my messed up internet
                    • Aptyp
                      • 6584
                      #205
                      go to the first page of this thread and click on the link... it works and better than ever.
                      • iXguido
                        • Nov 2009
                        • 727
                        #206
                        kk. thanks a bunch. I was using the wrong link. works just like you said
                        • Aptyp
                          • 6584
                          #207
                          little update... had an odd vibration front passenger side at 60mph. Turned out be my control arm bushing sliding on the control arm. Odd problem to have.
                          • HellzMindPlaya
                            • 395
                            #208
                            I have a strange vibration from that side too, what exactly was it? Mine is only when the steering wheel is turned to the right ever-so-slightly though, so it may just be that I am in need of an alignment.
                            e30 Sold long ago - Too many BMWs since then... For now 2006 M5
                            • Aptyp
                              • 6584
                              #209
                              Mine was going straight between 50-60mph. Thought it was tire or bent rim, but ended up being CAB.
                              • Aptyp
                                • 6584
                                #210
                                Got a set of these: 16x7.5 ET20. Perfect fit with Nitto 205/5--16 tires. Can't wait to roll of them.
