5-lug Setup
This is a sticky topic.
  • RobE30
    • 959
    #226
    WOW man! I've been off the board for quite awhile and just checked back to this thread. Fantastic writeup! I now feel much more inclined to finally swap my car to 5 lug and get rid of all the bent shit on my car. Strong work
    09 BMW 328xi touring 6spd
    05 Subaru Outback XT 5spd
    87 BMW 325is
    a few bicycles
    • samiam3356
      • Jul 2009
      • 1901
      #227
      Originally posted by Aptyp
      ever got it sorted out? very interested to see what you've come up with.
      I'm going to start over from the begining and rebleed the MC and then the brakes again. Going to do it the old fashioned way this time as I've heard people having issues with pressure bleeding. Just need the time to get it done. Thank god I have some extra brake lines to use for bleeding the master. Just going to run them back into the reservoir.
      As far as the bigger piston in the rear I'm going to wait until summer time to figure that one out. More than likely I'll be running an adjustable proportioning valve the remedy the issue.
      Will let ya know whenever I get done though.
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • matias88e30
        • Dec 2009
        • 1110
        #228
        Awesome write up man! thanks a lot it will be very helpfull for my rear 5 lugset up!
        no more boosted m20, 91 318i...
        • unloadedak
          • 1197
          #229
          just me or is extra drei down?
          2003.5 Imolarot M3: daily
          1995 Alpinweiß M3: hpde
          • samiam3356
            • Jul 2009
            • 1901
            #230
            not working for me
            $5 shipped?
            • Aptyp
              • 6584
              #231
              I have to renew the domain, but I gotta wait til my other domain comes up for renewal so I can get the discount.
              • Mr.SWISS
                • Nov 2005
                • 1251
                #232
                Ok can you post the rear setup again so i can get on that yo?
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                • hoveringuy
                  • Dec 2005
                  • 2705
                  #233
                  I'm going to re-post some info because I think it's valuable:
                  318ti calipers have a 2mm smaller piston than 325 calipers.
                  The current state of the art is that in order to use the e36 non-318ti calipers you need to mount them on the opposite side in order to use the stock hose. The bleed nipple is on the bottom and I need to stand on my head whenever I want to bleed the brakes....
                  Option two. Go to local hydraulic shop and fabricate a couple of hoses for $40 that let me mount the calipers in the proper position so that bleeding doesn't become a hassle. The brake line *may* need to be removed to remove the caliper, but that's it.
                  Parts used:
                  (2) BQ4511 Tube Nut 10x1mm x 3/16
                  (2) HF02 Fitting-universal ext 3/16 bundy tube
                  (2) HFMF05 Fitting- Female 10x1mm European (DPS)
                  12" 1/8" brake hose
                  $40, assembled and pressure tested to 3000psi
                  • Aptyp
                    • 6584
                    #234
                    interesting... I actually had no issues bleeding brakes. I don't even take wheels off, nor lift the car. I put 7mm wrench on it and a brake bleeder over the nipple.
                    When I had 17's I bled brakes through spokes, hehe.
                    PS: Push your barking brake cable in.
                    • hoveringuy
                      • Dec 2005
                      • 2705
                      #235
                      The bubbles could stay at the top. Just sayin...
                      The spring pushes it out until they're installed. I was glad the new ones were plastic.. the old metal ones were a BITCH to remove!
                      • Aptyp
                        • 6584
                        #236
                        my fluid stayed as clear as the day I poured it in a year and a half ago, so that means I didn't leave any air in there, but I see what you're saying.
                        Yeah, I replaced a trailing arm before, because parking brake cable was rusted/fused in place. Such a stupid problem to have.
                        • samiam3356
                          • Jul 2009
                          • 1901
                          #237
                          Parts used:
                          12" 1/8" brake hose
                          So stock
                          e36 m3 front piston 60mm;
                          e36 m3 rear piston 40mm;
                          e36 318ti rear piston 34mm;
                          e36 325 rear piston 36mm;
                          At least it's a move in the right direction and I would imagine it being fairly cheap to do as well.
                          $5 shipped?
                          • greggp
                            • Jan 2011
                            • 17
                            #238
                            Link to doc
                            Saved the link but noticed the site is down. Anyone have this great doc posted.
                            Thanks,
                            • greggp
                              • Jan 2011
                              • 17
                              #239
                              Any chance you could re-post your write up?
                              • Aptyp
                                • 6584
                                #240
                                by popular demand, it's back
