5-lug Setup
This is a sticky topic.
  • hotballs
    • 1155
    #241
    No reason this isn't a sticky. Great writeup. Let's keep it at the top. I also have a pdf copy of your website front page in case it ever goes down.
    • Aptyp
      • 6584
      #242
      there's also another update I need to add to the side.
      European 323ti uses a larger rear wheel bearing, but the same rotor as the 318ti. This is a way to keep the standard proven bearing and to get extra 5mm space in the rear.
      Cool addition by an Indonesian member.
      • BusyMrE30
        • Feb 2011
        • 55
        #243
        Is there a way to fit e36 m3 rear calipers and rotors on an e30 five lug converssion i have plenty horse power and need to stop
        • BigD
          • Jul 2006
          • 1085
          #244
          Why is this still not a sticky? It's like the Bible not being a sticky on a Christianity forum.
          • yanal
            • Jun 2011
            • 248
            #245
            Down again ?
            Sticky:True e36 one touch windows DIY
            1990 M3
            1992 Mtech (S50 + 5 Lug)
            • IanS_in_Oz
              • Jan 2010
              • 75
              #246
              E32 7 series front rotors and E28 5 series front callipers fit....
              BumbleE30 M52 2.8i
              • bmwmech1
                • Jun 2010
                • 1075
                #247
                What about the parking brake? This looks good, but a lot of guys are running their's on the street, so this may not work for a street application, correct? I see the remnants of the parking brake assembly laying on the floor...
                Still good info, though...
                Garey
                • e30guydownunder
                  • Jul 2008
                  • 874
                  #248
                  Hey Ian, did that just bolt on?
                  - Chris
                  Project M42 - 255 @ 19 psi
                  • IanS_in_Oz
                    • Jan 2010
                    • 75
                    #249
                    Garey
                    I'm fitting a hydraulic parking brake....ala drift spec....
                    No, I had to drill and tap the caliper bracket.
                    Conclusion is that it doesn't work too well. Brake pedal travel is too long with the humungous rear calipers, and the rears lock up too soon, even with the bias adjuster.
                    Am going to try some different calipers, possibly rears off an E34 5 series.
                    I have a hillclimb event in two weeks, so I'll put the E36 ti rears back on for that.
                    BumbleE30 M52 2.8i
                    • Aptyp
                      • 6584
                      #250
                      use regular e36 calipers with large piston. That's what made my brakes feel amazing.
                      • e30guydownunder
                        • Jul 2008
                        • 874
                        #251
                        E36 calipers probably won't fit over the thicker front rotors.
                        Ian as you should know, 325/328 E36 and all E46 (maybe not 318i) had quite large vented rotors. I think E36 is in the 280's but E46 is 296/294 ish. Both are 19mm thick so you could use either the E36/E46 calipers.
                        I think you need to make a caliper adapter bracket to cope with the change in diameter though.
                        I used some Toyota Cressida 270x19 discs with WRX single Sliding calipers on the rear of my car
                        - Chris
                        • IanS_in_Oz
                          • Jan 2010
                          • 75
                          #252
                          Thanx for the info Chris. I have an old set of E46 rotors here, and may still have the original rear calipers off the E36...time to go a-hunting...
                          BumbleE30 M52 2.8i
                          • keating786
                            • Jul 2011
                            • 2
                            #253
                            extra drei website failure
                            Hi,
                            I was using the extra drei 5 lug conversion website to do my conversion im still in the process of getting the parts but the website has gone. has anyone got the pages saved by any chance. the help would be appreciated.
                            • Aptyp
                              • 6584
                              #254
                              I will put it back up on Sunday, when I get back home. I've been out of town for a while. SOmeone did say, that they had a PDF file of it saved, though.
                              • Aptyp
                                • 6584
                                #255
                                back up, since the "true" thread was redirecting questions to my e-mail and PM box
