hope all works well. I need to lower mine in the front bad. I called GC with no help.
Do not buy G60 shocks.
Any updates?Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
I hate to tell you that won't work. You absolutely MUST use the Bilstein upper gland nut because it has a built in dust seal.
Also, the Bilstein strut insert needs to be "pinched" only around the exact periphery of the housing, nothing can touch the chrome shaft under any condition. If gland nuts other the Bilstein are used, the strut can slide and gouge the chrome shaft, in addition to being unsealed.
Bilstein has the parts, you need to call them and buy them.
Jay GCHere is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
Ground Control Gallery
The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
Bilstein has collar nuts with external threads that match the E30 shock tubes with dust rings the same diameter as G60 shock shafts? If they do that'd be amazing.
Like I said I drilled out the collar nuts for the G60 shafts. I found some O-ring gaskets that are the exact outer diameter as the inner collar nuts and exact inner diameter as the shafts that I'm using as dust rings right now. I also wrapped the shocks with this thick friction tape I found at home depot to make up the 6mm difference in diameter.
I thought I posted this picture up but I guess not.
It doesn't have an adhesive really, it just sticks to itself. A lot like handle bar grip. They fit very snug. Nothing touches the shafts of course.
I'd love to get those collar nuts from Bilstein if they exist.
I'm holding out on pictures until I get tires on the new wheels.
Some pictures of what I'm talking about:
So all in all, it was a learning experience to say the least.
On the plus side, I can dismantle E30 suspension in the dark in record time now.
Yea, this way takes more work and some modification, but here's my parts list for under $1300:
Bilstein Sport G60 (F)
Bilstein Sport E30 (R)
GC Coilover Conv. kit
M3 Offset CAB's
HD Control Arms w/ all joints
Tie Rods
Sway Bar Links
JT Design rear shock mounts
Rear Mount reinforcement plates
New collar nuts
M3 Sway Bar link tabs
Tape, gaskets, etc
Fabrication
And a much lower range of motion.Comment
that you are
Parallel lines show difference in caster and vertical lines show difference in camber. And this is only from a 5 degree difference, which is amplified when you lower the car and control arms sit flat instead of angled downwards. Enjoy.
On the other note, Mucci, what you're doing will destroy your billies very quickly, because Bilstein collar not is supposed to hold outer casing in, since these shocks are inverted (reason why shafts are so thick). I would go to a junk yard and grab struts from a VW, cut threaded pieces off and weld it to your housings and use bilstein strut nuts.Comment
You mean horizontal lines show caster?that you are
And I'm not sure what you mean about holding the outer casings in. I'm looking to resolve this better then I have currently. Finding a G60 raddo in a yard isn't easy though.Comment
No pics installed on the car yet eh?Originally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
