This is a sticky topic.
  • Naplm00
    • Nov 2008
    • 1573
    #1816
    oh PS that was 2 sets of 4
    so i need to deceide what would work better with the available adapters in 25 and 35 ...i dont want them to poke, i guess i could roll the fenders when i drop the car....
    great!
    thansk for the awesome info
    the only adapters i could find were H&R and they only come in 25mm and 35mm so i guess im goin to have to compromise somewhere
    unless i can find another company making these things i thnk FK does but i cant seem to find one
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
    • stinkydriverx
      • Jan 2008
      • 501
      #1817
      Yo jay i can always count on you for a quick answer
      Specs on the wheels.
      15x8
      With 5" backspacing.
      The e30 is on coilovers.
      im more worried about them rubbing on the coils then the fenders.
      Oh the tires are 205/50's
      Thanks man
      Turbo m30 drift car build.
      500whp or bust.
      http://www.r3vlimited.com/board/showthread.php?t=256525
      • Turf1600
        • 9815
        #1818
        BBS RZ Euro
        15x7 et 20
        I'd like a good tire for DD...good handling in all conditions and preferably something that wears out really slowly.
        Any tips on a tire and size?
        • Philo
          Ich esse kleine Kinder
          • 3334
          #1819
          I just want to check with you so that i am correct but say i have a set of wheels 18x7.5 with an offset of +45 and a backspacing of 6, I would need to run 20mm spacers?
          -tim
          Originally posted by Jordan
          I like the stance
          • vivalegreg
            • Apr 2006
            • 1313
            #1820
            who here runs these XXR 501 16x8 +15?? i just ordered me a set of these since they are pretty cheapo and decent looking....will i need to run spacers on my car to fit properly? i am lowered on some bmp springs with some bilstein sports i believe...also i have some fake wide body fenders on i wonder if ill get away clean...
            what are the spacers really used for? do adjust the sai line to the correct settings when an offsetted real is used?
            edit: ok did some more reading and it seems 205/45/16 are the best sized tired for me to go? if possibly i would like to see if i could fit some wider rubber on there...whats the widest you think i could get away with 225? dare i say 245?
            e30s r kool
            • Mr Two
              • Jul 2008
              • 590
              #1821
              From doing some reading at the start of the thread, is it correct that 17's will generally allow for wider tires than 15 / 16's?
              • Mastrcruse
                • Sep 2005
                • 5340
                #1822
                My guess would be that it has a lot to do with how wide the wheel is then how large the wheel is
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  #1823
                  great!
                  Custom ones are all the rage with the E30-Porsche wheel deal. Do a search for some leads.
                  • Mystikal
                    • 9602
                    #1824
                    15x8
                    Thanks man
                    Sorry for not being that quick, it was the holidays. :p
                    That wheel is ET12, so you'll have quite a bit of room to the suspension. With heavy fender rolling that setup works.
                    • Mystikal
                      • 9602
                      #1825
                      Originally posted by Turf1600
                      BBS RZ Euro
                      15x7 et 20
                      I can't tell if the "fuck you" state is in the snow belt or not.
                      lol, tell me if snow and/or wet is a priority.
                      • Mystikal
                        • 9602
                        #1826
                        20mm is good. 25mm will look better and still not need fender rolling with 215/35/18 tires (but 25mm spacers usually cost a lot more). Those will actually probably clear the struts without spacers, but it'll look really strange.
                        • Mystikal
                          • 9602
                          #1827
                          Lots of 501 guys on here, search under sportmax instead of xxr.
                          They fit perfectly without spacers, actually a nice width/offset combo. 205/45/16 tires are the common choice, as you won't need to do any fender rolling. If you go to a 225/45/16, you'll need to roll the fenders flat and still hope for the best. 245 is pretty much flares only.
                          • Mystikal
                            • 9602
                            #1828
                            Yes it is. This is due to the inclination of the struts on the front suspension (they tilt inwards as you move up vertically). Because of this, you can take advantage of the inner space by having a higher offset wheel, therefore giving you more net space.
                            Most 235/40/17s don't even need fender rolling with the right wheel setup. Like 17x8 ET25.
                            • Turf1600
                              • 9815
                              #1829
                              No snow. Wet is somewhat important but not very. I'm in Texas.
                              • Mystikal
                                • 9602
                                #1830
                                lol, should have guessed that.
                                I just looked at Tirerack, and the news is bad. The two perfect tires for you would have been the Michelin Pilot Exalto (summer version) and the BFG KDW2, but BOTH have been discontinued in your size. That sucks.
                                There are now very few choices for what you want. The BFG Traction T/A is good in the dry/wet and lasts literally forever, but it's not a 10/10ths performance tire. Perfectly fine for a daily and is very competitive in it's class, but it's no summer tire.
                                If you want to give up some mileage the Falken 912 and the Fuzion ZRi are also good choices, and are a bit sportier (especially the ZRi). But they'll easily last half as long or less than the BFG.
