This is a sticky topic.
  • Hboost
    • 11
    #3286
    So can I run 15X7 BBS RS's with a 38mm offset on a 91' 325i?
    Also, what tires would you recommend?
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #3287
      Nope, you'll need spacers. 15mm all around minimum. If you use 15, you can run up to 225/50 all around.
      • Lurker27
        • 821
        #3288
        Originally posted by Mystikal
        What's the wheel width? Early or late model? Suspension setup?
        I have yet to see any 25" tall tire work, I'd love to learn how he did it.
        I assume he'll be OK posting this here, he shared readily and seems like a cool guy. I also googled around and found a track E30 and 1 other using the same setup (star specs on 16x8)
        Originally posted by p0cket penguins
        I am pretty sure that will work, however to get my wheels to fit I had to roll and flare the fenders pretty severely. Good luck
        Chris
        Hey man,
        I saw this thread
        And I was wondering if you had to do anything special to fit them. I have the same tires, and 16x8 et 25 - would a 5mm spacer do me OK?
        Thanks
        Heat gun and baseball bat ready. So you were @ 20 offset? Thanks for the quick reply.
        Have a good one!
        Ryan
        yeah but the car is gutted and it has no weight and its on j stock springs.
        '89 335is +turbo
        • sefb222
          • Apr 2007
          • 1206
          #3289
          Not a chance. Even with a 215/40 you will likely have to roll the fenders.
          hmm.. im running 215s all around now, on DS2s with no rolling, no rubbing, and there seems to be PLENTY of room.
          i definitely dont want to go as narrow as 215. i hate the ones i have now, as they just dont stick.
          Originally posted by Holland
          There should be a restraining order to keep kids 100 feet from that car at all times. Plus execution on the sight to anyone who places a shopping cart within 200 feet of the thing.
          • Hboost
            • 11
            #3290
            Ok, I see. Check this out though. They started out as 15x6 ET38 and the lips were swapped to make the wheels 15x7. Would that change the offset? Also, where do all you guys get spacers?
            Here's some pics of the wheels:
            • Mystikal
              • 9602
              #3291
              Dude, read that over again. He has a gutted and track-built car, sits on springs that have rates in the 4-digit range, AND he had to flare the fenders outward "pretty severely". Pretty much nothing left on the table there, that is well beyond what I call extreme.
              I will still never, ever recommend that tire size. No one here wants to try any of that (rather, all of that - you can't skip a single step there) with their street cars, or even weekend track specials. You're pretty much racing for trophies at that point.
              I mean if you're willing to take it to that extent, you're probably not reading this thread. The hardcore motorsports guys will push the envelope past a reasonable point to gain that extra .5 secs...but that doesn't mean it "fits" in a sense that is remotely applicable to 99.9% of the E30 population.
              • Mystikal
                • 9602
                #3292
                There may be plenty of room, but the centerline of the new setup would be a full 2cm (almost an inch) outward. Combine that with tires that are 2cm wider (almost half an inch on the outside) and you have a scenario where you need about 1.25" more space. You may think you have plenty of room, but definitely not 1.25".
                • Mystikal
                  • 9602
                  #3293
                  Definitely, they are now 15x7 +25, which is ideal E30 fitment. You can run 225/50/15 right off the bat, or narrower of course.
                  • Hey-U
                    • Mar 2008
                    • 560
                    #3294
                    Alpina designed those rear wheels (+28 offset BTW) to fit 225/45 on showroom-fresh E30s. Go right ahead.
                    Thanks for reply. I am running S-Drives and noticed that they only have 225 50 16. Do you think these will work? The car is also sitting on Eibach sport springs.
                    • Mystikal
                      • 9602
                      #3295
                      Wouldn't recommend it, you would have to roll the fenders to fit those.
                      • sefb222
                        • Apr 2007
                        • 1206
                        #3296
                        well, im not opposed at all to rolling or even cutting the fender lip.
                        how wide do you think i CAN go, and avoid destroying my tires? 225?
                        • daniel
                          • 6703
                          #3297
                          roll the crap out of your fenders and put 245/35-17's on there.
                          http://instagram.com/dslovn.drives
                          • mulberryras
                            • 40
                            #3298
                            i got a 91 325ic lowered 1 inch all around i like the wide tires look . i am looking at some 16 rims i am willing to do some fender roll,my question is , what is the best offset and rim size i can use to get the wide tire look? thanks
                            • sefb222
                              • Apr 2007
                              • 1206
                              #3299
                              all the way around?
                              • ExDubber
                                • 29
                                #3300
                                Not too aggressive at all, but you will require stretched tires of course. 205/50 all around is a good start, and you will have to roll your rear fenders FLAT.
                                Thanks everyone! Ill post pictures as soon as they arrive!
