17x7.5 et20, what tire size recommended? some people told me 215-40/17, others 225-45/17. I have 91 325 on billies and H&R sports...
This is a sticky topic.
If I wanted to run e38 Style 5s (filled and redrilled), 16x8 et23, what else would I need to make it work? Do I need 10mm spacers? Do I need to pull any fenders? I want to achieve the same look as the April COTM, Neil's e30.Comment
That leaves my final et coming out to 12f and 10r with the spacers I'm interested in.
Would 185/65 now work in this case with a roll?Comment
1991 318is, H&R pro or race. Willing to do minor fender rolling. I want the most tire possible.
Questions:
1. Can I run Continental race slicks sized 225/40/17 all around (these run wide…near 245 width)? If so-what width/offset 17 (they run square-ish on 8-9” wheels).
2. I want to run the most street tire on n 16s or 17’s. What sizes/offsets to get most tire with my setup.
Thanks!'95 E34 540i 6 speed dd'd and tracked with mods
'88 E24 635CSI 5 speed dd'd and tracked with mods
'91 E30 318is 5 speed...soon to be turboedComment
ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
General knowledge question, what is the size difference between a 205/40/17 and a 215/40/17 in terms of sidewall size. I am pretty low on coilovers and don't want to rub on the back. Anyone with this setup have knowledge?YOUTUBE: AR Perez
- - -If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30Comment
The numbers tell you what the sidewall side is. For example the 40 stands for 40% of the width. So a 205/40 has a sidewall width of 82mm (205mm times 40% (0.40)), and a 215/40 has a sidewall width of 86mm (215mm times 40% (0.40).'95 E34 540i 6 speed dd'd and tracked with mods
I'm about to pull the trigger on ESM 002r 16x8 ET20 all around, but i'm uncertain on the tire selection.
My car is an 89' coupe on IE stg3 race springs/Bilstein sports. I want to minimize stretch (205/45 on an 8" wide wheel still looks OK to my eyes and doesn't seem unsafe, but it's at the limit IMO). I also need enough sidewall to handle the rough roads in WI. How big of a tire can I fit? What's the typical tire for these wheel/suspension specs with disregard to potholes?Comment
Still a bit too tall for the front if you're lowered. I'd recommend 185/60 or 195/55.Comment
