So the gist of it all is that the numbers are just that - numbers.
How to increase throttle response?
I know we've been talking about botched numbers - but look at the Miller graphs:
Even if those numbers are botched a bit (and not measuring from the peaks) - there is a significant difference in the peak numbers when comparing before to after.
The graphs look much different from that link.Comment
You seem determined to convince yourself it's worth the money, so go ahead and buy it. Then dyno test it back to back at the same place, same day.
Otherwise your "butt dyno" will tell you it did something so you can justify your purchase.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Sorry, not really backing my theory, as I'm not well versed on this - more so just asking why.
The custom tune sounds like it would be worth the money. I'll have to try to find someone reputable around here.Comment
exactly what we were trying to tell you, the quoted HP gain is not at the PEAK hp, it's at the point in the graph where the HP increase is biggest. So it may be +20hp, but it's not 168hp + 20hp = 188hp.Comment
It is cheaper than a reman bosch afm.Comment
No I know, I can see that they're measuring from the greatest points of deviation. I was referring to the fact the deviation between the peak of before and after is much greater then 1.5hp in the Miller graph - since someone was referencing the MarkD chip as only giving you a 1.5 peak hp increase.
...but this is just going to go full circle to the "different dyno's, different motors" argument.Comment
A custom tune is always the way to go, but you saw the relatively small gains to be had on a stock motor. Personally I'd live with and either go stand alone on a M20 build or go 24v.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
I better spill here. Miller is a well respected tuner and I have seen a lot of their equipment run on the track. I am not all that technically inclined as I drive them but I don't really like getting greasy so I will not argue specs but I can assure you they are at least as on the up and up as any other tuner.Comment
I'll vouch for this, the throttle response of James' M20 is intense. He's also got a new throttle cable, too. I could feel a definite difference in his pedal response/feel in comparison to mine, it was much smoother.Comment
i thought i'd chime in here. i have a 2.7 stroker with seta pistons, mildly p&p head "i" head, 292 cam, shortie MSDS headers, cat replaced with a 2 1/4" magnaflow muffler 2" mid section and a stromg cat back, split second ford MAF conversion, split second ARC-2a piggy back, Dbilas ITB's, and cone filter with a kamotors heatshield.
the throttle responce is awesome, except off idle from a stop. if you don't blip the throttle to get the idle up a little there is a little hesitation or small stumble first, then it goes just fine. i think that this is caused by the motronic 1.3's out dated engine controls and them trying to deal with the big cam. i have done a lot of playing with it and just can't get that stumble completely gone. standalone may be the only answer to that, but htat was planned as a future mod for the M30B3.5 S/C swap on the car.seien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
So now I have the Miller MAF Gen III kit in my hands to play with.
I'm not so much after increasing throttle responce as wanting to try some things out that are not possible with an AFM but I'll install it first on my 325 and see what we get straight out of the box first.
I can tell you one thing right off the bat, my software guy says he hasn't seen anything quite like what's on Millers chip here.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".Comment
Shoot, should've gotten the W.A.R. chips with it.
W.A.R. chip = the BMW equivalent to Hondata (from what I have gathered from the BF.c Forced Induction forum)My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
