So I designed a zero lag turbo charger
  • slammin.e28
    שמע ישראל
    • 12054
    #241
    I'm going to hook up my AC compressor to my intake for MOAR AIR AT THE PUSH OF A BUHTTTOOOOONNNNN!!!
    • Kershaw
      • 11822
      #242
      how about hooking up that electric supercharger to regenerative braking.
      on a track it could be helpful with all the hard braking and hard acceleration you do.
      AWD > RWD
      • u3b3rg33k
        • Jan 2010
        • 2452
        #243
        KERSBOOSTVTECYO?a
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
        • Kershaw
          • 11822
          #244
          Originally posted by u3b3rg33k
          KERSBOOSTVTECYO tm
          good name. Lets get this ball rolling.
          AWD > RWD
          • Turf1600
            • 9815
            #245
            How did I just now see this thread?
            FWIW my guess is on a hot cam with tons of valve overlap. More flow between intake exhaust = higher velocity exhaust gasses = faster turbo = more boost = infinity power!!!
            • u3b3rg33k
              • Jan 2010
              • 2452
              #246
              I got it! suuuper hot cam, and an idle of 3000rpm.
              fawk lagggg.
              • flyboyx
                • 8371
                #247
                jesus pat, what are you doing up at 5:50am? you work to hard.
                Gigitty Gigitty!!!!
                • Turf1600
                  • 9815
                  #248
                  I work from 6p-6a 3 days per week.
                  • CabbE30
                    • Aug 2009
                    • 2358
                    #249
                    good times
                    • einstein57
                      • Jun 2007
                      • 10780
                      #250
                      Originally posted by e46s54dr
                      Compound turbos?
                      Twin Charging?
                      Misfire systems? - Throttle bypass or inlet bypass causing unburnt air/fuel to ignite when it hits the exhaust manifold and spool the hot side. (works well, but it is very brutal on the engine and turbos)
                      How about a small electric or mechanical compressor used to pressurize an air tank used to spool the turbo?:D lol
                      Either way, youre trying to reinvent the wheel here. This technology has been around forever so I highly doubt you will come up with a SIMPLE solution.
                      None of those. I was thinking more along the lines of regenerative braking but for compressed air. Fewer moving parts. You probably won't need more than an instant for the extra air to get the turbo back up to speed.
                      www.gecoils.com
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        #251
                        Except for the air compressor, lines, tank, solenoid valves, and control system you'll need to add...
                        • einstein57
                          • Jun 2007
                          • 10780
                          #252
                          Like I said too heavy for a race car and too expensive for a street car to save 2 seconds of delay.
                          www.gecoils.com
                          • $hane
                            • May 2011
                            • 366
                            #253
                            Word on the street is that subaru is working on a new 1.6L motor that is fitted with an exhaust turbine that generates electricity and powers an electric supercharger. 1.6L puts them back into WRC.....
                            • Kershaw
                              • 11822
                              #254
                              that's an interesting way to do it.
                              AWD > RWD
                              • u3b3rg33k
                                • Jan 2010
                                • 2452
                                #255
                                I've seen it done before - somewhere on the internet. IIRC each side can handle around 9HP.
