The Official 'Craigslist find' thread - awesome & awful (eBay, Kijiji, etc.)
This is a sticky topic.
  • e30RS
    • Mar 2019
    • 437
    #6196
    Impressive, in ten years I am at seven.
    • Aleman
      • Mar 2012
      • 1608
      #6197
      Not sure on the price, but I have doubts about being able to build it yourself for much less than the asking. In my mind, a non-M3 E30 really doesn't get much better than this. Mic drop.
      1990 BMW 318i Touring - S54 Swap - 6 Speed Manual - Italian Import - $35000
      Odometer Reading: 360 Miles (Actual Miles On Shell Unknown)
      Title: Clean / Clear - Original (Clean Carfax)
      Engine: 3.2L 6 Cylinder (S54)
      Transmission: 6 Speed Manual
      Drivetrain: Rear Wheel Drive
      MPG: Unknown
      Exterior Color : Sterling Silver Metallic
      Interior Color : Alpina Cloth / Gray Carpet / Black Headliner
      Build Date: 09/28/1990
      VIN: WBAAG71080ED82692
      Yes, you read that correctly. E30 Touring with a S54 & 6MT from a E46 M3. This is a very rare chance to own such a beautifully executed project. No expense spared and no shortcuts taken. Built by a local enthusiast. Get in and enjoy.
      The silver paint is in great condition. No rust, rot, fading. All panels are straight and look excellent. A/C blows cold & heat blows hot. Everything works as it should and this car does not possess the typical negative qualities of a swapped car. No warning lights, everything looks untouched and it would be very easy to convince someone unfamiliar with the platform that the car came this way from the factory.
      Background: The vehicle was originally a Italian market vehicle & imported to the US from Italy. Donor car was a rear ended 2005 BMW M3 Convertible w/ 65k Miles. Both the S54 and 6 Speed Manual transmission were used from this vehicle. Below is a list of maintenance, modifications, improvements, and wizardry that made this swap so clean and tidy.
      Options: Shadowline Trim, M Tech II Steering Wheel, E46 M3 6 Speed Shift Knob, Central Locking System, Fold Down Rear Seats, Cargo Cover, Manual Sunroof, Roof Antenna, Power Steering.
      Engine / Transmission / Driveline:
      -NEW Rear Main Seal & Constant Pressure Valve (CPV)
      -NEW Clutch Kit w/ Pressure Plate, Release Bearing & Pivot (E46 M3)
      -NEW Clutch Master Cylinder (E30)
      -NEW Slave Cylinder (E46 M3)
      -NEW Oil Pan & Oil Pump (E34 M50)
      -NEW Transmission Input, Output, & Shifter Seals
      -NEW Oil Cooler (E30 Unit Installed In Original Location To Work w/ S54)
      -NEW Walbro High Pressure Pump
      -Kassel Performance Conversion Harness & Tune
      -NEW K&N Cone Filter & Castro Motorsport Enclosed Airbox
      -NEW UUC EVO3 6 Speed Shifter
      -NEW Axles
      -NEW Custom Driveshaft w/ Support Bearing & Guibo
      -NEW Mishimoto Aluminum Radiator
      -NEW Spal Cooling Fans (Connected OEM Fan Switch)
      -NEW Condor Speed Polyurethane Engine & Transmission Mounts (Idle Vibration)
      -Front Subframe & Transmission Bracket Reinforced w/ Garagistic Kit
      Suspension / Steering:
      -H&R Lowering Spring (Specific for Touring Model)
      -Koni Adjustable Shocks w/ New Mounts
      -NEW 22mm Front Swaybar w/ Bushings
      -NEW 19.5mm Rear Swaybar w/ Bushings
      -All Suspension Bushings Replaced w/ OEM Rubber
      -NEW Front Control Arms w/ Treehouse Racing Control Arm Bearings
      -Rebuilt Steering Rack w/ NEW Tie Rod Ends (E36 M3)
      Brakes / 5 Lug Swap:
      -NEW Vented Front Brake Rotors - 300mm (E46 328)
      -NEW Vented Rear Brake Rotors - 296mm (E46 328)
      -Front : IRP Spindle Sleeves, Caliper Brackets, & E46 Front Wheel Bearings
      -Rear: Z4 Hubs, SRS Concepts Caliper Brackets, & E30 Rear Wheel Bearings
      -NEW Stainless Braided Brake Hoses
      -NEW Brake Booster (Porsche 924)
      -NEW Brake Master Cylinder (E34)
      -BBS RZ 16x7.5 Wheels w/ Matching Painted Spare & One Extra Wheel
      -Bridgestone Potenza RE040 215/45R16
      Interior:
      -Uncracked Dashboard In Immaculate Condition
      -NEW Headliner
      -E30 Sport Seats Recovered In “Alpina Cloth” (Creative Design Kit)
      -MPH Instrument Cluster Installed w/ New Odometer Gears
      -Manual Windows & Sunroof (All Work Excellent)
      -Keyless Entry On Two Front Doors
      -Factory Headunit w/ Bluetooth Kenwood Amp (To Stream Music via Bluetooth)
      -Premium Aftermarket Speakers
      -Blaupunkt Self Powered Subwoofer (Hidden - Passenger Side Compartment In Cargo Area)
      Climate Control:
      -Factory A/C System Installed
      -Heater Box Under Dashboard
      -NEW A/C Condenser
      -NEW A/C Receiver Drier
      -NEW A/C Evaporator
      -NEW Custom A/C Lines
      -USED E36 Compressor
      Exhaust:
      -Stainless Steel
      -Factory Headers w/ Decat
      -Magnaflow High Flow Catalytic Converters
      -Borla Center Muffler
      -Dynomax Glass Pack
      -Magnaflow Rear Muffler
      R135 /// 1990 Alpinweiß II 325is
      └┼┼┘ /// 1993 Black/Black Convertible (sold)
      ..24
      • Powling
        • Jan 2015
        • 1291
        #6198
        Wasn't that touring just on BAT...can remember if it was for sale or featured in an article there.
        Steve • Toronto
        1991 318is • Brillantrot
        Build Thread
        • Staszek
          • 2533
          #6199
          Not sure if it was on BAT or not but the Harness to do the swap was Andrew's
          • Powling
            • Jan 2015
            • 1291
            #6200
            Here it is.
            Learn more about Dream E30 Build: Factory-Style S54/6-Speed 1990 BMW 318i Touring on Bring a Trailer, the home of the best vintage and classic cars online.
            Steve • Toronto
            Build Thread
            • e30RS
              • Mar 2019
              • 437
              #6201
              Too bad when it sells we won't get an alert on the final sale price.
              • laidback93
                • Nov 2016
                • 435
                #6202
                This Touring is sure making the internet rounds.
                R3V
                BAT
                eBay
                And now Jalopnik picked it up for NP or CP.
                It's currently a strong "crack pipe" due to the high price of admission.
                90 Bronzit 325is
                16 Black Sapphire 340i M Sport
                • Aleman
                  • Mar 2012
                  • 1608
                  #6203
                  R3V
                  BAT
                  eBay
                  That's a pretty high price, admittedly. But when you consider the going price of E30 M3's, this, to me, has a way higher fun-to-dollar factor.
                  - It's the ultimate sleeper.
                  - People at cars & coffee will lose their shit when they see this.
                  - You can do burnouts for days
                  - It'll still haul the family of 4, plus the dog and luggage on road trips.
                  - I'm sure it sounds great too.
                  Only bad thing, is that, like most new cars, it makes no financial sense. It's not going to GAIN in value like an M3. Ooh but it would be so much fun to own though :D
                  ..24
                  • laidback93
                    • Nov 2016
                    • 435
                    #6204
                    You make a strong case here for someone that isn't a wagon guy like me.
                    90 Bronzit 325is
                    • LateFan
                      • May 2013
                      • 4432
                      #6205
                      Nice Price or Crack Pipe?
                      $35,000 swapped Touring.....
                      Today’s Nice Price or Crack Pipe E30 isn’t just an amazingly desirable ride owing to its E46 M3 drivetrain, it’s also a learning opportunity since its manual windows will let you demonstrate to kids what it means to “wind them up.” Could that two-fer be worth its new car price?
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3430
                        #6206
                        That's a really nice looks car, seems to be done right. However, if I wanted something with an S54 in it and had $35,000 I'd probably just buy a clean E46 M3. I'd rather have a V8 in the wagon anyway potstir
                        IG @turbovarg
                        '91 318is, M20 turbo
                        • e30RS
                          • Mar 2019
                          • 437
                          #6207
                          Good point on the clean e46 m3. And a chevy small block 350 in the touring would be wicked.
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3430
                            #6208
                            Too much weight, gotta be aluminum block if chevy or 302 windsor if ford.
                            IG @turbovarg
                            • DrJosh
                              • 2011
                              #6209
                              Throw it up on bat and let the bidders decide.
                              Originally posted by Sonny
                              I am a meme for our community.
                              • roguetoaster
                                Biggus Tippus
                                • 7830
                                #6210
                                Looks like $3.50 to me.
