5-lug wheel hubs fro e30's....
  • Victell
    • 1083
    #46
    interested, sub'd
    • dsm2002
      • 193
      #47
      DBA site has a catalogue with most specs: look for dbacat_7oct2010_v2.pdf.
      Also a search option to locate a rotor by dimensions.
      • Bryan///
        • Nov 2011
        • 290
        #48
        Please decide soon before I buy 4x100 wheels :)
        '01 e46 330ci blk/blk (GF stole from me)
        '90 e30 325i Traded
        '95 e34 540i/manual swap (electric fire)
        '96 miata M-edition (not quite an e30 so i got below car)
        '93 Audi Urs-4 (like the e34 but still not an e30)
        :hitler:
        • Roysneon
          • 4505
          #49
          I'm just saying, I'm going to be completely replacing my entire suspension soon, and if 5 lug was available reasonably soon I'd wait for it. An E36 spec offset in front that presses in to the E30 spindle would compliment stock E36ti rear. Non M E36 front brakes would allow us to use all factory E36 calipers and rotors and have the same offset as the stock E36 compact rears, sourcing parts would be easy and there are lots of nice E36 fitment wheels we could run.
          Originally posted by mbonanni
          I am a pursit now.
          • poopin04
            • Jul 2010
            • 1396
            #50
            Originally posted by JiXer
            ^^^ I've heard that before but honestly don't know what it means??
            EDIT: oh, wait. I get it. Subscribed to post to watch progress, Im guessing?
            LOL yes, I'm sub'd to watch the progress of this product in the making and hopefully one day it comes to reality and I can afford it.
            Click here to leave me feedback on our transactions. :p
            • JiXer
              • 620
              #51
              To clarify a couple things, I am not interested in fitting the biggest brakes possible under an e30. As an experienced e30 race car driver I can tell you with 100%$ certainty that massive brakes are not at all necessary on an e30. I run stock rotors and really good brake pads on a 2400 car with aero and I still get in to the ABS. With the ABS turned off, I could make use of larger brakes, but I don't think for a second that it would be worth the additional unsprung weight that e36 calipers and rotors would add.
              I know that being able to run a larger variety of wheels and the esthetics of bigger brakes are the appeal here, but I just wanted it to be known, that I am not looking in to this b/c I think the e30 braking system is inadequate.
              Point 2, don't be in any sort of hurry to see these things. This was simply a feeler to see if it made sense financially and to get public opinion on the tech points that I mentioned. I have access to the brake rotor and caliper information too, but I have not had a chance to research it. There are shit-tons of 5 lug rotors out there and I am confident I can find one that will sit in there just right and make use of a light weight, affordable, readily available caliper. My only concern there is the adapter bar which I really want to avoid.
              Point 3, the e30 M3 hub is a real possibility, but if the center bore and offset numbers don't make sense, then that will be ruled out. I was even thinking that the e36 rea hub would work because the e30 and e36 use the same wheel bearing. However, just off the top of my head, I believe that the splined section of the axle is a different size and this has likely already been explored many times by others having the same thought.
              J. Farina
              Yeah, thats me kicking up all that dirt!
              • craz azn
                • 749
                #52
                I've tried this... however I never did try to stick an E30 axle spline into the E36 hub... but it wouldn't have worked anyways because the E36 rear hub was very shallow, its offset was too far inside and it was hitting against all of the ebrake mechanism. The only way to run an E36 rear hub is to ditch all the ebrake jazz, and run a spacer in behind the disc to the hub to push the disc out far enough so any normal disc won't run into the backing plate. Again, assuming the halfshaft spline is the same lol.
                Rippin' Proper | Youtube | Vimeo |
                • FSUJBP
                  • Apr 2008
                  • 461
                  #53
                  Originally posted by nrubenstein
                  Why would you not want a 72.56 hub bore? What wheels do you get access to with less than that? It seems utterly stupid to force everybody to get hubcentric rings to accommodate unlikely wheels.
                  Unlikely wheels? My reasoning is that you can get very nice and reasonably priced wheels from vrwheels or memoryfab or numerous other JDM importers. Those wheels are likely to come in more narrow centerbores. Many of them can be redrilled easily to accommodate a 5x120 bolt pattern. I don't like the idea of boring the centerbore AND redrilling a wheel, but that's just me.
                  My reasoning behind the smaller diameter centerbore is to allow for more wheel options and to allow for more people to get into quality wheels at a reasonable price.
                  • StereoInstaller1
                    GAS
                    • 22679
                    #54
                    Allows many options within the stock BMW wheel catalog as well. 72.56mm is a winner in my book.
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • Pac1373
                      • 1746
                      #55
                      I honestly hope you crack this "Mystery" and are produce these for about the cost you stated.
                      if so I am in as well.
                      Originally Posted by ACMF74
                      i clicked on this cuz i saw p3nis
                      • Kershaw
                        • 11822
                        #56
                        while we are all in dreamland, i'd like these for an ix as well.
                        and please include the complimentary unicorn.
                        AWD > RWD
                        • flyboyx
                          • 8371
                          #57
                          here is a comparison pic of e30 rear hub to e36 rear hub. as posted by craz azn above, e36 rear hubs are not viable to replace the rears on an e30
                          Gigitty Gigitty!!!!
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            #58
                            cant believe i missed this. fwiw i would be in for a set 100%
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • 323iNathan
                              • 232
                              #59
                              Interested also. If this gets going I know there'd be some local interest too.
                              I spoke with a few guys who also thought about the possibility of using e28 hubs with a little modification on the front. I haven't had a look to see the specifics, but you could maybe have a look into that too? - They'd surely allow a lower offset and more dissshhh! :D
                              • george graves
                                • 20003
                                #60
                                Why that magic number? Just wondering.
                                Originally posted by Matt-B
