The Welding Thread
-Christian
'37 Chevy pickup, the über projectOriginally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list. -
I actually did a bit more work on this hooptie today. It's a 89 with a M30b35 swap.
Untitled by ericandshovin, on Flickr
The previous exhaust was complete shit, so we found an E32 in the yard with the cat cut off right at the X pipe. I trimmed it down into a y-pipe, then crushed this 3" manderal bent stainless into an oval to fit.
this went into a V-band clamp (cannot get it to stop leaking, ugh)
then a 18" magnaflow muffler, 3" in, dual 2.5 out. From the muffler the dual 2.5's take a right turn and head straight out to freedom. It's loud, very very loud!
As you can see in the photo above, there is only one hanger holding the exhaust up. We ran out of time at the hobby shop on base ad had to finish up with just a couple tack welds. Unfortunately, the tacks quickly broke ad the muffler dragged on every little thing. This was after 2 days of driving.
So today's project was to fix the leak and add more hangers. The muffler was actually quite easy to repair, a bit of hammer and I was ale to lay down a nice bead. SOrry it's out of focus.
And then added some hangers. There is now a total of 4 hangers holding the exhaust up... I don't thing it will be moving much!
Eric, were you back purging? It looks like on that v-band you blew a hole, and the bead looks awfully grey. Stainless likes to be cold and loves argon.
I finished my exhaust over the past two days and I'm pretty happy with it. I can't wait for a machine with pulse at my house, straight TIG is such a tease when you know you could pulse and lay dimes... At least I got a permanent corner in the detached garage :)
IMG_0468 by Los Pantelones!, on Flickr
Test piece...
IMG_0463 by Los Pantelones!, on Flickr
I made some purge caps that were much better than aluminum foil...
IMG_0484 by Los Pantelones!, on Flickr
IMG_0470 by Los Pantelones!, on Flickr
IMG_0471 by Los Pantelones!, on Flickr
IMG_0472 by Los Pantelones!, on Flickr
IMG_0479 by Los Pantelones!, on Flickr
IMG_0475 by Los Pantelones!, on Flickr
Done
IMG_0480 by Los Pantelones!, on Flickr
And checking for full pen, and gas coverage... ;)
IMG_0485 by Los Pantelones!, on Flickr
No back purging. I rent this little Lincoln 175 from the auto hobby shop on ft. Carson. I can't really modify the setup besides changing out my torch consumables.
Grey'd out like that is usually from too being too hot, but I had it down to almost no puddle and it was still gray! I talked with another guy who has welded stainless from silicone intakes, and he thinks that whatever the Chinese put on it to give the pipe that mirror finish causes the welfare to to not color like normal.
If you look at the other welds that are magnaflow to wire hanger, they have the normal salmon color. No change in any way other than base material manufacturer.
I find this learning experience fascinating!
Sent from my iPhone using TapatalkComment
Re: leaky vbands, I welded up two 3" T304 vibrant clamps (MIG) and they seal fine. I feel like the only real trick is to weld it with the two flanges/clamp all tightened up.Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
Just found this thread. Haven't done a whole lot of welding myself, just sheetmetal work while fixing rust on my cars. Planning on picking up a tig welder to make a turbo m30 manifold as well as an aluminium intake manifold for the s38 throttle bodies I plan to use with it. I follow several welders on IG and I'm obsessed with tig welding.
I saw there was some earlier talk about brazing. I've been following a guy on IG for a while now who is kick ass at brazing.
230 likes, 13 comments - Harry Kam Erskine (@kam_fab) on Instagram on June 15, 2015: "Norton featherbed rear gusset and shock mount.. #brazporn #bronzebrazing #nortonfeatherbed #norton"
260 likes, 15 comments - Harry Kam Erskine (@kam_fab) on Instagram on June 12, 2015: "On your Tig welder your laying one dime at a time... When laying molten brass with an oxy torch, ..."
ส็็็็็็็็็็็็็็็็็็็็็็็็็Originally posted by blunttechI need you to exfoliate my ballsack
Saw this on tv tonight. Made me lulz
And yes the turbo functioned hahaComment
https://instagram.com/p/xkiEh5m1l2/
You can tell the welds in the background is were I started and then you can see where I got the hang of it hahaLast edited by nomansland92; 10-29-2015, 08:27 AM.Comment
I need a bottle.
Sent from my iPhone using TapatalkLast edited by Eric; 10-29-2015, 03:41 PM.Comment
That's awesome and you'll love using it! I just bought my first tig last winter and built my tw turbo mani with it for my first project. Definitely a huge learning experience but I plan on building anyone just because well I can haha.
Instagram @rebellionforgeComment
At work I built a mobile base for my band saw, and it was interesting to weld. I've never TIG'ed anything over 3/8th's, and that was a long time ago... I'm a 16ga type of guy, and I now see why guys get those perfect dimes every time on thicker material. My boss said it would be more difficult than 3/8th's, but he felt I would do okay, and he was right ;)
IMG_0527 by Los Pantelones!, on Flickr
Mines on the left, his is on the right...
IMG_0528 by Los Pantelones!, on Flickr
Mine :p
IMG_0531 by Los Pantelones!, on Flickr
IMG_0532 by Los Pantelones!, on Flickr
His... butts were harder than fillets
IMG_0529 by Los Pantelones!, on Flickr
IMG_0530 by Los Pantelones!, on Flickr
1/8th" tungsten and filler if you were wondering ;DComment
