The Welding Thread
  • Wschnitz
    • 8089
    #301
    The ITB's threw me off on your engine, thought it was like a weird S54 12v mix till i saw the trumpets on the table.
    willschnitz
    • ForcedFirebird
      • Feb 2007
      • 8300
      #302
      Customer car, but yes, ITB m20. Came in to get a 2.8 bottom end swap. :D
      john@m20guru.com
      Links:
      • Exodus_2pt0
        • 5943
        #303
        Nice looking cradle! That's probably what I miss most about working at dealerships, is the drivetrain cradles. God those made life easy.
        No E30 Club
        • doorman
          • Mar 2015
          • 360
          #304
          Update on the table
          Before and after a few trips thru my dads planer.
          I love the color of this reclaimed wood!!!
          Douglas Fir I believe.
          One set of legs fabbed up.
          Still needs to be ground down and spatter cleaned off.
          New toy. I got tired of digging the big Miller 185 outta the back of my truck!!!
          • Northern
            I like cupcakes & sh!tboxes
            • 5192
            #305
            Originally posted by red2.4srt
            Did you change the polarity when you switched from FC to 70S-6? All of Lincoln's smaller MIG's come setup for FC from the factory and thus are set to electrode negative (ground hooked to + terminal on the welder). They weld like shit if you switch to solid wire and don't change the polarity to electrode positive (ground hooked to - terminal on welder).
            The liner you'll need is just a standard Tweco style 35-40-15 liner for .030-.035 wire. We sell them for $9.xx IIRC?
            Yeah I switched to DCEP when I first got gas. Never bothered to switch it back even when burning up flux core wire. I'll pull the liner out to double check, but I've seen some half decent beads I made with it a few years back, and I certainly can't seem to do that recently.
            Originally posted by priapism
            Originally posted by shameson
            • JGee
              • Jul 2011
              • 264
              #306
              ^ No way that liner should be worn out. I have had tips last longer than that. Slide the wire through it by hand feeling for snags. If the liner is bad most likely it will be right at the end. Check the tip too.
              Also a crappy ground clamp will give the same symptoms. I recently coated the jaw of my ground clamp with copper (brazed it) and it is working much better now. GL
              HIK Fab
              • doorman
                • Mar 2015
                • 360
                #307
                Base for the table is welded up.
                I even beveled the bottoms of the legs to make them less "chunky" looking.
                Now I need to clean the welds/spatter and let the wife decide on the finish.
                She seems to be leaning to bare steel.
                • pantelones
                  • May 2011
                  • 533
                  #308
                  Originally posted by trippmann
                  Is anyone here still using a torch to weld? I just picked up a rig so I can cut and heat stubborn parts, but it came with welding tips as well. I've been experimenting but still don't really know what I'm doing in the least.
                  :giggle:
                  For TIG classes you more than likely will take gas welding first... My teacher said they started doing this to "weed out" the ones that were never going to make it in TIG.
                  It's not pretty, but it's not that hard either... I think there was something funny with our filler rod; every bead I did without it almost looks like TIG, but when I was using filler it looked like poop I learned later on that I was running the wrong tip# and too hot so that may have been part of it.
                  IMG_0605 by Los Pantelones!, on Flickr
                  The piece on the bottom is two plates edge welded together... My teacher liked that one :up:
                  IMG_0607 by Los Pantelones!, on Flickr
                  This was one of my two final projects... It was supposed to be a handle to hold a DSLR camera, but I never used it haha
                  IMG_0608 by Los Pantelones!, on Flickr
                  IMG_0609 by Los Pantelones!, on Flickr
                  I also saw one of my dads gas welds that looked pretty good. He said it was beveled and multi-pass with 347ss rod... Probably a 20+ year old weld too...
                  IMG_0610 by Los Pantelones!, on Flickr
                  And if you're wondering that is for an old drag-racing Borg-Warner 4-speed ;D
                  IMG_0611 by Los Pantelones!, on Flickr
                  A man chooses, a slave obeys... Would you kindly?
                  • Exodus_2pt0
                    • 5943
                    #309
                    Got a Hobart Handler 140 for free the other day. It was getting tossed out! Needs a new gun, and voltage switch, but does power up, feed, and weld!
                    I can't wait to get our garage, I mean house. For now this guy is going in my shed along with all the other crap I've been collecting in preparation for a work area.
                    No E30 Club
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #310
                      Hobart makes a great machine. I love my 190. Parts interchange with Miller, so the gun and switches are readily available.
                      john@m20guru.com
                      Links:
                      • Ohgeemee
                        • Aug 2015
                        • 76
                        #311
                        It's interesting seeing this thread and cool.. I've been wanting to try since I deal with welding regularly 👍
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #312
                          Originally posted by pantelones
                          :giggle:
                          This makes me want to setup my torch and dink around in the garage with it again!! There are some really impressive welders out there that do amazing things with this process.
                          I'm trying to find the guy on IG again but here is some of the frames he builds. All torch brazed.
                          Instagram @rebellionforge
                          • Northern
                            • 5192
                            #313
                            My fear is more about either corrosion or contamination of some kind.
                            My ground clamp is the normal lincoln one with the copper braid that runs between the two sides, but I flip it forward and let the clamp bite it into the surface. I don't think it gets much better than that.
                            • pantelones
                              • May 2011
                              • 533
                              #314
                              IDK where Ironfreak saw those, but these are all augnetagious first pass, then si-brz or nickle for the second. I plan on doing the same for my motorcycle frames... All raw with no post treatment other than wipe down with 99% alcohol and clear-coat. Few photos of what I want to achieve...
                              • gte175x
                                • 150
                                #315
                                What's up with the "Men Only"???
