The Welding Thread
  • IronFreak
    • Dec 2012
    • 3702
    #316
    Originally posted by pantelones
    http://www.silverstonesuperbikes.co.uk/xr69_5.html
    IDK where Ironfreak saw those, but these are all augnetagious first pass, then si-brz or nickle for the second. I plan on doing the same for my motorcycle frames... All raw with no post treatment other than wipe down with 99% alcohol and clear-coat. Few photos of what I want to achieve...
    AAAH see i didn't think that frame looked quite right. I'll have to find the images I was talking about and post them up sometime.
    Instagram @rebellionforge
    • doorman
      • Mar 2015
      • 360
      #317
      The Welding Thread
      Finished the table and put her in the living room.
      Imagine the room perfectly clean and not shitted up by a four year old!
      Wife thinks leaving the shelf off the bottom may look the best. Gonna run by my dads soon and pick up the wood anyway and mock it too see what she thinks.
      • marshallnoise
        • Sep 2013
        • 3148
        #318
        That looks rad! I have an idea for a home theater, ps3, receiver stand that would fit perfect beside my fireplace. I would have to fab it because it is an odd dimension and everything is too wide. I love the color of the wood.
        Si vis pacem, para bellum.
        New Hawtness: 1995 540i/6 Claptrap
        Defunct too: Cirrusblau m30 Project
        Defunct (sold): Alta Vista
        79 Bronco SHTF Build
        • doorman
          • Mar 2015
          • 360
          #319
          That's the great thing about people that work with their hands. Give us some material, dimensions, tools and we make anything for anywhere!
          The wood was true 2x6 that was reclaimed. When it came outta the planer I knew that I wanted it too be as close to its natural color as possible.
          I think my dad said it has some boiled linseed oil or tongue oil and a matte finish clear on it.
          • JGee
            • Jul 2011
            • 264
            #320
            Very nice job the table! Glass maybe a good option down below.
            HIK Fab
            • doorman
              • Mar 2015
              • 360
              #321
              Thanks bud!!!
              We replaced all our glass tables with other solid sufaces......4yr old+glass=no bueno!
              • Northern
                I like cupcakes & sh!tboxes
                • 5277
                #322
                I've recently been thinking about upgrading my lincoln Mig Pak 10 to a mig pak 140. Just checked canadian tire and it's on sale this week for ~$500. Any thoughts on whether it's worth it? I could probably sell my Mig Pak 10 and recoup ~$300
                Alternatively, the Mig Pak 180 comes on sale for ~$600 every so often, but I'd need to keep my 110v mig as well to use where I don't have access to 220v, and I don't think I'd really run into a situation where I'd weld something thick enough to need the extra juice... I think the 140 is good for 3/16" or 5/16" with flux core wire as it is.
                Originally posted by priapism
                Originally posted by shameson
                • marshallnoise
                  • Sep 2013
                  • 3148
                  #323
                  Not great pics, but my little Eastwood 135 Mig works great.
                  I needed to clean up the metal a bit more before doing this, but I was impressed.
                  • McGyver
                    • 4637
                    #324
                    I finally got around to fabbing up a transmission brace so my g265/6 will work in my e30 with the straight trans mounts instead of requiring the angled mounts for the e30 m3 brace.
                    It took longer than I expected and didn't come out completely straight, but is pretty good for using a handheld cutoff wheel and lining it up on uneven concrete.
                    I think the next step is to get a chop saw so I can cut good 45 and 90 degree angles. Any recommendations a hobbyist level saw to do mostly exhausts and 1 inch tubing?
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #325
                      just look of CL for a friction saw. you can find one for sub $100 no problem. the next best thing is the cold saw that Dewalt makes, that's what I'm stashing for. if you;re lucky you'll see them pop up on Amazon for $5-600
                      • McGyver
                        • 4637
                        #326
                        Does a "friction saw" go by another name? Nothing called a friction saw is popping up within 100 or so miles.
                        I just need something sort of portable and capable of giving me good angles. (Tools are stored in the basement and have to be carried out to the covered concrete work area) Based on that, why wouldn't something like a Dewalt D28715 work for me?
                        **EDIT**
                        Ok, from a little poking, it looks like an "abrasive cut off saw" refers to a giant 14" cut off wheel mounted on a stand (a "chop saw"), whereas a "friction saw" rotates at a much higher speed using a metal disk to slightly melt the steel and then scrape away the steel. Do I have this correct?
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #327
                          Abrasive cut off saw is another term.
                          john@m20guru.com
                          Links:
                          • trippmann
                            • Dec 2012
                            • 118
                            #328
                            So i went and picked this up a few days ago :D
                            Originally posted by unloadedak
                            It's brand new. I've gripped the shaft a couple times and that's about it.
                            • doorman
                              • Mar 2015
                              • 360
                              #329
                              Doing some welding/fab work today
                              Started with this today.
                              Underside framework of a dock plate at a meat packing plant. Temp brace the unit open, torch bent shit out.
                              Measure everything up for square/etc.
                              Almost finished with reassembly. Taking a short break now.
                              • Northern
                                • 5277
                                #330
                                I think I just clued into why I always had such a shit time with my old mig. I've been welding on 15A circuits the whole time, and often with an extension cord, not always a good one either.
                                I'm running a dedicated 20A circuit to my workshop now, and I picked up a 12GA extension cord for when I absolutely need to do more than just tack something outside.
                                I really think it'll make a difference.
