300HP E30 Build-Help needed!
  • BMW012
    • Mar 2016
    • 10
    I'd like to build an E30 coupe.My goal is about 300 WHP.I wouldn't want to go over 2 liters in engine displacement because of a high tax in my country.That's a pretty big problem,given the fact that most of BMW's performance oriented engines are 2.5-3.5L.I understand that i'll need a turbo.My budget is 15000 Euros,max.Also,i don't want to run a 100 shot of nitrous to get power.I want a constant,reliable,300 WHP,because it will be my daly driver.So if anyone had any ideas,i'm ready to learn! :)
  • Kershaw
    • 11822
    Fifteen thousand euro?
    Swap in an N20 turbocharged 4 cylinder 2 liter engine.
    Or if that's a typo and you mean one thousand five hundred euro, then uh.. well that's not happening. In any case, 2 liter and 300hp is not happening without a turbo.
    AWD > RWD
    • BMW012
      • Mar 2016
      • 10
      Yes,15 thousand Euros.And the N20 seems perfect,except for one thing.It's a pretty new motor,so it's hard to find.Also,i don't know how complex would the swap be because of electronics and stuff.Any other ideas?
      • Shftr8
        • Aug 2014
        • 530
        M20B20 from a 320i?? they didnt come to the states but I know they are somewhat common in europe.
        • Preyupy
          • Oct 2012
          • 73
          Trying to use an engine that was normally available in a E30 chassis is going to be very difficult to do. The M20B20 2 liter 6 cylinder being a 2 valve engine even with a Turbo is going to be very difficult to get to 300 HP and have it be much of a street car engine. At the very least you will need a modern stand alone EFI system complete with knock sensors and a very good Map to keep from melting it down. Same thing goes with a M42 (or the derivative M43/M44) The 4 valve combustion chamber will help but 300 hp from 2 liters is going to be very difficult and I'll bet your 15,000 euro budget might build you the 1st one and maybe part of your 2nd one soon there after.
          How about a turbo Rotary? Or one of the more recent Turbo engines from other manufacturers? Does the engine have to be one that came in the chassis (for licensing/emission reasons in your country) ?
          Short answer, I believe you are working with unreasonable expectations thinking you are going to build a "Reliable 300 HP using a 2 liter engine" without starting with a very modern engine and ECU for 15,000 euro.
          • 2mAn
            Señior Mod
            • 21016
            M12/7
            Race cars for sale and race cars wanted, rally cars, spares, memorabilia, transporters and pit equipment for sale with on-line photos and spec sheets.
            No idea if its actually available still, but...
            or here
            http://www.carandclassic.co.uk/car/C393215
            S42
            http://www.carandclassic.co.uk/car/C345692
            one can dream right?...
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • Kershaw
              • 11822
              With 15k euro you can pay a shop to do it. You could probably find one for 5k euro. Swap the transmission too. Custom driveshaft.
              No idea what you'd use for engine management. Full standalone or a reflash deleting EWS or whatever.
              AWD > RWD
              • BMW012
                • Mar 2016
                • 10
                Maybe an SR20DET out of a Nissan Silvia? How would that work?
                • BMW012
                  • Mar 2016
                  • 10
                  Also,my cousins are all mechanics.They'll do the swap for little money.They all have 10+ years of expirience.There's 3 mechanics i can count on.I can't do shit by myself....
                  • rturbo 930
                    • Dec 2005
                    • 2627
                    Do they check the displacement of the engine themselves, or do they go by what the block says? I'm assuming it's the latter, and if that's the case, I'd get an M50B20 (if they're available where you are), bore it out, stroke it, and add a turbo.
                    • BMW012
                      • Mar 2016
                      • 10
                      I'm not sure about that.I can tell you something for sure though.I live in Serbia.It's a country where very little people do their jobs properly,and everyone just wants to scam you.This is because Serbia is economically pretty weak.Point of the story is,they will probablly just take a look at it and let it go,cause they don't care.I'm just wondering,how safe is boring gonna be?
                      Also i will need custom pistons even if i don't stroke it.So does it pay off?
                      • Kershaw
                        • 11822
                        So you have 15k euro in a country that has no money and a team of cousins that are mechanics who will do the work for cheap and the inspectors don't care.
                        Why don't you swap in an s54 and pay off the inspector?
                        I don't know the m50b20, but I'm sure rturbo suggested it because it's probably the same block as the m50b28, so boring it out to 3 liters would be fine. And the real answer is, ask your cousins what engines they have the most experience with.
                        Another answer is, 15k euro is a lot of money. You could just buy a crazy built turbo e30 from the Scandinavians and be done with it.
                        AWD > RWD
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          Another answer is, 15k euro is a lot of money. You could just...
                          ...buy a different car and keep the E30 as is.
                          ...pay the taxes on a larger displacement engine.
                          ...lower your "need" for 300HP as it's not necessary, but is fun.
                          ...get an S14B20.
                          ...get a motorcycle.
                          • stonea
                            • 2892
                            -Buy M20b20
                            -2.7 Stroker
                            -Buy Kam's Kit
                            /Thread
                            My Garage
                            Feedback
                            Instagram: Stone.Hopkins
                            • rturbo 930
                              • Dec 2005
                              • 2627
                              I'm not sure if it's exactly the same. I looked up a few things on wikipedia, and the M50B20 has an 80mm bore, the M50B25 has an 84mm bore, and the S52B32 has an 86.4mm bore . If the blocks are exactly the same except for the bore diameter, then you could likely bore it out to 84 or 86, but if not, you might be a bit more limited. The cranks I would imagine swap out pretty easily though, but I don't know that for sure. I don't actually know that much about the 24v motors.
                              Even if you were limited to the 80mm though, if you could get an S52 crank in there, you'd have a 2.7L, which isn't bad. 82mm bore would get you just shy of 3L, which is plenty.
