Another cold air intake thread.
  • O 16581 72452 5
    • 1066
    Yeah, i've searched and found numberous ones of these, but nothing to back up "It makes your car lose power". I'm wondering if anyone has real proof through dynos of what an intake does on these cars. I haven't found anything yet.
    For some reason my stock intake tube isn't sealing worth a shit and the car is running terrible, cuts out sometimes towards redline, idles bad, choppy powerband. The tighter i make the hose clamps, the better it runs, smoother powerband, better idle, unfortately the clamps are on the verge of breaking they're so tight. I'm thinking silicone couplers, hard pipes, and t-bolt clamps will do the trick, i rather not waste my money if there's no gain or an actual decrese in power from it, i'd rather rubber cement it if that's what might happen.
  • CarsSuck
    • Oct 2005
    • 968
    have you checked the intake boot for cracks or air leaks of any kind? An air leak after the AFM will make it run like shit. 20 year old rubber is probably deteriorated and will crack and leak soon, just replace it, if you havnt already, as a regular mainentance item.
    --Will
    • ZiMMie
      • Jun 2004
      • 968
      well i guess u havent read this yet.
      ill stick to my stock air box.
      www.stancefactory.com
      • rede30
        • 4697
        you porbably wont loose power but more shit will get into your engine, it flows better because it doesnt do its job as well as it should.
        • O 16581 72452 5
          • 1066
          http://www.bolhuijo.com/airflowtest/
          Now that's a good page!
          I'm reading through it now.
          Edit: Read it, cool information, not really what i was looking for, but it definately was a good read. I'd like to see how a hardpipe with a cone filter and heat shield does compared to a stock intake.
          I'm going to check my intake tube throughly today for any rips or tears.
          • parkerbink
            • Jun 2004
            • 10138
            Can't "back it up with a dyno" But I can tell you that my car ran significantly worse after I spent a slew of time and money shoehorning a K&N Cone filter and hard tube in there.
            I reverted to stock box with panel K&N and was very happy with it, my 19lb 4pintle injectors and MarkD chip.
            • Van Westervelt
              • 9365
              I noticed a drop in low end torque. High end though at 80 mph+ it improved quite a bit. Daily driving = stock airbox, track days = cai.
              • O 16581 72452 5
                • 1066
                That's the point of I/H/E, high end power...
                • Digitalwave
                  is a poseur
                  • 6299
                  It sounds like you have problems that replacing the air filter would not solve.
                  RISING EDGE
                    • 34844
                    for sure. before wasting time and money on worthless bolt ons, how about some maintenance? replace sensors, hoses, boots, cap and rotor, spark plugs, ICV, valve adjustment, test things like the AFM and throttle switch, etc. etc.. get your car running like it should be, and then worry about mods. otherwise you end up masking problems and potentially making them much harder to find later on..
                    • O 16581 72452 5
                      • 1066
                      I'm thinking my intake is leaking after the AFM, i'm not too worried about a mod as much as maintaince with a possible gain, like i said later today i will check out my intake tube to see if it's torn or ripped.
                      • Digitalwave
                        is a poseur
                        • 6299
                        Well I don't see how the intake has anything to do with the maintainence of a vacuum leak after the AFM.
                        RISING EDGE
                        • O 16581 72452 5
                          • 1066
                          Hard pipe would replace the tube between the AFM, TB, and Silicone seals better than old ass rubber...
                          • moatilliatta
                            • 6152
                            Well when you add a cold air intake... for it to be an actual cold air intake you have to block the heat from the engine.. or else it would just be a hot air intake...
                            so what i've done here is this....
                            Then add a nice stylish box to keep out all the bad hot air... shave the openings of the grill to allow more air to flow to the filter... then bam.. you have yourself a stylish ram cold air intake...
                            @Zakspeed_US
                            • O 16581 72452 5
                              • 1066
                              Did you remove your IACV?
