Toughest job in an e30?
  • brickwhite
    • 582
    #61
    Hardest Job
    I would say the Rear subframe bushings and trailing arm bushing. When it's 98 degrees out side an you have the car on jack stands by yourself you will be there a while.
    • SchnellerVert
      • Sep 2005
      • 3948
      #62
      Subframe and trailing arms were a bitch, need to do another set on my current car.
      • PeaveyBassist
        • Sep 2004
        • 3511
        #63
        Subframe and TA bushings arent that bad when you have a lift, air tools, special press tools to push out the bushings :) I'm finishing up a set today actually.
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • Erick
          Official R3V Drifter
          • 11169
          #64
          I did, and our main problem was that in a group of 3 people, all of us wanted to do it in our own separate way. I wanted to just drop the entire rear end, someone wanted to just drop the subframe, doing the T/A bushings while the T/A sits suspended on the car, and the other one wouldnt stop cursing at the goddamn brake lines. :p
          Out of our 5 hours working, a solid 2 were just looking and arguing.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • vivalegreg
            • Apr 2006
            • 1313
            #65
            hmm hardest job on my car thus far was, windshield wiper motor so far. what a bitch! my wiper alignment still has to be tweaked but it works...so i dont htink im gonna fuck with it till the napa pos motor breaks. also breaking loose that 32mm clutch fan nut was no walk in the park either. talk about a stuck nut i had to torch the bitch to break it loose
            e30s r kool
            • etxxz
              • Feb 2006
              • 2085
              #66
              Removing Rusted e-brake cables in my last e30. 9hour job, ~5 with a dremel and a hammer. BY FAR THE WORSE TIME i've had with an e30 **** what a nightmare that was
              rust makes everything 27x worse...this is considering i've done subframe/TA bushings completely on own (that wasnt so bad actually ~ 6hours/2day) but there was no rust and everything just slide out like a charm. also done diff swap suspension cab and dropped and s52 in last week amongst other presumed harder tasks...go figure!
              toughest. as in requiring lots of time, effort strength and patience i would have to crown Subframe&TA.bushings king
              No more e30s for me.
              88 black BMW OBDII 332is dedicated track [sold]
              88 BMW OBDII bronzit 332is [RIP 03/08]
              91 BMW 325i [sold]
              86 Corolla 'Ae86' HB 20v trd [sold]
              http://youtube.com/watch?v=pTj7Hn9v5Rs
              • Erick
                • 11169
                #67
                Yeah... damn you for not telling me that. I got all the bushings after driving your car :p
                Feedback Thread
                • Eric
                  • 5142
                  #68
                  [QUOTE=golde30;894181]rear subframe + brake lines above it. also gas tank, that was a pita.
                  QUOTE]
                  I would say the brake lines over the subframe is the worst job, especially if your not dropping the subframe
                  • Erick
                    • 11169
                    #69
                    ^Another thing I was bitching at myself for not doing. Once I saw the lines just chilling there, I was like "damn it... I could've done that now"
                    Feedback Thread
                    • oldskool3
                      • Mar 2005
                      • 401
                      #70
                      Definetly took me about a week working on and off. More off than on since everytime I got under the car I thought about kicking the jack stands out and putting me out of my misery. After that the tank swap seemed like changing my oil.
                      Diff swap solo would be second. Not hard just a huge pain when trying to allign the new diff by yourself sitting on a jack. I think that any work you have to preform solo turns into a nightmare.
                      My next two jobs were going to be subframe/TA bushings and my dash swap. Im pretty excited that they are probably the 2 hardest jobs mentioned ;)
                      Photoshop by O 16581 72452 5
                        • 34844
                        #71
                        Originally posted by FrankM E30
                        haha, ooooh nando. novice.
                        After aluminum and steel have been pressed together for 20 years, it's nearly impossible to separate that aluminum bushing from the steel bolt. I worked on each bushing for at least 45 minutes with an air hammer and FINALLY got it out. Big big job. I will never underestimate subframe bushings on a 20 year old car again.
                        that's because you live in the rust belt :p
                        • uofom3
                          • Jan 2004
                          • 5392
                          #72
                          [QUOTE=Eric;894419]
                          QUOTE]
                          For sure... taking those off was a major PITA. Without Jordan's tools, that would have taken me a very, very long time.
                          PNW Crew
                          90 m3
                          06 m5
                          • psloan
                            • 9815
                            #73
                            I had a hard time with the dash. Don't know why. But the heater core and valve were pretty easy IMO. I also had a hard time with motor mounts - but probably because I have all the wrong tools.
                            • mudflaps
                              • 808
                              #74
                              taking the intake manifold off to get to the fuel injectors, only to later realize I could have just taken the valve cover off instead.
                              • delatlanta1281
                                Dart Master
                                • Mar 2006
                                • 10317
                                #75
                                Dash anyone?
                                Yours truly,
                                Rich
                                you kids get off my lawn.....
