E30 from Ukraine - "Shadow of Intelligence"
  • The_Glory
    • Jul 2022
    • 440
    #196
    Let's return to wiring.
    General electrical equipment of the car
    Collection_52. ETK_61_General electrical equipment of the car. Jute wires (part 3)
    Jute wires (part 3)
    Last time I laid the main jute wiring. Now we will talk about all the harnesses of additional options, which are laid parallel to the main harness - along the left threshold to the trunk, and in front of the front seats, through the gearbox tunnel to the right side. So, first I put a large harness of the "electrical package" (mirrors, sunroof, power windows, power window comfort relay, central locking, interior light timer and heating of the driver's door lock. Next, other options - audio wiring, electric antenna, telephone and hands-free system, heating of the front seats, heated rear seats (custom), standard alarm, lights in the interior mirror, interior lights, illumination of the hydrocorrector of the headlights. Maybe I forgot something else)
    In the process, we have such a picture :)
    Complete chaos under the wheel)
    We connect the outer and inner parts of the door connectors. In the left door connector, you need to immediately install the cable of the standard alarm magnetic lock.
    So, all the harnesses are laid, now you need to fix them properly. I'll start with the simplest, where there is less wiring - from the trunk.
    On the right side, the wire of the central lock goes up through the wheel well to the hatch of the fuel tank, and the wire of the fuel level sensor in the additional tank. It is attached to the body with a metal clip. Since I did not install an additional tank (at least not yet), I simply hid the sensor behind the trunk loop.
    The wire of the central lock passes over the wheel arch, is attached with a metal clip to the rib and to the bracket of the drive of the central lock of the fuel tank hatch.
    On the right side of the trunk, that's all.
    On the left side, there is more wiring - audio amplifier, electric antenna, alarm system, telephone. Fastened with two clamps.
    As I said earlier, all electronic units will be installed together with their wiring. I installed the GSM phone unit not on the left rear wing, as expected by the factory, but under the rear shelf. I already mentioned earlier about the regular bracket, and its not very successful fastening with the drilling of the wing. That's why I like my version better - it's convenient and inconspicuous.
    I did not install the audio amplifier, because I have not yet found the bracket for its attachment, the antenna still needs to be repaired a little. So, for now, just plugs.
    The audio wiring turned out to be from the Touring, so the ground terminal does not reach the G300 point under the rear seat. I fixed it in the matching hole on the stiffening rib of the body.
    Lamp control unit in the rear lights.
    The wiring of the trunk lighting and standard alarm is laid through the hole in the body bracket, and is wound into the trunk loop.
    At the exit from the loop, it is fastened with a tie, and is wound into the opening of the trunk lid.
    It is laid along the diagonal stiffening rib to the lamp shade and to the alarm stop button.
    The alarm and central locking wiring is routed along the wing and rear panel to the alarm diode (I mentioned it earlier when installing the license plate panel) and to the trunk central locking actuator. It is attached together with the main harness with metal staples.
    All wiring in the trunk is laid and fixed.
    Let's go to the back of the cabin. On the back shelf, we bring out the wiring of the rear speakers. But, since the audio wiring is from the touring, the connectors for the speakers do not fit, and an extension cord will be needed for the left rear speaker. Then I will make adapters/extensions.
    Down under the seat is point G300 for the "ground" of all these wiring harnesses. By the way, all the harnesses did not fit into the standard rubber insert. I laid the wiring of the telephone, alarm and speakers through the shelf.
    We also lead the wire of the third brake light and the rear window heating contacts here.
    By the way, the standard alarm system is connected to the contact break of the rear window heating.
    I don't know why, but that's how it is. Maybe this is how it will react to the breaking of threads when it is broken... But I did not check :)
    Under the rear seat, the wiring is laid parallel to the main harness and fastened with clamps together with it. I routed the wiring to the rear seat heating buttons and to the phone in the center of the gearbox tunnel.
    On the right - the ABS connector, the wiring connector that goes under the bottom to the gearbox, and seat heating.
    On the left - the ABS connector, the wiring that goes under the bottom to the fuel pump, and the heated seat.
    Then all these bundles go forward along the left threshold. The front part of the wiring will be more difficult to fix, so I haven't done it completely yet. I'll write later when I'm done.​
    • The_Glory
      • Jul 2022
      • 440
      #197
      The wiring is partially completed, so you can move on to lighting.
      Lighting devices
      Assembly_53. ETK_63_Turn signal lamp Pd/Pd Bik
      [URL='http://ru.bmwfans.info/parts-catalog/E30-4-doors/Europe/325i-M20/1985/browse/lighting/front_front_lateral_turn_indicator/']Turn indicator light South/South Side[/URL ]
      I will say right away that I never liked the original side turn signal lights on the E30. Their design is not bad, but on the car, in combination with moldings, they look like something extra. Some of them are too massive or something... So, I will not install them, so their not quite perfect condition does not bother me - I bought them just to be :)
      Part Visitor Messages - left (63 13 1 367 801) and right (63 13 1 367 802) turn signal lights. Complete with metal clips.
      Part No. 8 - rubber seal for the turn signal lamp, left (63 13 1 367 803) and right (63 13 1 367 804).
      Part No. 9 - lamp 12V5W (63 21 7 160 797) - 2 pcs.
      Part No. 10 - clip (51 71 1 874 203 or 63 13 1 378 066) - 2 pcs.
      Part No. 11 - self-tapping screw ST3.9X16 (07 11 9 906 734) - 2 pcs.
      Everything is assembled. The wiring is the same on both sides.
      The side turn signal lights are quite a useful thing in city traffic, so I will have them, but I will write about that later.
      Front turn signals.
      Part Home - front turn signals assembly,
      Part Forum - rubber seal (63 13 1 370 397) - 2 pcs.
      Detail Blogs - glass. The original comes from different manufacturers (SIDLER, ULO, ZIZALA (ZKW)). ZKW comes in different colors - orange, transparent and smoky, but for some reason they all have the same number 63 13 1 377 996. Therefore, when ordering by this number, it's like a lottery, but the usual orange usually comes :) I collected all the original options.
      There were several more beautiful "aftermarket" options of those times, and many modern Chinese ones, but that's it... )
      Part No. 4 - self-tapping screw (63 13 1 369 303) - 4 pcs.
      Part No. 5 - lamp 12V21W (63 21 7 160 790) - 2 pcs.
      Part No. 6 - screw (63 13 1 370 849) - 4 pcs.
      Item No. 12 is not used.
      So, I install the side indicators - in non-standard holes in the wing.
      Next, we insert the wiring into the hole in the body (I knocked out the metal plugs before painting the car)
      And we take it to the cabin, where it will be connected to the wiring of the instrument panel.
      The same on the right.
      The connectors of the front turn signals are removed from the main wiring harness.
      Of course, I will install the front turn signals together with the front bumper.​
      • The_Glory
        • Jul 2022
        • 440
        #198
        Assembly_54. ETK_63_Block of rear lights
        Rear light unit
        Part Home - left (63 21 1 370 677) and right (63 21 1 370 678) rear light. By the way - in ETK it is literally said - "Rear light unit with fog light is right". But (63 21 1 370 682) - the usual right, without fog lights. This is proof for those who believe that the rear fog light was only on the left. I also added it to the right lantern - I like it better that way.
        Detail Forum - tail light cover. There is a regular one, or with additional illumination of the trunk from the marker lights.
        I have it with additional lighting.
        Part No. 3 - sealing gasket (63 21 1 370 679) - 2 pcs.
        By the way, just in case, I cut a couple more spacers from the same material along the contour of the original spacers. They turned out almost no worse :)
        Part Groups - left (63 21 1 374 913) and right (63 21 1 374 914) lamp mounting bracket.
        Part No. 5 - M5 nut (63 25 9 128 043) - 12 pcs.
        Item No. 6 - lamp 12V 21W - 8 pcs. , lamp 12V 10W - 2 pcs. BOSCH lamps.
        Part No. 7 - lamp cover fastening handle (63 21 1 376 879) - 4 pcs.
        I already wrote about the restoration and polishing of the lights earlier, so everything is ready for installation.
        But there is an alternative option - Startec! ;)
        Tried Startec
        But they are not yet in the state in which I want to see them, and they need attention.
        Therefore, it will be the standard for now.
        • The_Glory
          • Jul 2022
          • 440
          #199
          Assembly_55. ETK_63_Different Lights
          We continue the section
          Lighting devices
          It has three subdivisions with the same name.
          Various lights
          For some reason, only one item - No. 20 - has been singled out for this subdivision. This is a fiberglass bracket (54 12 1 884 483) of the interior lamp. Perhaps such attention to it is due to the fact that it is practically impossible to find it whole! :) Both of my brackets have already been glued more than once, and broken again. I glued them together again, but they broke again, even before installing them... You can order new ones, but not cheap, and most likely they will break soon anyway. Very poor design and material. There are no analogues. So I enlisted the help of a teammate and he made a 3D model of these brackets, with improved mounting, and printed them out of more flexible plastic. Compared to standard:
          Now they are firmly installed, and easily and without damage removed. A great alternative to the original, even better.
          The next subsection is already about the lamps themselves.
          Various lights
          Part No. 1 - interior lamp (63 31 1 367 353) - 2 pcs. But probably everyone knows that the interior light is not very good in the front of the E30, so I installed a third lamp near the interior mirror a long time ago, and connected it parallel to the left lamp. That's why I have three of them. By the way, if you look closely, two are HELLA, and the third is from some other manufacturer, but outwardly they are the same.
          Item Forum - 12V 10W lamp
          I already mentioned the wiring earlier - it is the same on both sides. In addition, I made a similar wiring with additional connectors for the third lamp. On the left, we connect the home-made wiring to the standard one, and then connect both lamps.
          Left:
          Then from the left, front:
          Right to standard wiring:
          We insert the side panels into the brackets, and the front panel will then be installed in the electric sunroof panel instead of the plug.
          Detail No. 3 - the button for the light switch of the box for small things.
          Part Groups - not used.
          Item No. 5 - 12V 5W lamp. I bought it, but then I realized that I didn't need it. Although, it can be installed in the button cartridge, but it will shine inside the torpedo :) Apparently it is for other BMW models.
          Part No. 6 - trunk lighting lampshade (63 31 6 961 985).
          Item No. 7 - 12V 5W lamp.
          In the basic configuration, one ceiling light is installed, but there is a place for installing another ceiling light in the trunk lid. I guess it was some kind of option, something like "advanced lighting package"... I installed two shades a long time ago.
          Item No. 8 - portable rechargeable flashlight (82 11 9 413 147).
          Part Albums - glass with a lens (82 11 9 413 148)
          Detail No. 10 - lamp.
          The flashlight is in a special charging slot, in a box for small things. The white flashlight is rare and is no longer available to order. On newer BMW models, it is black, available to order, but does not fit the charging connector for the E30. But, if desired, it can be replaced together with the connector. I have the original one for the E30 - white, but as in most cases, the battery in it no longer works. Batteries will need to be replaced.
          Item No. 11 - a portable lamp. It has not been available for order for a long time.
          Part No. 12 - license plate light shade (63 26 1 372 763) - 2 pcs.
          Part No. 13 - rubber sealing gasket (63 26 1 354 034) - 2 pcs.
          If you order by HELLA number, the lampshades come complete with rubber gaskets.
          Part No. 14 - insert for self-tapping screw ST3,9-4 (07 12 9 925 707) - 4 pcs. It is necessary to order such original mortgages. They are specific, shorter than usual.
          At first, I tried to install standard ST3.9 sockets, but the holes on them do not match the holes on the ceiling lights. So I had to order and wait for the original ones. You can see the difference in the photo.
          The original mortgages fit perfectly.
          Part No. 15 - plastic insert for self-tapping screw (63 26 1 378 067) - 4 pcs. Apparently this is a mistake in ETK again - I also ordered them, but they do not fit at all instead of mortgage E30 Classified Forums Although, maybe there was a back panel option with holes for these mortgages.
          Part No. 16 - self-tapping screw ST3.9X13 (07 11 9 907 720) - 4 pcs.
          The previous owner of my car for some reason welded the holes for the license plate lights. It's good that the wiring remained - I connected them and they acted as an additional trunk light :) And finally, I will have a license plate light.
          Detail #17, 18 - not used.
          Part No. 19 - block with spare lamps. No longer available to order. If I find it, I will buy it.
          Another subdivision:
          Various lights
          There is also only one detail here - No. 1 (63 31 0 138 864). Portable rechargeable flashlight. It has not been available to order for a long time. I would probably buy it too if I ever find it... ;)​
          • The_Glory
            • Jul 2022
            • 440
            #200
            Continuing the previous record, we move on to the section
            Collection_56. ETK_61_Different switches
            Various switches
            Part Home - handbrake lamp switch (61 31 1 369 771).
            Part Forum - screw M4X10-Z5 - 1 pc.
            I installed it together with the lever a long time ago.
            Detail Blogs - door switch button. If there are electric windows, a switch with double contacts (61 31 1 370 805) is installed on the front door. A conventional switch (61 31 1 368 430) is installed on the rear door and trunk lid.
            Part No. 4 - self-tapping screw ST3.9X9.5 (07 11 9 902 216) - 5 pcs.
            Part No. 9 - front door switch button stop (61 31 1 370 695) - 2 pcs.
            The front switches are screwed with self-tapping screws, the stop is simply clicked into the hole in the door.
            The connectors are located on the main wiring harness in the niches of the front speakers. The window comfort relay and other electrical options are connected to the second contact. I will write about this later.
            The rear door switch buttons connect to the wiring for the interior lights that I wrote about in the previous post. The connectors are located on the main wiring harness, below the middle roof rack. The wiring is laid inside the rack and attached to it with metal clips from below near the seat belt coil.
            But from above, near the ceiling
            The same on the other side.
            A separate wire goes from the wiring connector under the back seat to the door switch button.
            We pass the wire through the wheel arch and connect it to the rear door switch.
            Screw the switch to the body with a self-tapping screw.
            Similarly on the other side.
            The trunk lid switch remains. In the previous entry, I already wrote that the basic equipment included one trunk light shade, or two as an additional option. In the photo, the "ground" wire of the switch is the lower basic wire for one lamp, and the upper one, with a double terminal, for connecting two lamps.
            The basic option for one lampshade
            Just two contacts per ceiling.
            Since I have two lampshades, I made the power wiring for the second lampshade.
            In addition, I have a standard alarm installed, which must also be connected to the switch button.
            Therefore, we first connect the alarm system, then connect the wire for two ceiling lights and their power supply to its corresponding connector.
            Everything is installed.
            Parts No. 5-8 are intended for automatic transmission, so they are not used.
            Another subdivision with the same name:
            Various switches
            All these parts are for special cars, probably for the police. I don't have a police car, so I don't have them and there's nothing to write about :)​
            • roguetoaster
              Biggus Tippus
              • 7830
              #201
              Additional light in an E30 is a very smart upgrade, LEDs also seem to help if you can get the right ones.
              • The_Glory
                • Jul 2022
                • 440
                #202
                I decided to leave the usual lamps. Just replaced them all with new ones.
                By the way, I did repair the contact on the interior light switch-off timer sensor. It turned out not bad enough, in my opinion. And I hope that now it will work for a long time. Later I will show a photo of my idea ;)​
                • The_Glory
                  • Jul 2022
                  • 440
                  #203
                  Apparently, the brackets for the interior lamps are a very important detail - they were not just separated into a separate unit, but also duplicated in the sunroof section! :) So, let's go to this section.
                  Sliding roof and folding top
                  In fact, I decided to completely finish the trunk assembly - install the drain hoses from the hatch, the rear seat belts, so that I can finally install the side panels of the trunk. I also start with hoses - again from the last subdivision.
                  Collection_57. ETK_54_Soft cover of the lifting-sliding hatch cover
                  Lifting-sliding roof cover hatch
                  Part No. 9 (No. 1+No. 4) is a soft casing of the lifting-sliding hatch cover (54 12 1 924 517). No longer available to order. My car came with a manual sunroof from the factory, so I guess this cover in the front part of it was trimmed a bit to fit the electric sunroof. By the way, he is not very soft, but that is probably from old age.
                  Part No. 2 - a soft casing of the hatch manual drive mechanism (54 12 1 879 148). The hatch is not used with an electric drive.
                  Part No. 3 - sound insulation of the hatch cover (54 12 1 906 809). I have it in good condition, just slightly tinted :) That's why I left it as it is.
                  Part No. 5 - rear hoses for draining water (51 73 1 947 958) - 2 pcs. In ETK, their length is 1690MM, but in fact I have them 1350MM long. We run the hoses from the trunk along the rear rack of the roof to the drain pipes of the hatch. Just in case, I installed them on the gasket sealant.
                  Part No. 6 - clamp (54 12 1 874 589) - 4 pcs. Metal clip for fixing the hose inside the roof rack. I only had two, so I ordered two more. The number is already different (17 12 7 634 089), but the clip looks the same, only it is light in color.
                  The clip is installed on the hose and is attached to a special hole on the rear rack of the roof. But I was in a hurry to glue the noise insulation of the rack, so I had to tear it off a little. It's good that she stuck to it again later.
                  Another clip fixes the hose to the rib on the wheel arch. Next, the hose passes under the central locking actuator bracket and the end of the hose is firmly inserted into the clip on the rear fender ventilation grill.
                  Similarly to the left.
                  In this way, the water from the hatch is brought out under the rear bumper.
                  Part No. 7 - front hoses for draining water (51 73 1 922 405) - 2 pcs. In ETK, their length is 1700MM. They are not in the general photo, because they have been installed for a long time. I also installed them on top of the gasket sealant.
                  Next, the hose runs tightly along the front roof rack and exits into the speaker niche, where it is pressed by the plastic cover I mentioned earlier.
                  And that's all. Water from the hatch pours right into the threshold! In my opinion, this is one of the most ridiculous engineering decisions in the E30! That is why all E30s with a hatch in the front part have holes in the floor and rotten thresholds. Of course, I decided to fix it - at the stage of bodywork, this hose was brought out under the front fender and fixed with body sealant.
                  This is done on many cars. Water will flow on the lower fender mount, but it's still better than on the threshold and in the cabin!
                  Part No. 8 - again the same brackets for interior lamps (54 12 1 884 483). Last time I already said - the 3D copy turned out to be better than the original. Already installed together with lamps.
                  The cover is fixed to the roof with metal brackets that bend.
                  In the front part, there is a cutout for an electric sunroof.
                  • D.Martijn
                    • Sep 2016
                    • 1024
                    #204
                    Is that plastic cover inside of the A pillar standard? Never seen one of those
                    1990 325iX Touring - November 2018 R3V Car Of The Month
                    1980 Volkswagen Golf mk1 1.1
                    1974 BMW 2002 Touring
                    Instagram
                    • The_Glory
                      • Jul 2022
                      • 440
                      #205
                      Yes, this is a standard cover - left (51 71 1 916 123) and right (51 71 1 916 124). I recently wrote about them here in the appropriate section.
                      But, if the standard central lock is installed, then the left cover is not installed - in its place is the ECU of the central lock.
                      If there is a hatch, you need to break out special segments for drain hoses on the covers.
                      • The_Glory
                        • Jul 2022
                        • 440
                        #206
                        To complete the assembly of the trunk, it is necessary to install the rear seat belts. So, the section
                        Spare parts+accessories (body)
                        There are two types of seat belts.
                        The first - until September 1986 - with small buckles, the rear straps are installed in the trunk under the shelf and with an additional attachment on the rear roof rack. The fastening bracket on the racks was metal, and later plastic. The plastic one had a simpler attachment and a more aesthetic appearance. The rear middle belt is secured to the left under the rear seat.
                        The second - after September 1986 - with large buckles, the rear straps are installed on the shelf, without additional fastening on the rear roof rack. The rear middle belt is attached to the right under the rear seat.
                        Accordingly, seat backs and rear shelves are also different and not interchangeable. But buckles of the second type can be locked in a lock of the first type, but not vice versa.
                        Front belts for 2- and 4-door sedans have different fasteners. How do I know that? Because he collected a whole collection of belts! ) I used to have front belts of the second type, and no rear belts at all. I bought the rear belts of the first type a long time ago, and the same front belts were given to me by a friend. I bought the rear middle one recently. So I put together a complete set of 1985 belts - just the thing! Unwound them all, and cleaned and washed them well.
                        So, I install the belts.
                        Collection_58. ETK_72_Spare parts + accessories (body). Seat belts
                        Front seat belt for 4-door cars
                        November 1985
                        Item Home - Autoflug Belt Reels - Left and Right Symmetrical.
                        Part Forum - Autoflug locks - left and right are the same.
                        But there is another manufacturer - Repa.
                        And the difference is this - the Autoflug buttons remain red even after 40 years, while the Repa buttons have completely lost their color.
                        First I bought Repa locks and then had to buy Autoflug to make all the locks red. Although, locks of the second type of Autoflug come across both red and with a completely lost color.
                        A collection of locks. By the way, I still need a lock with a seat belt sensor to fully implement this "American" option. You will probably have to look for it in America...there are none here...
                        Although the belts were thoroughly cleaned, they did not wind very well. Therefore, I decided to lubricate the mechanism and tighten the spring.
                        First the right. The cover of the mechanism is easily removed.
                        The spring cover must be removed very carefully - the spring may pop out, and it will not be easy to wind it. Hands can also be injured. Now I know :) Lubricated and wound an extra turn of the spring.
                        The same on the left side.
                        Now about belt fastening.
                        Front safety belt accessories
                        All seat belt mounting bolts have a specific 7/16" thread.
                        Part No. 1 - bolt (72 11 1 904 775) - 2 pcs.
                        Part Forum - sleeve (72 11 1 848 465) - 2 pcs.
                        Part #3, Groups - bolt 7/16X20 (72 11 1 861 932) - 6 pcs.
                        Part No. 7 - washer (72 11 1 808 673) - 4 pcs.
                        Part No. 8 - tension washer (72 11 1 808 672) - 2 pcs.
                        Part No. 9 - cover (72 11 1 904 665) - 2 pcs.
                        Part #10 - not used.
                        Part No. 11 - button (72 11 1 950 829) - 2 pcs.
                        Part No. 12 - button (72 11 1 917 406) - 2 pcs.
                        The coil of the front belt is fixed in the niche of the middle rack. Only in this position can the belt be unwound. The belt clip is attached to the upper hole on the rack, and is closed with a cover.
                        The bracket of the third point of attachment of the belt, and the lock is attached to the seat. Therefore, it will be after their installation.
                        For the front belts of the E30, there was a very rare option - height adjustment of the upper fastening of the bracket.
                        Belt adjuster
                        I saw it only once in a photo on the Internet. A really rare thing for an E30. On the middle rack, there is one additional hole for its fastening. The bracket is attached to this device and can be adjusted to different positions in height. It would be interesting to find such a thing...
                        Now the rear straps.
                        Rear safety belt
                        August 1985
                        December 1985 (average)
                        Detail Home - belt spools - left and right look the same. Marked with stickers L and R.
                        But they have a difference inside.
                        Disassembled and lubricated similarly to the front ones. I did not tighten the spring on the rear ones, they began to wind up well anyway.
                        Left.
                        Right.
                        Spring.
                        Rear safety belt accessories
                        Part #2, Blogs - not used. Used for belts with steel staples.
                        Part No. 4 - washer (72 11 1 808 673) - 4 pcs.
                        Part No. 5 - sleeve (72 11 1 848 465) - 2 pcs.
                        Part No. 6 - bolt 7/16X20 (72 11 1 861 932) - 6 pcs.
                        Part No. 7 - cover (72 11 1 904 665) - 2 pcs.
                        Part Private Messages - left (51 46 1 916 979) and right (51 46 1 916 980) covers - 2 pcs.
                        Part Albums - not used. It is used for belts of the second type.
                        The rear belt coil is mounted in the trunk, on special brackets under the shelf. Only in this position can the belt be unwound.
                        The belt is passed through the hole in the shelf and the plastic cover, the belt clip is attached to the rear rack, and closed with the cover.
                        The bracket of the third point of attachment of the belt, and the lock is attached under the rear seat.
                        The middle belt should be attached under the rear seat on the left. But I have the seat and rear shelf for the second type of belt where the middle belt is on the right. That's why I installed it there. It seems even more logical to me - so the middle and side belts will not cross. I don't understand why the factory made the opposite...
                        The middle belt does not wind up, but will be fixed with a buckle in a special plastic cover on the interior shelf.
                        So, the seat belts are installed, the side panels of the trunk can be installed.
                        Next will probably be about the lining of the trunk lid.​
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          #207
                          I just love this thread, can always count on it for something new to me just about every time I open it.
                          • jjjjj
                            • Jun 2019
                            • 88
                            #208
                            i just spent three hours with this thread for the first time. wow. you sir are quite the man with a vision and with tools. i'll be coming back, meanwhile you just keep doing you.
                            • The_Glory
                              • Jul 2022
                              • 440
                              #209
                              I think there will be something new next time too ;) At least, I haven't come across such a thing...
                              • The_Glory
                                • Jul 2022
                                • 440
                                #210
                                Thanks, I'll try)
