E30s on 16s - post yours
  • Shadye30
    • 177
    #2671
    My early model coupe on 16x8 ESM 002r's all around with staggered tires..
    1988 E30 M3
    Diamantschwarz/Black
    • AmosCake
      • Feb 2021
      • 218
      #2672
      what are your offsets and tire specs? Looks real nice
      • Shadye30
        • 177
        #2673
        Thanks,
        +20 ET
        205/50 up front
        225/50 in the rear
        1988 E30 M3
        • AmosCake
          • Feb 2021
          • 218
          #2674
          Thanks,
          +20 ET
          205/50 up front
          225/50 in the rear
          Whats your suspension set up? Because I used n4sm to compare your set up to my current one and my fronts poke out a lot. With your set up, mine will retract by only 8mm which doesnt seem like its enough.
          • Shadye30
            • 177
            #2675
            Raceland coil-overs with Bilstein inserts/rear shocks
            1988 E30 M3
            • AmosCake
              • Feb 2021
              • 218
              #2676
              For those with a late model, what tire set up for 16x8.5 ET 20 in the REAR w/o rubbing? Car is on supersport H&R springs w/ rolled fenders. Apparently 225/45 rub so was thinking 215/45?
              • lambo
                Captain Scene Points
                • 10953
                #2677
                if it helps, I run 16x9 et13 with 205/50's in the rear and rolled fenders with no rubbing., night help with some fitment calculators idk
                • It's Soda Not Pop
                  • Jan 2022
                  • 877
                  #2678
                  16x8 ESM BBS Reps.
                  88' Seta 2.7i Zinno
                  https://www.r3vlimited.com/board/for...430-my-88-seta
                  • AmosCake
                    • Feb 2021
                    • 218
                    #2679
                    That helps a lot actually, thank you. Might just run 215/40 to be safe based on the wheel fitment sticky on here
                    • iansane
                      • 1342
                      #2680
                      I tossed my 16s back on for winter and holy crap I always forget how much better they ride than the 17s.
                      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                      • alpinaseeone
                        • Jan 2023
                        • 85
                        #2681
                        16x9 AC Schnitzer reps et15 on 225/45/16 Toyo Proxes R1R
                        • moatilliatta
                          • 6152
                          #2682
                          16's have always been best. Compromotive?
                          @Zakspeed_US
                          • iansane
                            • 1342
                            #2683
                            Yessir, compomotive.
                            After daily-ing the 16s more I agree that they are a far superior ride but the 17" comp TH's look a million times better than the 16" comp TH's. It's not even in the same ballpark.
                            • jjjjj
                              • Jun 2019
                              • 88
                              #2684
                              16x7 RG-FClick image for larger version
                              • varg
                                Florida Turbo Man
                                • May 2014
                                • 3413
                                #2685
                                Who makes those and do they make a replica of the one piece AC Schnitzers?
                                IG @turbovarg
                                '91 318is, M20 turbo
