My daily '84 318i m30 swap
  • lukeADE335i
    • Apr 2013
    • 1389
    #136
    Car is looking great Glnr13! Will follow your progress on the tucked radiator with interest - I'd like to do one on mine so that I can reinstate a clutch fan and run AC.
    My e30: OEM+ with M30B35
    • glnr13
      • 1334
      #137
      will do for sure, Luke.
      installed a VISracing hood that i've had in storage for years. euro valance to go on maybe this weekend.
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4495
        #138
        This is a dream setup. Always wanted to build a no/low optioned ‘84 with an M30.
        • glnr13
          • 1334
          #139
          Got a little bit of soldering to do Sent from my Pixel 4 XL using Tapatalk
          • glnr13
            • 1334
            #140
            Quick mock up of RHD ITB kit and inventory check. Fuel rail back ordered. Sent from my Pixel 4 XL using Tapatalk
            • 2mAn
              Señior Mod
              • 20978
              #141
              Glen with the low-key flex
              Glen_____________________ Translation
              "got some wiring to do" _______I got a standalone to build and wire up
              "laid out some new parts" _____Just dropped major $$$$ on ITBs!!!
              ok bruh NBD! lol
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • glnr13
                • 1334
                #142
                i'm making up for the months/years of not posting any progress pics
                • Bearmw
                  • 1323
                  #143
                  Do you plan on running some type of air filters?
                  • glnr13
                    • 1334
                    #144
                    yes, not sure if going to run the ones that clamp over each trumpet or one of those big ITG ones. I'm hoping I can get these to tune without needing a plenum/IAT.
                    • Slybeanx
                      • Dec 2018
                      • 518
                      #145
                      cool build so far! some inspiration to finally jam my M30 in.
                      85% of the time i have no idea what I'm doing
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4495
                        #146
                        Cant wait to see standalone/ITB progress.
                        What modifications did you do to get the IE headers to fit?
                        Also, there is very little info on the wiring required to swap an m30 into an early 318 on the interwebz. Did you use a 320i harness or something?
                        • downforce22
                          • Aug 2009
                          • 3192
                          #147
                          isn't the only difference the square vs round c101?
                          • MrBurgundy
                            R3V Degenerate
                            • Mar 2012
                            • 5597
                            #148
                            Are you gonna run a MAP sensor to a vacuum manifold?
                            That should work fine without a plenum
                            • glnr13
                              • 1334
                              #149
                              had to dimple the runner above the motor mount. painful to do that to a brand new set of headers but, it fits and it works + no one can see the dimple from up top.
                              this is the pinout. I spliced and soldered the harness, cut an end off of the harness from the junks.
                              Pin 15 has no use on the m30. It's kind of really trippy that the m30 can just run on the 7-8 pins off of the m10 harness.
                              Click image for larger version  Name:	e30 harness pin out.png Views:	0 Size:	92.6 KB ID:	9951175
                              yeah, it'll be MAP on a manifold for sure. Reading about IAT aiding in tuning but we'll see down the road. doesn't look there's really any room to get a plenum in there anyway due to the brake booster.
                              • paynemw
                                • Dec 2015
                                • 439
                                #150
                                Awesome work. Curious about the clearance of the entire engine and the radiator, not just at the distributor cap, but also at the waterpump. Keep the content coming dude. And here's an awesome video to keep you motivated: https://youtu.be/I2il7mYVi1g
