New Member - 1989 325ix and Evo
    • 34844
    #196
    only if they're worn.
    • BingM3
      • 863
      #197
      Not true, just talking from experience...lowered started clicking, put it back to normal height it disappeared. All depends how low you go I guess mine was low enough because I wanted to hide that fender clearance.
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4490
        #198
        Hmm, I never experienced any clicking, but perhaps I wasn't low enough?
        To my understanding, the clicking is per nandos explanation; worn out.
        I couldn't have physically gone any lower due to frame clearance, so unless someone notched their frame and experienced clicking, it didn't happen to me.
          • 34844
          #199
          yeah, I might just have a little bit of experience here. :p
          • iXguido
            • Nov 2009
            • 730
            #200
            what spring rates did you get with your coil over kit?
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4490
              #201
              I went with 450F/650R.
              The car is my DD, and I'm 110% satisfied with these springs on a daily. A great blend of aggressive and comfort.
              Also, there haven't been any more axle popping incidents since I got four turns out of the front adjusters.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4490
                #202
                Beginning to question my sanity.
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4490
                  #203
                  To further update on the coilover situation:
                  All four front CV boots are ripped after a month. Ordering civic coils to use the threaded piece. Lower your iX they said, it'll be fun they said.
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    #204
                    Ouch not good news!
                    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                    E30 M50 6 spd 764whp @ 24psi.
                    E30 M20 6 spd 675whp.
                      • 34844
                      #205
                      Were they new? Something is wrong - I've never had one, much less all 4 rip in that short of a time frame.
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4490
                        #206
                        Originally posted by Nisse Järnet
                        Ouch not good news!
                        They were my lightly used spares. Not a single rip. Boots were all in great condition and weren't dry or anything. I have two sets that I'm rebuilding so I have more, it's just frustrating to have them rip so quickly.
                        Do you run a rear sway, nando?
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4490
                          #207
                          Project Standard Transmission Swap was a success!
                          A bit more time consuming than I anticipated, but went pretty smooth minus the clutch master cylinder pushing fluid past the seal after it was installed.
                          A note: I purchased the Condor weighted shift knob and it feels terrible due to how high it sits. Installed an older wood BMW knob I had lying around and it feels 10x better.
                          The car is a whole different machine with a 5sp!
                          Have a plethora of parts coming for next weekend.
                          Picked up:
                          Performance:
                          IE Rear 19mm Sway (with billet mounts and adj endlinks)
                          M3 Front Adj Endlinks
                          Trailing Arm Bushings
                          Rear Diff Bushing
                          Offset CABs
                          Rear Strut Reinforcement Plates
                          Bimmerheads 274 Regrind
                          Ported IM
                          Maintenance:
                          Performance Wires, OE plugs, cap, and rotor
                          Gates Racing Timing Belt, OE components and gaskets
                          New Style Head Studs
                          Fan Clutch
                          Dropped my IM and VC off at the powdercoaters over the weekend as well! Feels good to finally be making some progress on it.
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4490
                            #208
                            Car is finally coming along.
                            Found a set of pretty nice tan sports seats and got the manual swap all buttoned up.
                            Sourced a new piece of glass for the front windshield and also got my fresh hood back from the body shop. Going to glue my headliner back up and all that jazz when I finally get around to throwing that stuff on.
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4490
                              #209
                              Installed my new glass today, finally.
                              Also threw on my front M3 adj swaybar endlinks and I still think they're too long. It feels like they're binding up, and the swaybar definitely doesn't sit parallel. It's driving me crazy because the car pulls to whatever side is bound up. The shorter links helped, but still not short enough :hitler:
                              • rzerob
                                • Jun 2013
                                • 2315
                                #210
                                Subscribed
