New Member - 1989 325ix and Evo
  • AWDBOB
    • Aug 2013
    • 4394
    #226
    Originally posted by 2man
    Well, mine hasnt been cheap so it better be the other two!!!
    Baha well I sure wish you the best in that respect!
    In other news, the car performed flawlessly on her Philly to Indianapolis travels. The iX needs a 6th gear more than any other car I've driven.
    • AWDBOB
      • Aug 2013
      • 4394
      #227
      About 1,000 miles on the new axles. Both inner boots are ripped. This is becoming a problem. At least my undercarriage will have a rust preventing CV grease film.
      Also, please excuse pictures taken by a potato.
      Installed my offset CABs today, along with my 3.91 front diff.
      Only use the best
      • audiquattrot
        • May 2008
        • 3836
        #228
        Just out of curiosity which brand boots are u using? I was using what I thought were OEM equivalents and had a similar issue tearing boots prematurely. Made a post about it a while back, and ordered BMW OEM ones which were a lot different in material than the ones that kept tearing. Never had an issue since I used the pure rubber ones, as opposed to the hard plastic like ones
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
        • downforce22
          • Aug 2009
          • 3191
          #229
          Whats the offset cab supposed to do?
          • AWDBOB
            • Aug 2013
            • 4394
            #230
            http://www.r3vlimited.com/board/show...ighlight=boots
            They're the cheapies. This makes a lot of sense. It's also never the outers that tear first, it's always the inners, as you can visually see that they have the most stress on them from the axle angle.
            I shall try OEM boots, and report back. I appreciate the heads up, man.
            :up: Although I don't need the positive camber, I did it for the stiffer bushing and some caster.
            Control arm bushings locate the rear leg of our control arm. The M3 had an offset suspension for a wider track so the bushing itself is offset. It is in fact a higher durometer (stiffer), rubber than stock (non-M, E30), yet still compliant unlike urethane. If you install it in the OE manner (arrow on bushing points to dot on casting), then it causes the ball joint (and spindle) to rotate forward and in. This results in a slightly longer wheelbase with an increased caster angle. both of these aid high speed stability and straight-line tractability. The detriment is the reduction of negative camber. If you have lower springs and have too much neg camber, this is a cheap way to correct it. BavAuto sells them for $48 each. If you do this, you will need to add some toe-out up front.
              • 34836
              #231
              Only use the best
              dang. I've never had that issue. the pics don't work, but which boot specifically is ripping? I did have passenger inners fail prematurely but it was from my exhaust being too close.
              I'm not sure there is any difference in boots. A guy I know IRL on E30 tech posted a video on youtube comparing the BMW boots to the off the shelf Loebro boots and as far as he could tell they were exactly the same, only the BMW boots cost 3x more. maybe I'm wrong, I dunno. I've always used the $20 boots. they're both made by the same manufacture AFAIK.
              however, at 1,000 miles something is up. I'd think they should last 20,000-30,000 minimum.
              • audiquattrot
                • May 2008
                • 3836
                #232
                I didn't think there was a difference either, until I saw both side by side. One was def a harder plastic boot (which I had ordered from AutohausAZ), the OEM one (ordered from bmwmercedesparts) mostly/all rubber. Its' been 2 yrs since I swapped it out with the OEM one, and no issues....
                #snwmble
                Current:
                Past:
                • AWDBOB
                  • Aug 2013
                  • 4394
                  #233
                  Odd, the pics work on my end for some reason.
                  The boots that are ripping are the inner boots. Drivers inner boot ripped first, followed by the passenger's inner boot. Kinda driving me crazy. There seems to be plenty of slack left in the boot too for stretching. I don't quite know what else it could be at this point besides the quality of the boot itself.
                  Trying an OEM boot is my last option at this point. Might as well. Now you see why I was looking for spare axles :p
                  • Mlarsen
                    • 4082
                    #234
                    I was thinking about this issue awhile back. I know they make high angle cv boots for lifted trucks. In theory something like that could help. Don't know if anyone makes anything that'll fit our front axles.
                      • 34836
                      #235
                      I don't think you really need fancy boots
                      I've rarely had a driver's inner boot fail - maybe 2 of them in 140,000 miles that I've driven my ix. the most common one is the passenger inner boot and I believe that is because of the exhaust, but it still lasts me several years.
                      • AWDBOB
                        • Aug 2013
                        • 4394
                        #236
                        I've been thinking the same thing, Mlarsen. My inner boots when the car is on the ground visually have what appears to be far too much stress on them. I'm going to look into the longer boot idea. If they didn't look so stressed, I wouldn't bother with it, but I really think they would help in my case.
                        Nando, your boots are made of a secret mixture of platinum and unobtanium. For the rest of us, there needs to be a solution!
                        However, if all goes well I'll be picking up a much cooler project than an unreliable iX on Thursday, at which point my boots can stay ripped forever for all I care.
                          • 34836
                          #237
                          I'm not saying something isn't wrong, but I just don't think the boots should fail that quickly. I understand your frustration however.
                          I'll try to get a pic of mine this weekend to compare the CV angles. Mine are pretty steep but maybe you are still lower than me?
                          • rzerob
                            • Jun 2013
                            • 2315
                            #238
                            Originally posted by awdbob
                            however, if all goes well i'll be picking up a much cooler project than an unreliable ix on thursday, at which point my boots can stay ripped forever for all i care.
                            e30m3?
                            • AWDBOB
                              • Aug 2013
                              • 4394
                              #239
                              Oh, I was just kidding, man. I'm thinking the boots were too tight on there without enough slack left for the angle of the dangle. I actually think you're higher than me now! I raise my car all the way back up. And the boots still went bye bye. Which leads me to believe they're either A) Shitty quality B) Installed too tight or C) Both
                              Originally posted by rzerob
                              e30m3?
                              I wish! An E30M3 is coming up fast in the 'someday' list of cars for me.
                              • AWDBOB
                                • Aug 2013
                                • 4394
                                #240
                                I know you fellas probably won't think it's as cool as I do, but picked up an E34 530i 5sp Touring Wagon tonight.
                                Body wise it's in pretty good shape minus the repainted door, which I don't care about. Needs a rear bumper.
                                Mechanically the motor runs great. Fresh clutch and trans. Needs struts BAD, along with the pitman arm bushing.
                                So, I'm going to clean it up, do H&Rs and Konis, have a set of M Parallels lined up, and drive her. I'm excited.
                                Bids for the pink scooter start at $10K
