Project: Spielereien. AKA "The dumpster fire"
  • 2mAn
    SeƱior Mod
    • 21062
    #181
    Originally posted by delamaize
    Thanks Simon.
    I appreciate it! I'd never thought that anyone would be intrested in my shit box.
    doenst matter how old we get here... we're all just a bunch of sh!theads who love the sh!tboxes. this isnt s14.net lol
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • delamaize
      • Nov 2013
      • 1465
      #182
      Not much of an update, But something. going to wider tire and fixing the brakes made it possible to drive the Dumpster Fire all the time, even with crap weather. It's still sketchy in the wet, but not like it was. I took it to work the other day, Wow, it does not like the cold! LOL This is when I came out at 0645 and started it to let it warm up before heading home, It defiantly was not happy.
      Dumpster Fire Pilot
      • delamaize
        • Nov 2013
        • 1465
        #183
        Got my new to me Mtech wheel recovered, Using a kit from Redline Goods. It looks good, not perfect, but I'm happy with it. I accidently trimmed the cover too short on each of the lateral spokes, but I have an idea how to fill the gap, and make it look nice. I'm at work, so I will get some pictures Sunday evening when I'm off duty again.
        EDIT: picture added
        On the bad list, I developed a coolant leak on the rear of the motor. The leak isn't bad, I usually have to add about 8 Oz of coolant every time I drive it right now. I *think* that It's the hokey hose layout I had to do to make the heater and coolant expansion tank work. I need to come up with a better solution. I'm also considering changing out the rear crossover pipe with a different one. I think the donor car had dual climate zones, and If memory serves me, I have the crossover pipe that has like 4 outputs, rather than the one that has 2, Like this one: https://www.ecstuning.com/b-genuine-...e/11531702201/ and simplifying the hose layout, by using stock hoses like these: https://www.ecstuning.com/b-uro-part...218390710~uro/ I used some household 90 Deg brass angles to make a 180 turn to get to the expansion tank, mainly to just get the car on the road. The whole "Don't get it right, get it running." Mantra from David Frieburger, knowing I would need to fix it right later. I'm thinking that the time is quickly approaching. When that project starts, I'll be documenting that here also. My heater blower has started squeaking recently also, I'm hoping when I attack the hose issue, I will have the room to get the blower cover off, and have the room to replace the blower or at the least lube the bushings.
        Dumpster Fire Pilot
        • delamaize
          • Nov 2013
          • 1465
          #184
          Update: coolant leak is coming from an extra port on the cross over pipe, that I caped with a rubber cap. I used the same cap on an extra port on the reservoir, and that cap was bad when I pulled the car from the barn storage.
          To add insult to injury, its in a place where I cant get to it, without pulling the motor. FML.
          Dumpster Fire Pilot
          • varg
            Florida Turbo Man
            • May 2014
            • 3434
            #185
            Oof. Up against the firewall? It's not accessible with the intake manifold off?
            IG @turbovarg
            '91 318is, M20 turbo
            • delamaize
              • Nov 2013
              • 1465
              #186
              Nope, it sticks out the back lower portion of the Cooling System Accumulator, and points down towards the bell housing. I actually had to clearance the transmission tunnel close to the firewall so this output didnt rub it.
              Sorry about the late reply, I dont get on R3V as much as I use to...
              Dumpster Fire Pilot
              • delamaize
                • Nov 2013
                • 1465
                #187
                So I haven't updated This Thread in an extremely long time, but I figured I would come in here to say two things.
                One: The Saga of Project: Spielereien took some while twists and turns since the last time I updated this thread, Including a name change, it's now called the dumpster fire. The car ended up sitting idle in storage in a barn for 5 years, and a bunch of other bullshit happened. If you want the full update click the link in my signature, that is the most updated thread, and.....
                Two: I will not be updating this thread anymore. I've been doing all the updates on the thread that's Linked In My signature. And that will be the only thread from here on out. Project: Spielereien, aka the dumpster fire, is alive and well, and will continue to be for the foreseeable future.
                for the 1.5 of you that actually are reading this thread, I hope to see you over on the other thread. Lol
                Dumpster Fire Pilot
                • 2mAn
                  SeƱior Mod
                  • 21062
                  #188
                  Kinda clunky, but the 2 have become ONE!...
                  Now get it done!
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • delamaize
                    • Nov 2013
                    • 1465
                    #189
                    Parts ordered to address the coolant leak. Now to just find the time to drain the coolant, and slide the motor/tranny forward, or pull the whole damn thing.
                    Dumpster Fire Pilot
                    • BadDays
                      • Dec 2024
                      • 186
                      #190
                      Coolant related issues are my worst enemy, Let's hope you can get it done with the motor still in the car, BTW V8 swapped E30's are just infinitely more cooler than M50/S52 swaps šŸ™‚ā€ā†•ļø
                      • delamaize
                        • Nov 2013
                        • 1465
                        #191
                        Did a little looking at the location of the leak today, I *Think* there is a small chance that I could drop the driveshaft, Tranny crossmember, Disconnect the exhaust, Move some heater/reservoir hoses, Loosen the motor mounts, and lower the tranny, angling the entire thing down in the rear, the I *Might* be able to reach around the bellhousing and *Maybe* get to the offending plug and replace it. The permanent fix is still going to require pulling the motor.
                        Geesh, reading that after typing it, the effort it will take to do that, I'm thinking I will probably just skip the band-aid fix, and just pull the damn thing when the parts get here....
                        Dumpster Fire Pilot
                        • delamaize
                          • Nov 2013
                          • 1465
                          #192
                          Well, While I wait for parts to fix the leak, I figured I'd figure out why my drivers window stopped working about 3 months ago. Yep, Motor is toast, and track is Fuct. Found one on E-bay, It's on the way. Man, Some of the prices on some of the regulators were insane. Saw one dude that wanted $600 for one that looked like he pulled it out of a mud pit, With no Make an offer option. Are these really that sod-after.
                          Oh well, Only paid $200 for the one I ordered, after shipping.
                          Dumpster Fire Pilot
                          • delamaize
                            • Nov 2013
                            • 1465
                            #193
                            UPDATE TIME! WOO!
                            After a mess of staring, and head scratching, i came to the conclusion that I could get to the coolant crossover if I pulled the Intake. Needless to say, thats what happened.
                            Click image for larger version  Name:	20260524_100406.jpg Views:	0 Size:	267.8 KB ID:	10161517
                            I was able to get to all the bolts and got the bastard off.
                            Click image for larger version  Name:	20260524_104655.jpg Views:	0 Size:	260.4 KB ID:	10161518
                            and found the smoking gun.
                            Click image for larger version  Name:	20260524_105121.jpg Views:	0 Size:	104.4 KB ID:	10161519
                            So I was off a little, not the cap, but a break in the line that looped around to the reservoir.
                            Now that I got it out, gotta track down the T shaped hose that connects the coolant cross over to the reservoir and heater core, a hose for the other heater core connection, and a tap for the temp sensors. The replacement crossover I picked up has the bosses, but no homes drilled.
                            Might throw some new injectors at it, since I got it this far apart. The old ones are OEM, and could use an upgrade.
                            Dumpster Fire Pilot
                            • delamaize
                              • Nov 2013
                              • 1465
                              #194
                              Well, some things got done today.
                              the new crossover I yanked from a junkyard 2001 540i didn't have bungs for the temp sensors.But it did have the bosses.
                              well, now it has Bungs.
                              Click image for larger version  Name:	20260525_101924.jpg Views:	15 Size:	215.5 KB ID:	10161591
                              I ended up buying a entire tap and dye set from harbor freight just to get the M14x1.5 tap to thread the holes. Oh well, im sure I will need the set again someday.
                              Dumpster Fire Pilot
                              • delamaize
                                • Nov 2013
                                • 1465
                                #195
                                Progress has been made. Crossover with new O rings and gaskets has been mounted. Hoses aquired and fitted. It not perfect, but it will work, and is better what was there before. No more household plumbing parts mixed in. Filled the system with new pentefrost, with no leaks. Just waiting on the Intake O rings/Gaskets now, then the Dumpster Fire will be ready to Terrorize the roads again. I cant wait! I miss throwing around the shitbox!
                                Click image for larger version  Name:	20260601_164047.jpg Views:	3 Size:	218.8 KB ID:	10161911
                                Dumpster Fire Pilot
